I NEED TO CHANGE LIGHT BULB IN MY GE MICROWAVE BROWNER OVEN BUT CANNOT FIND AN OPENING TO DO IT?
SOURCE: GE Spacemaker Microwave
On these models, the oven must be pulled from the wall mount, then the outer cover must be removed. This is apparently to limit the manufacturer's liability. Removing the microwave from the wall is really a two-person job, since it is heavy and awkward. You don't want it to fall or slip, and the edges can be sharp. It helps a lot if you saved the original installation instructions. Once the oven is out of the wall, you can then access the lamp socket. These bulbs are special halogen types that must not be touched by bare hands, since skin oils will shorten their life. You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
SOURCE: GE MICROWAVE
Dear Carluc
Right for this one, it is essential that you unplug the oven from the mains and leave it to dissipate any electrical current certainly for 6 hours. Once you have done this, you wil to get yourself a phillips head 6mm screwdiver and unfasten the screws on the back that hold the casing cover to the chassis. This will expose the enternal components, then all you simply need to do, is find the lightbulb, unclip this from the holder and then replace it with one of the same make and model. Fitting and re-assembly is as straightforward as it is taking the unit to bits.
go to http://www.google.com and type in GE Microwave lightbulb........this will get you the details about the bulb, and use the same google search to get your service sheet/ disassembly guide. Easy as 1,2,3.
Hope this works for you and please contact me here if you need further assistance in this or any other matter that is of a technical nature.
Yours sincerely
Oz
SOURCE: Changing light bulb in microwave oven
If
there's no obvious removable cover over the bulb (and the owner's
manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
The
screws you need to remove should be pretty obvious, but a special
driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
SOURCE: ge microwave oven jes1288 light bulb replacement
The light bulb assembly (bulb and socket are all one piece) is part number WB36X951.
It is located on the air duct assembly where the door switches are mounted.
You can see an exploded view diagram here.
You'll need to remove the outer cover (wrapper) to get to the bulb assembly.
Always unplug a
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The
screws.
If you're not able to find the bulb assembly at your local appliance parts store, you can order one here.
We're
SOURCE: Light bulb in oven went out
Remove the top grill by removing two screws in the top. Pull the top of the grill out towards you as the bottom has pegs on it. About 6 inches from the left is metal cover that you just squeeze with your finger tips to remove. This exposes the bulb.
