Question about Whirlpool GLS3665RS Gold 36 Inch Gas Cooktop -Stainless Steel
CONTINUOUS SPARKING OF IGNITOR - Whirlpool GLS3665RS Gold 36 Inch Gas Cooktop -Stainless Steel
How to replace electric ignitor for outdoor grill?
it may be that the electricity or the spark is connection to different point of the grill, the electricity will spark to the closest point of conductivity.
if you check and each ignitor is sparking , strongly ( so no problem with spark modual), then there may be points in the wireing whichis exposed or more likely where the wireing and the ignitore connects,
you can tape it with electrical tape, then it should see the spark to the burner. if it is sparking, and not to the burner, just means it is sparking to a different point, where the jump is shortest.
Apr 18, 2013 | Cooktops
Jenn-Air JDG8430 Ignitor won't stop sparking after burner ignites
Test the ignitor first, if the ignitor does not spark should be the ignitor itself.
Oct 12, 2008 | Jenn-Air 30 in. JGD8430A Gas Cooktop
Ignitor sparks continuously
Hi, How long ago did you get the ignitors wet? Most cases, unplug the range for a few hours giving it time to dry out. Maybe set a fan near the range top to help dry it. This helps MOST of the time. please let me know if it helps or if I can assist you further.
Vic
Jul 04, 2009 | Cooktops
Gas ignitors continue to spark every 5 seconds in off position
try unplugging the unit over night, itspossible that by you cleaning the tops, the electrodes got wet, falsley sparkin, when the water dries out it should stop, and no not dangerous in any way, only annoying to listen to
Feb 13, 2009 | Amana AKS3040 Gas Cooktop
Ignitors Continue to Spark
Turn the knob back towards off about 1/8 of a turn and you will take it off lite and it should fix it.
Aug 27, 2008 | Thermador 37 in. SGSX365 Gas Cooktop
Continual clicking of the automatic ignitor even when burners are off
some JA models i have seen the the spark switces are poorly constructed or improper installed from the factory and beging to become a probelm after a year or so of use. this is not a gas pressure issue it just plain ole' bad spark switches
Sep 05, 2007 | Jenn-Air 35 in. JGC9536 Gas Cooktop
Ignitors on all 5 rings wont stop sparking
you have a short in the ignition switches. these are located at the base of every stem under the knobs. In order to get to them you have to remove the entire cooktop, which entails removing all of the burners. The switches are run in parallel on a single harness.
Jun 23, 2007 | Baumatic 27 in. B67 Gas Cooktop
Whirlpool GLS3665RS Gold 36 Inch Gas Cooktop -Stainless Steel Logo
Top Whirlpool Cooktops Experts
vince
Lakeland Appliance...
Are you a Whirlpool Cooktop Expert? Answer questions, earn points and help others
