Question about JVC AM FM CD DET FACE CAR STEREO
How to wire a jvc kd-r330 head unit with an 1999 oldsmobile intrigue
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • JVC Master
  • 102,366 Answers
You may download a copy of the installation manual here.
Posted on Jan 16, 2013
JMuskovitz
  • 135 Answers
SOURCE: JVC KD-S640 pinout needed
For ten bucks, you can buy a new connector: http://www.jvcservice.com/store/ProductDetail.asp?part=JV16-0001A To figure out how to wire it: http://books.jvcservice.com/download/256614688/28879.pdf Page 25 describes the color of the wiring in the harness.
Posted on Mar 29, 2007
informatica
  • 1114 Answers
SOURCE: how set time jvc kd g220
Hi - You can download the manual from the link underlined in blue below:
jvc kd g220
See page 10.
Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Jul 21, 2008
soundinstall
SOURCE: jvc kd-pdr30 ipod problems
The Touch will not work with the KDPDR30. I spoke with JVC and their models that will operate the Touch are KDPDR40, KDAPD49, KDPDR45, KDPDR41 and KDG47 the last two have a cable required.
Posted on Mar 02, 2009
josetejas
  • 300 Answers
SOURCE: Connecting iPod to JVC KD-LH810!?!
Hi, KD-LH810 has no option for external input. Refer to the picture attached. It is only front and rear line outputs. Don't get disappointed. Buy the accessory cable KS-U100 and you are set. This info is from the installation manual.
Posted on Jan 19, 2010
josetejas
  • 300 Answers
SOURCE: need to wire JVC model KD-G340 into a 97 Kia Sephia
Do not cut the wires from the car. Instead, call Crutchfield at 888-955-6000 and order the adapter part number 120701003. When you call them, ask for color coding. For JVC, refer to the attached picture. Match the adapter color code with that of JVC. If the adapter color code is the same, then connect ground (black), battery (yellow), and wire from ignition switch (red) securely. Turn on the car and see the radio works. If it works, connect one by one speakers and confirm. Remember, perfect connection gives reliable installation.
Posted on Jan 25, 2010
I need a maunal for cd player Jvc Model KD-R330:
Try the jvckenwood website. Or a quick foogle search should turn up numerous places to get it from
Dec 31, 2016 | JVC Car Audio & Video
Which car wire would you hook to JVC KD-R330 memory wire?
Constant power. In other words it should be hot even when the ignition is off. Most likely black. Put a voltage tester on the wire and to the ground point. If you read 12V with the ignition off, that's it.
Jun 09, 2015 | JVC Car Audio & Video
I have the jvc kd-r330 and I have it hooked it. It has a battered source and power coming in but won't turn on or display anything.
make sure you have the ground wire is connected. If there is no ground radiop wont turn on, also make sure with a volt meter that there is power going to radio
Oct 21, 2014 | Car Audio & Video
How can i save my settings on jvc kd-r446 ? every time i shut down my settings is reset
if it is resetting oon shut down , you dont have your memory wire connected to a full time power wire . full time power wire is a wire that has power even when car is off.. this is what saves your memory on the head unit.memory wire is usually yellow.
Feb 26, 2014 | JVC Car Audio & Video
JVC KD-R330 Won't turn off Demo mode - tried instructions. Every time I follow the instructions (Turn on, Hold Menu, push "vol" button, change to Demo off...etc) It doesn't work. In fact, as soon as I...
Do you have a Bluetooth adapter plugged into the KD-R330?
A compatible Bluetooth adapter (like the KS-BTA100) usually plugs into the rear auxiliary port of the receiver. It then needs to be "paired" with your Bluetooth device, for example, a Bluetooth phone headset.
What you're describing sounds like what can when no Bluetooth device has been "paired" yet.
If you don't HAVE a Bluetooth adapter connected to your KD-R330....is it possible you accidentally plugged something into its rear auxiliary jack? Or the front auxiliary? In other words, is it possible your KD-R330 receiver is mistaking some other device for a Bluetooth adapter?
Don't know if that helps at all...if there's no adapter issue, and nothing connected to the AUX jacks, probably your next step should be a call to JVC, or whatever number you were given for tech support.
On the bright side, since the receiver turns on, and responds to some commands, you probably didn't mess up anything major in the wiring. And, there's also the possibility the receiver is defective....certainly if this continues, and JVC can't help you, trying a replacement might be worth a try.
BTW, feel free to post a reply...I'm going to look further to see if there's any other documented issue besides an adapter that might cause the problem you're having.
Oct 29, 2013 | JVC Car Audio & Video
Directions for,setting up system
Go online on google, Type in the brand end model number of the deck in the search box, You will find sites where you can print off a owners manaul for no charge.
Oct 19, 2012 | JVC Kd-r330 kdr330 In-dash Cd/mp3 Car...
Have a 1999 Oldsmobile Intrigue 3.8L V6. The radiator fans are not coming on when the car gets hot and the car gets real hot what and where is the sensor for this?
Providing your guage is working correctly; look just inside the fan, you should see a wire coming from the fan motor, follow the wire. It will end up at a sending unit that looks similar to a fitting. This is what tells the fans when to turn on.
Nov 07, 2009 | 1999 Oldsmobile Intrigue
Jvc kd-avx11
The parking brake wire is about a mint green color.
Oct 26, 2008 | JVC KD-AVX11 Car DVD Player
JVC AM FM CD DET FACE CAR STEREO Logo
119 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
