Question about Ovens
GE IN Wall Oven Model # JTP15WDW1WW Oven Sensor Replacement
My Oven Heat Sensor Needs Replacement. I Received the new GE Genuine Part #WB23T10002. When I take the old one out it is connected to the outside back wall with two Twist On Electric Wire Caps. The new part has a plastic white Molex like connector on it. One wire on the new connector has writing on it the other none. The Oven is 15 years old and doesn't have a newer connector plug on it. Can I snip off the White Connector on the new part and Twist on the wire caps to connect it to the oven??? I called GE and they have no answer for me.
  • tmyc Jan 24, 2013
    I received no answers from anyone here or at GE. I took the oven and... Well... I Fixed whatever was wrong. Since I received no answers...? I will give no answers. Fair enough! The answer would be helpful to anyone in the future.
2 Suggested Answers
  • 2006 Answers
SOURCE: i just installed an electrolus
Unfortunately, you do not have 220 volt standard house wiring. In fact, I bet if you put a meter on it, you will only have 110 volt. All US standards and codes require the standard 220 Volt wiring (Red and Black - hot; White - Neutral and green is the ground.
Also you need to look into what the oven require for amperage. Not only is that important for the circuit breaker that you install but also the size of the wire required.
I would suggest you read your manual and then run the proper size wire from the circuit breaker panel to the ovens.
If you attempt to operate the ovens on the wire you have installed, your insurance company has not legal obligations to pay for the repair of your house when it burns down.
Posted on Jul 12, 2011
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
The convection oven feature does not work. The oven heats (slowly) as a conventional oven but when we set the oven for convection the oven does not heat.
Hello & Welcome to FixYa
This indicates an open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you want to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more than this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Nov 25, 2011 | GE Profile JT915 Electric Single Oven
GE double oven Model JTP56WOA2WW top oven won't heat up, fan runs, relay clicks, no heat
This indicates an open/shorted oven temperature sensor and to solve this problem the temp.sensor needs replacement. If you want to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Mar 27, 2011 | GE Profile JKP56 Electric Double Oven
My wall oven will heat up and then starts to blink F3
F3 error code indicates an open/shorted oven temperature sensor and to solve this problem the temp.sensor needs replacement. If you want to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Mar 09, 2011 | GE Profile JKP18 Electric Single Oven
Fisher & Paykel double wall oven, bottom oven will not heat to set temp. Stops a 75 degrees
This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Feb 03, 2011 | Fisher and Paykel Titan OD301M Electric...
GE Profile Convection Problem
with GE
SHORTED OVEN SENSOR CIRCUIT
if your comfortable taking the range out of the box, it is a pretty easy repair. The oven sensor is a small tube in the range that "sences" temp.
although it could be the erc, its more than likely the sonsor itself.
it is on the back wall and has to be unplugged from the back to be removed
there are two screws that hold it on the back wall
put the new one in and you should be ready to go
goto appliancepartspros.com
type in your modle number and look in the cavity section
your looking for the oven sensor
they usually run around 20-30 dollars
Oct 17, 2009 | GE Profile 30" Built-In Single Electric...
Do I need to remove my wall oven GE model JTP14 to replace the heat sensor part # WB23T10002
Usually you have to either remove the top of the oven or you can remove the back panel to access the sensor. or you can unscrew it from the inside and pull it out enough to unclip the harness and install the new one. if it is connected to the thermostat ( temp switch ) you have to remove the switch and install the new one and route the sensor the way the old one is routed which might involve doing one of the above options and removing the face plate the switch is connected to
Sep 17, 2009 | Ovens
Ovens Logo
81 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
