Question about Roper RAS8445KQ Top Load Washer
Roper Top Load Washer Does Not Fill To The Top on ''Extra Large''
I have a Roper Washer.. it works fine on all temps... but the water does only fills up to about 75-80% on ''Extra Large'' Capacity Load...? any ideas?? seems to me it should fill up much more.. not sure...
  • 686 Answers
The water level switch can be adjusted to raise the water level but is not recommended. The level you have is normal.
Posted on Apr 04, 2009
I have a roper heavy duty extra large capacity washer the water comes into the machine fine but runs out just as fast, it won't fill up.
Go direct to the maker. This sounds like the pump is running continuously, or do you mean it empties on the floor?
If the latter, a hose has come adrift or split/perished?
Welcome to Roper Home Appliances
Sep 12, 2015 | Roper Washing Machines
The cold water cycle is not working on my Roper washer top loader heavy duty
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
May 12, 2011 | Roper RAX4232KQ Top Load Washer
Roper washer fills with water continuously
Your inlet valve is defective, can be easily changed. Approach your dealer with your model number he will direct you to the spares shop, or tell you where you can get it. Or google 'roper washing machine spares'
Feb 23, 2009 | Roper RAS8445KQ Top Load Washer
Maytag washer water doesnt stop
raise top or remove front panel(can't remember which) rear corner left small hose attached to connector on tub pull and clean probably plugged up with crud also ck connection on tub
Dec 12, 2008 | Maytag HAV3460AWW Top Load Washer
Washer makes noise, will not fill
turn it on and just makes a hummins noise??? not filling with water??? at very least the machine if powered correcly will fill with water, the humming if happening is hte washer trying to fill check your incoming water supply. try alo changing water temp select from cold/warm/hot.
Dec 03, 2008 | Roper RAS8244KQ Top Load Washer
Washer Filling
Sometimes the small tube leading to the  level sensor becomes clogged with soap scum and such. Find the sensor and disconnect the tube and clean it out. Next I would check the fill solenoid to make sure that it is not becoming lazy.
May 19, 2008 | Roper RAS6233KQ Top Load Washer
Washer will not fill all the way.
you may have to adjust/replace the water level switch. it is located behind the control panel. the water level knob is attached to it. it does have a screw adjustment.
May 15, 2008 | Roper RAB2121KW Top Load Washer
Washer leaks when running full loads
This could mean the fill level is not working properly and there is an overfill situation. Generally[I don't know 'Roper'] the fill level is controlled by a 'bottle' like device at the fixed to the outside of the drum at the bottom with, with a fine tube leading to a disk like thing near the top of the machine- with wire coming from it to the controller. The 'disk' thing is the pressure sensor. and the bottle thing is supposed to fill with water and the air pressure in the tube actuates the switch in the 'disk' Overtime the 'bottle' will get clogged with crud and need cleaning out. This will mean taking it off and giving it a good cleaning. Hope this helps.
Jul 07, 2007 | Roper RAS8445KQ Top Load Washer
It will not fill with water
how do you open top on whirlpool washer?
Jan 23, 2007 | Whirlpool LSR9434PT Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
174 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
