Question about Williams 2509612 Ceramic Mid-Size Heater
Heater on,off,on,off,on,off....... I have Williams Gas heater in my apt. The pilot stays on all the time, but after a while the heater goes nuts by going on and off repeatedly every few seconds. I can hear the gas igniting, and after a few seconds, it shuts off again. It goes on until I change the thermostat really low or really high. I think it has problems staying "just right" temperature.
  • shihs Feb 11, 2009
    It was indeed the thermostat. Thanks!
  • Williams Master
  • 8,220 Answers
That is a bad wall thermostat.
Posted on Feb 09, 2009
  • Dan Webster
    Dan Webster Feb 09, 2009
    Remove the wires from the thermostat.thermostat. If the problem persists then the thermotat wire might be shorted. more
Where is the orifice on a williams wall gas heater 290622
Where the pilot is unscrew pilot tube from pilot assembly and inside there it is
Feb 26, 2013 | Williams (5009622) Ceramic Gas Wall...
I have a Kirkland patio heater model # PTH-106SS-3G the pilot will not stay lit. Do I need to replace the whole pilot assembly
Hi, If the pilot light goes out when you turn the gas knob to full power on lighting them the most likely cause will be a worn thermocouple, these usually last between 2 years up to 6 years. Found this site very helpful, patio heater problem solving. They have a few solutions to checking patio heaters.
Oct 12, 2011 | Williams 2509612 Ceramic Mid-Size Heater
We just purchased a Williams 1403622 natural gas heater and installed it yesterday. However, the pilot light WILL NOT light. Can you help?
If you mean that the pilot light does not stay lit, you could have a bad thermocouple or a loose connection at the gas valve. Make sure the flame is against the thermocouple. If you mean that the pilot won't light at all, bleed out the gas line a bit more.
Mar 07, 2011 | Williams 1403622 Gas Compact Heater
Pilot don't stay lit after the gas control knob is release.
The thermocouple is bad and you will have to replace it...
The thermocouple is the thing that sticks up in the flame to sense that the flame is on... if it goes bad the pilot flame will not stay lit when you release the button...
heatman101
Dec 05, 2010 | Williams 3501922 (NG) Gas Compact Heater
I have Wiiliams direct vent wall furnace. I smell gas only when pilot is on and burner is not on. It does not smell when it is fully running (burner is on)
Dear Alex191: I am shocked and amazed that the Williams heater company is STILL knowingly and willingly selling faulty direct vent gas heaters. My problems took place in 1988! I bought a 30,000 BTU Williams DIRECT VENT from The Home Depot. I took the time to remove window sashes and run gas line to the Williams heater that I had placed in the window aperture. I was glad to finally have heat and be able to heat the area of the house where I stayed. Then I began to smell gas when the Williams was OFF. I traced it to the area where the pilot light gas tubing entered the combustion chamber. I removed the Williams unit and replaced it with an identical make and model and the SAME THING HAPPENED!!! I sat on my bed and almost cried. I had the gas company come out and they labled the problem as a "fuzz leak". The warranty repairman came out and had no idea what to do. Tightening the retaining nut did nothing. I called Williams and even back then they said that they were aware of the problem. They called me back and wanted to send me a part and asked me, "Can you work on it?" I returned the Williams and bought a Perfection-Schwank CONSOL heater that burns the air in the room and vents horizontally to a 4 inch vertical gas vent and was very satisfied with it. When they went out of business I bought an "Empire" brand gas heater. I don't know if I'll ever buy another direct vent heater from anyone. I will be glad to write an affidavit should you decide to suit the Williams company.
Feb 20, 2010 | Williams 1403622 Gas Compact Heater
The heater will not stay lit.
i have to start my heater manually. whats bi start it the controller works its when the heater hits its tempature it will turn off thats good, but when i re-start it with the control it wont start. i have to do it manually remove the cover on the heater and push a buttom on top. the pilot is always on?
Jan 31, 2009 | Williams 1403622 Gas Compact Heater
Pilot wont' stay lit
try clean pilot ..... replace thermocouple on heater
Nov 10, 2008 | Williams 1403622 Gas Compact Heater
Pilot will not light
The Pilot indicator will appear to line up with the arrow on the base, and even push in as though allowing gas to flow, but if it is just 1mm out of alignment, no gas will flow. So the solution is to move the valve in the Pilot mode slightly in one direction or the other to see if/when gas flows.
Nov 06, 2008 | Williams 1403622 Gas Compact Heater
Williams wall heater
i'm having the same problems.......................
Oct 21, 2008 | Williams 2509612 Ceramic Mid-Size Heater
Williams 2509612 Ceramic Mid-Size Heater Logo
182 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
