Question about Master Plumber 123333 1/2 HP Shallow Well Jet Pump
I need a parts manual for a master plumber 1/2 hp shallow welll jet pump mod. 504-407.
I need a c face mount and a new impeller. plus the manual
I have a UtiliTech 1/2 HP Jet pump #0003124. I need a manual. Can I get a larger volume impeler for this mode?l
Put a vacuum gauge on the suction, see if it goes real low after pumping a couple of gallons. If so, your point may be stopped up. A 1/2 hp pump should pump 40/50 psi, fill a 5 gal bucket in a minute or so.
Jul 29, 2015 | Utilitech 1/2 HP Convertible Jet Pump...
I just installed our EVERBILT 1/2hp shallow well jet pump! I cannot get it to hold prime?im a plumber by trade! bought it on Amazon its used! !Came without owners manual?! What am I missing?
you get what you bought,buyer beware,someone else gave you a deal,go cheap and end up spending more,get a rebuild kit or buy new from someone you know
Apr 30, 2015 | Jet Plumbing
Why would my 1 hp pump only maintain 45 psi running 1 garden hose?
Without knowing all your variables with well it is hard to say. Bladder tank needs to have 30 psi with no water pressure. It is possible that the screen down the well is restricted and you are only getting that much water. Or you may have clogged impeller in pump.
Sep 04, 2014 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Need manual for utilitech 43467
You might be able to obtain this directly from the supplier
Jan 15, 2013 | Utilitech 1/2 HP Convertible Jet Pump...
How to separate motor from 1/2 HP sprinkler pump?
To do that you need to take the pump apart...take the bolts out that hold the motor to the pump and then unscrew the impeller from the pump shaft....
All this is not easy and will be very difficult if you are not experience and handy with your hands...
getting the impeller off in one piece can be the toughest part...
heatman101
May 10, 2011 | Sta Rite Industries Shallow Well Jet...
I have a Flotec shallow well pump. The motor is buzzing but it will not turn.
could be bad bearings,obstruction in impeller,low voltage,failing capacitor.
Dec 20, 2009 | Flotec Corrosion Resistant Shallow Well...
Shallow well jet pump not pumping and kicking out
It sounds like the pump impeller is impaired. A sure way to tell is take the impeller off or out of the housing and see if pump works by itself. Lots of pumps do this when they have been frozen. Hope this helps.
Jul 06, 2009 | Plumbing
Master Plumber 123333 1/2 HP Shallow Well Jet Pump Logo
91 people viewed this question
Top Master Plumber Plumbing Experts
Donni Steen
Tom Chichester
Are you a Master Plumber Plumbing Expert? Answer questions, earn points and help others
