Question about Microwave Ovens
Ic CDMW 12B microwave and purchased a new front screen. My question is how do I remove the internal door parts to get to the front screen.
  • Microwave Ovens Master
  • 9,086 Answers
Normally you have to separate the door panels as shown in the photo below.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Posted on Jan 17, 2013
5 Suggested Answers
MicrowaveSvc
  • 9086 Answers
SOURCE: Sharp Carousel Microwave R-1601
We have the service manual for the R1750-series ovens available at our Web site.
It's not exactly the same, but it should be generally close enough to help you.
It's at http://microwavedisplay.com/r1750_r1751_r1752_r1754_sm.pdf
Most door panels separate like the one in the example photo below.
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 01, 2007
MicrowaveSvc
  • 9086 Answers
SOURCE: Sharp Carousel Microwave R-1601 - Need to Replace Door
It's at http://microwavedisplay.com/r1750_r1751_...
  • 13 Answers
SOURCE: Cannot Remove Sticker Goo on Door of New Sharp R-420lw Microwave
Hi, Go get a can of wd40 and spray a rag with it then use wet rag to rub the old glue off-this will work for any kind of sticker or remains of stickers on most surfaces-wd40 works like magic when removing any old stickers-is especially awesome for Park pass type stickers on car windows!
Posted on Dec 20, 2007
  • 15 Answers
SOURCE: remove a door on a microwave
I wouldn't remove the door myself if I were you. If you just got the microwave, it should be under a return/replace policy, or a warranty. I would recommend returning the microwave and getting a sturdier one, as you don't know if the problem exists for all microwaves in that series, and most stores don't allow the replacement to be return/replaced.
Posted on Dec 07, 2008
Tip
HOW TO REPLACE THE DOOR OF A MACROWAVE OVEN
GeneralElectric is internationally known as a premier manufacturer of ranges,ovens, stove-tops and various other household appliances. ConsumerReports ranks General Electric appliances high on functionality andtheir low rate of repair. Currently, manufactures microwave ovensand wall ovens. Microwave oven doors are designed to be removed andreplaced by professional repairmen because a "leak test" must beperformed upon replacement to ensure ions are not coming off themicrowave's magnetron. With wall oven doors, removal and replacement bythe owner is a straightforward task that is safe for any owner tocomplete.
Here are step by step Instruction on how to fix in your microwave door below.
step1.
If your microwave door is cracked or the latch is broken, you may be able to replace it instead of purchasing a new microwave. Check the manufacturer's website to find out how to order a replacement door that is compatible with your specific make and model or visit any technician store that deal with microwave and oven around your local area to get one.
step2
Your owner's manual may also list a part number, which you can use as a reference when looking for a new microwave door.
step3.
Difficulty or note able part : Moderately Easy Instructions material needed Replacement door with Screwdriver a technician tool .
step4.
Unplug the microwave and set it on a table or workbench. If you have a built-in microwave, you may have to remove some mounting screws or retention clips to get the microwave out of the support bracket.
step5.
Open the door and take out the glass tray.Pry off a corner of the plastic panel on the inside of the door with a screwdriver or butter knife. Once it is loose, work the screwdriver or knife all the way around the glass and remove the panel.
step6.
Ask someone to hold the microwave door as you disconnect it from the hinges.
NOTE:
Depending on the design of your microwave door, you may have to remove a set of screws or slide a pin out of the hinge to release the door.
step7.
Remove and discard the old door. Have your assistant hold the replacement door up to the hinges.
step8.
Attach the door to the hinges by reversing the previous step. Snap the plastic inner panel into place around the glass.
step9.
Move the microwave back to its original location. Insert and tighten the necessary mounting screws if you are working on a built-in microwave.
step10.
Set the glass tray back inside the microwave and close the door.
Good luck.
Thank you and thanks for using visiting fixya.
on Oct 27, 2010 | Microwave Ovens
I've got a model: JES1036PWH02.....when I plugged the unit in the internal light came on, the screen showed all eights and then in a few seconds shows a "PF" and NONE of the buttons work? How...
The keypad controller is defective, behind it there is the microprocessor ic mounted on a board with several other parts. The whole keypad and circuit board must be replaced, and the cost just for the part will run more than a new microwave.
