Question about Virgin Mobile - Lg Optimus Elite Mobile Phone - Black
Lg optimus elite turns itself off and will not turn back on until battery is removed and reinserted
My phone turns itself of at least once every power cycle when battery is still charged well. It won't turn back on until I remove the battery and put it back in. It's done it since I bought the phone. I did a factory reset to see if it would help but it still has the same issue.
  • craig_hundle
    craig_hundle Jan 22, 2013
    Don't know what to add. LG warranty service line couldn't help either. I guess it's a conundrum.
4 Suggested Answers
mobil master
  • 14641 Answers
SOURCE: virgin mobile venture won't start
.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Posted on Aug 10, 2012
Take the battery out. Then put it back in. I couldn't find anything that would work but doing a hard reset. Once I did that the phone worked again. I lost everything but my phone works again.
To hard reset the Virgin Venture please follow the instructions below:
Start with the phone turned off.
  1. Press power button until the phone turns on and vibrates.
  2. Press and hold the up volume button until you see the word hello.
  3. Release the up volume button.
    Note
    : You will see the word hello on the screen for about 5-7 seconds.
  4. The screen will display the android guy next to an exclamation point inside a triangle.
  5. Press the home button to access Android system recovery screen.
  6. Scroll to and select wipe data/factory reset.
    Note
    : The volume button scrolls and the enter/return key selects
  7. Scroll to and select Yes.
  8. The Venture will reset.
  9. Select reboot system now.
The Venture will reboot to the initial setup screen
Posted on Apr 04, 2013
  • 23 Answers
SOURCE: why won't my phone charge up
it is yr port take it in get it looked at.
Posted on Jul 15, 2013
My lg Optimus f3 phone wont turn on do you have any solutions
Replace the battery and recharge the phone.
Apr 13, 2015 | LG Cell Phones
Why won't my phone charge up
Jul 15, 2013 | Virgin Mobile - Lg Optimus Elite Mobile...
My lg optimus elite keeps turning on and off how do i fix it
First, make sure if this problem appear after you install any APP, if so you can try to brush system to fix it.
Else maybe the following cases:
1, mobile phone motherboard leakage lead the current too large.
2, The inside circuit protection of the lithium battery is too sensitive, so it power off when circuit is large.
3, the battery itself is aging.
4, Battery contacts are dirt-bit, causing bad power supply.
5, The engagement between the battery and the phone is easy to loose bits.
Of course, don't forget to see if the power button is back to its own place
May 06, 2013 | Virgin Mobile - Lg Optimus Elite Mobile...
Virgin mobile optimus v frozen screen
The first thing to Try is Remove the battery from the phone and wait 30 seconds, then, with the battery still out, plug it into your wall charger, then place the battery back in and turn the phone back on.
Aug 18, 2012 | LG Optimus V
How do i hard reset my metro pcs lg android phone
Try this:
  1. Turn the power off. If your LG Optimus M is frozen, pull the battery out and reinsert it
  2. Hold the Home and Volume Down button
  3. Press and hold the Power button until the device turns on
  4. Follow the on-screen instructions to reset your device
All data including third-party applications will be deleted from the LG Optimus M. Once the wipe is complete, the phone will reboot to its factory fresh state.
Jun 19, 2012 | LG Optimus M Metro Pcs Android Phone Good...
I need help , lg phone keeps saying force close on androd.mms and doesnt let me do anything cause it keeps popping up everytime i close it, what can i do??
I suggest power cycling your phone. You can do this by turning off your phone, removing the battery, taking the SIM card out, placing the SIM card back in the holder, returning the battery (making sure the contacts are in the correct place) and turn the phone back on. Once you complete the power cycle if it doesn't work you can complete a hard reset. Here are the steps here for the hard reset. Please be advised you will lose ALL saved data on the phone so it is Highly suggested to back it all up.
http://mistermobiless.blogspot.com/2010/12/lg-optimus-one-p500-hard-reset.html
Aug 26, 2011 | LG P500 Cell Phone
My son put a password on his lg optimus sprint phone and can't remember it, is there a way to find it out without doing a hard reset?
You can try this it might work for you
  1. Turn the power off. If your LG Optimus T is frozen, pull the battery out and reinsert it
    All data including third-party applications will be deleted from the LG Optimus T. Once the wipe is complete, the phone will reboot to its factory fresh state.
    Jun 22, 2011 | LG Cell Phones
    I have a LG Chocolate phone and the screen froze after I canceled a picture message. The phone will not turn off or on.
    Seems as though you have overloaded the phone and it has frozen, shouldn't be any permanent damge, just take out and reinsert the battery after 10 seconds.
    Hope this helps
    Steven Cumming
    Please leave positive feedback :-)
    Jun 05, 2011 | Cell Phones
    How do I reset my lg optimus
    See the instructions below how to factory reset your LG Optimus
    First, try this:
    1. From the main home screen, tap menu
    2. Tap Settings, then Privacy
    3. Tap Factory data reset
    4. Tap Reset phone
    5. Enter your password if required, then tap Erase everything to confirm
    If that doesn't work, or if your phone is frozen:
    Amardeep
    For More Tips, Visit My Blog @ http://thegeektweet.wordpress.com
    May 27, 2011 | LG Cell Phones
    I dropped my lg qwerty once and it would not turn back on everytime i tried to turn it back on
    Unfortunately there isn't much you can do to fix a cell phone that has been dropped. Try getting it exchanged with your insurance.
    Feb 28, 2011 | Cell Phones
    Virgin Mobile - Lg Optimus Elite Mobile Phone - Black Logo
    495 people viewed this question
    Top Virgin Cell Phones Experts
    Lee Wilkin
    Dennis
    jeff5may32
    Are you a Virgin Cell Phone Expert? Answer questions, earn points and help others
