Question about AEG Lavamat 16810 Front Load Washer/Dryer
Key in machine
There is a key in the machine under the drum.when the machine is on spin the key is tearing between the drum and what it runs in.how i know its a key is becauce 1 key has come out already(by accident).have you got any advice on how to get under the drum.
  • maurice madigan Jul 12, 2007
    thanks for the suggestion about the sump hose,it worked.
    Problem Solver:
  • 18 Answers
2 things you can do, either remove the sump hose from the bottom of the drum,or take the back off remove the element and fish the key out from there
Posted on Jul 11, 2007
SOURCE:
Why do i have loud noises coming from my washing machine only whilst it spins
The bearing in the drum has failed and it's always noiier as it spins faster as there is more debris being thrown around inside the hardened steel casing of the bearing. Bad news is that's a write off. Uneconomical repair. It will tear its self apart shortly, probably leaking grease into the wash and leaving black marks everywhere, oor the drive belt will come off, or the drum will impact the front gasket and fill the drum with smoke. Any way you look at it, it's almost certainly going to destroy a load of washing. Throw it away now before it wrecks your washing
Aug 21, 2016 | Washing Machines
It shakes excessively on spin cycle, machine is level, it does it on every load, it is beginning to tear up door seal
It shakes when off balance. Your wash load may be balanced but the drum may not be. This could be down to the drum bearing or the "spider" that holds the drum in place. If one of the arms is broken it will spin off balance.
Oct 26, 2015 | Washing Machines
Washing machine banging noise
It could be the main shaft on the drum or misalignment. There is some flexibility, but not a lot. Check for worn belts, pulley wheels, and other attachments.
Feb 26, 2014 | AEG Washing Machines
Ge profile wpdh8800
the spin cycle is run by a belt-I'd say something is stuck like the drum or you just have a bad belt or probably both. you'll have to do a tear down to see for sure-to check bearing in tube try to turn by hand to see if its tightCheers-Denny
Oct 11, 2013 | Washing Machines
Wt you mean by spin in washing machine
its a separate cycle all by itself.
Say U hand wash something in a sink and instead of wringing it out by hand U can put it in the washer and press this SPIN cycle.
So U can also use it to spin more water out of your garments after the regular wash and spin cycle.
Slower spin speeds mean -
  • Cheaper washing machines
  • Quieter washing machines
  • More stable washing machines
  • Longer lasting washing machines because there's less wear and tear on the bearings, motor, carbon brushes, suspension etc.*
  • Gentler on laundry
  • The drum spins for approx 4 or 5 mins. No water is added and you dont add detergent or fabric softener for the spin only option. The object of the exercise is to centrifugally remove excess water from the garments in the drum. They will still be damp but not sopping wet after the spin cycle
  • Spin takes the water out, extract is even better
May 17, 2011 | Frigidaire ATF6000ES Front Load Washer
Our washer is cutting our clothes.
Possible that there is a gap in the spinning agitator that seems to chew up the clothes to damage.
SO if you notice this gap then remove and reset the spindle.
if not make sure that the drum pores have some sharp edges which is tearing , run your hands/palm over the drum for a suspected abrasive edge.Can be some objects that have lodged into and causing to behave as a knife edge.
Dec 20, 2010 | Washing Machines
Cause of noisy spinning
your drum bearings have gotten water into them from a defective inner drum lip seal,now you need to tear down the machine and replace the lip seal and also replace both inner and outer drum bearings
Apr 18, 2010 | Zanussi ZWF1430W Front Load Washer
Motor runsbut drum very slow to spin in spin cycle
The motor could be on its last leg of working. You can also check to make sure that the belt is not binding against anything under the drum. You may also want to make sure that the conterbalance weight is not hitting the belt. Make sure that your machine is lever and that it does not walk during spining.
Nov 28, 2009 | GE Washing Machines
It leaks water and makes a banging noise when on spin cycle
your stabilisers are either off the hooks or shot or the springs that keep the drum in place are over stretched most likely cause is overloading it as for the leaking the water tight skin around the door most likely has a hole or tear in it all are fixable, bras are the most likely cause for this or anything with metal in it depends on how old it is really, they can tear under stress from being overloaded
Nov 20, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Drum won't spin
A couple of possibilities,there is something fast in the drum,or the main drum bearings have seized up.
If it is the bearings, and it is under 5 tears old, then you should be able to get it done under your 5 year parts guarantee., you just pay for labour and call out, a much sheaper solution than buying a new washer.
You really need to determine what has caused it to jam up.
Plz rate this solution.
Thanks.
Dec 15, 2008 | Hotpoint Aquarius WF000 Front Load Washer
AEG Lavamat 16810 Front Load Washer/Dryer Logo
126 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
mikenearman
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
