Question about Microsoft SHAREPOINTSTDCAL OLV 1Y STUDNT DVCCA
Englis gramr gramr and englis
  • Microsoft Master
  • 2,878 Answers
English grammar.
Posted on Jan 17, 2013
How can I be sure if my PCM is bad???
I would try disconnecting battery again. Disconnect both cables and touch them together for a few seconds. This will reset all modules. Wierd that you had so many codes after just disconnecting battery. Sometimes very hard to tell if ecm is bad.
Dec 01, 2014 | 2006 Pontiac Torrent
What is the transmission capacity of a 85 Toyota Corolla?
Automatic Transmission Fluid - Volume: 2.50QTS. ( 2.4L ) - [Automatic Transmission Fluid DEXRON II] - 1.6L Eng & 1.8L Eng
Manual Transmission Fluid - Volume: 1.80QTS. ( 1.7L ) - [API - GL-4 or GL-5 SAE 75W-90 or 80W-90] - 1.6L Eng & 1.8L Eng
Feb 08, 2011 | 1985 Toyota Corolla 2 Door
What is the fluid capacity for a 1986 monte carlo ss
Engine Coolant - Volume: 12.00QTS. ( 11.4L ) - [50/50 mixture of Ethylene Glycol Base Antifreeze and water] - 4.3L Eng - [GM Specification 1825-M.]
Engine Coolant - Volume: 16.30QTS. ( 15.4L ) - [50/50 mixture of Ethylene Glycol Base Antifreeze and water] - 5.0L Eng - [GM Specification 1825-M.]
Engine Oil - Volume: 4.00QTS. ( 3.8L ) - [SAE 5W-30 (Preferred) (Below -20Deg.F to Above 100Deg.F), 10W-30 (0Deg.F to Above 100Deg.F), 30 (40Deg.F to Above 100Deg.F)] - 4.3L Eng
Engine Oil - Volume: 4.00QTS. ( 3.8L ) - [SAE 5W-30 (Preferred) (Below -20Deg.F to Above 100Deg.F), 10W-30 (0Deg.F to Above 100Deg.F), 30 (40Deg.F to Above 100Deg.F)] - 5.0L Eng
Fuel Tank - Volume: 17.60GALS. ( 66.6L ) - 4.3L Eng
Fuel Tank - Volume: 18.10GALS. ( 68.5L ) - 5.0L Eng
Feb 07, 2011 | 1986 Chevrolet Monte Carlo
Can you swap a 5.7 liter hemi into a 94 camaro?
measure the eng compartment,if eng is smaller it may go in then eng mountings,will they line up will propshaft fit eng,,these things you take into account if its worth doing
Jul 07, 2010 | 1994 Chevrolet Camaro
How do you remove starter?
disconnect neg batt cable. as required remove nuts from a/c compressor and eng brace, adjacent to starter, if neessary. remove nut from eng cross brace. using a pry bar between upper eng mount and eng pry rerward and support eng.if nessary remove oil filter, air induction tube and cooling fan. Disconnect wiring at starter, and (note!!!!)position. good luck
Jun 25, 2009 | 1993 Chevrolet Lumina APV
1992 EX Check Eng. light comes on Eng. quits
When your engine not starting or quits while you driving check to see any sparks, or remove the distributor and let the auto part test it. if it no sparks or the auto part say is bad , replace it.
Mar 29, 2009 | 1992 Honda Accord
Microsoft SHAREPOINTSTDCAL OLV 1Y STUDNT DVCCA Logo
53 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