Feb 06, 2011 | GE Microwave Ovens
Can I buy a new door. Current door is cracked on the corners.
You easily replace the door on most microwave ovens by opening the door all the way up and lifting straight up at the hinges. The door should lift off of the hinge pins. On some microwave ovens, you may have to remove the upper grill cover over the door (if equipped) to accommodate door removal.
NOTE: Some doors have a hinge pin that needs to be removed, or screws holding the door in place at the hinge.
There are several parts sources available that you can may try to purchase replacement parts:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites on the list also offer helpful exploded view parts listings to aid in parts identification and location. Just type in your model number and locate the parts listing for the door. Some manufacturers only sell the door as a complete assembly. Others may sell individual parts. To save money, you may also try just purchasing the door facing parts that are cracked. If you have any questions, or require additional assistance, please post back with your complete MODEL NUMBER and let me know. I hope this advice is helpful.
Dec 16, 2010 | General Electric Microwave Oven
On the inside of the door of my microwave front window is an adhesive plastic covering that if you pull it off there is a black mesh screen exposed. is that clear sheet suppose to be removed.
The metal mesh is a filter screen to keep the microwaves in the oven while letting you see the food. The plastic sheet that's peeling off is meant to keep that screen clean. It's not supposed to be removed, since then food can get into the holes in the screen. A buildup of foods can lead to overheating and burn the paint and possibly damage the door. It should be replaced.
The part number is WB36X10068. A Google search turned up several sources. Here's one, but there are others. The new sheet has the adhesive applied, you just peel off the protective film and stick it in place. Clean the door inner surface first so the new sheet will stick firmly.
Good luck with the repair, and thanks for using Fixya!
Oct 17, 2010 | Hotpoint RVM1435 Microwave Oven
There is a whirlpool Microwave (model:MH1150XMB4) in our apartment. Unfortunately, there is a crack in the door. Although the crack is only in the plastic frame of the door, the landlord asked us to...
Got the same problem. Still inquiring but I might have found a solution here : http://midwestapplianceparts.com/microwave-parts-537/whirlpool-microwave-parts-648/microwave-door-panel-663/whirlpool-microwave-door-panel-w-glass-4212.html
$79 for the panel only
Jul 01, 2010 | Whirlpool MH1150XMQ Microwave Oven
I NEED TO REPLACE PART 83242. HOW DO I REMOVE
I do not know what part #83242 is. A search of several reliable parts web sources, yielded no positive results. So, I'm guessing this may be a door handle(?). If so, to access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you need to remove the entire door, simply open it all the way and lift at the hinges. The door will lift off the hinge mounts. You may wish to remove the door for an easier means of working on it. Especially, if the microwave is mounted above your range.
If you have questions, please let me know. If this is not what you are needing assistance with, please post back with the name of the part you are trying to replace. I hope you find this information helpful.
Jul 10, 2009 | Sharp R-1480 Microwave Oven
How to change the handle
To access the door handle mounting screws, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to simply pry the plastic up and work your way gradually around the perimiter of the glass. Most microwave ovens have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
If you have questions, please let me know. I hope you find this information helpful.
May 14, 2009 | Kenmore 62702 Microwave Oven
Removed splatter shield
The parts can be ordered from the Panasonic authorized parts rep. You have to contact Panasonic for details.
I strongly recommend to have any work on a microwave oven done professionaly. There are radiation leakage issues if the door is not re-assembled properly. After doing any service the microwave oven must be tested for radiation leaks. I doubt that you have the radiation testing equipment to make sure that there are no leaks.
From US Food and Drug Administration (Microwave Oven Safety)
http://www.fda.gov/cdrh/consumer/microwave.html
Excellent Wikipedia Article About Microwave Ovens
http://en.wikipedia.org/wiki/Microwave_oven
Jerry G.
Jul 26, 2008 | Panasonic NN-S753 Microwave Oven
Door Window steams up on Microwave
Is the internal cooling fan running? You should feel air flow from the grille in the front or back (as the case may be).
If it's just steaming up the inner face of the door, that's fairly normal, but if the steam is appearing inside the layers of the door, that is not normal.
Since it's new and you've got a warranty, I would call Emerson.
Nov 02, 2007 | Emerson MW8107WA Microwave Oven
Microwave Ovens Logo
20 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
