Question about NEC Ux5000 24-button Telephone Set ip3na-24txh
Nec ux5000 phone wont ring
Red light tells me of incoming call, volume is up, but no sound. Intercome volume works.
  • 201 Answers
SOURCE: Blinking light but no ring sound on incoming calls
This is a phone system phone and each station you want to ring when a certain phone line rings has to be programmed into the system. This is not something you can change at the phone itself. You will either need to pay a company to make programming changes or locate a programming and installation manual for your phone system (not the phone) and try to re-program it yourself. If you have not done this before it will not be easy but it may be worth the effort so you can continue to make your own changes instead of paying someone $200 per hour to do it for you.
There is also the remote possibility your phone's ringer is broken. You can try swapping your phone with another of the same type and model to see if it will ring.
Posted on Oct 18, 2007
  • 10 Answers
SOURCE: nec dterm wont ring in
During an incoming call try holding the up arrow on the volume key. That is the only way I know to increase or decrease the volume of the ring. The phone might also be set on DND. in which case you have to Press feature dial the DND cancel code 69 press feature. If note look for you user guide here. http://www.neccare.com/cng/docs.nsf/Lib3?OpenView&Start=1&Count=100&Expand=6.13#6.13
Posted on Nov 04, 2008
  • 149 Answers
SOURCE: when a call comes in the ringer doesn"t ring
you need to have the phone programmed to ring. ldtsnj.com can help
Posted on Jan 02, 2009
  • 16 Answers
SOURCE: I have a NEC ETW 16DC-2 phone that does not ring with calls
The telephone instrument you have can be used on the NEC Electra Professional Level I, and the Level II systems (and under some conditions the NEAX 2000 series). Codes for features are somewhat different based on the system. It is possible that your phone is in "Do-Not-Disturb" if other phones on your system actually ring when they are called via the intercom (on the Level I and Level II systems, initial intercom ring is a system wide setting). The cancel DND code is: Level I system: with telephone idle, press <FNC>, dial 60, press <FNC>. Level II system: with telephone idle, press <FNC>, dial 69, press <FNC>.
It is also possible that your ring volume is very low. To adjust, press <SPKR>, dial 601, then adjust volume using the up/down keys at the bottom of the phone (press <SPKR> when finished. If your system is programmed to access an outside line when you press <SPKR>, you will need to press the <INTERCOM> button first.)
If your system is set for voice intercom, people calling your phone can make it ring by dialing a "1" after your intercom number.
If you do all this and your phone still won't ring on incoming calls, let me know and we'll have to go into system programming to correct it.
Posted on Jan 12, 2009
SOURCE: Make All phones ring when there is an incoming call
I have a DtermSeries E and the second line blinks but does not rings.
Posted on Aug 03, 2009
Main phone for office is not ringing, console will not ring. Just blinks. If portable phone is detached, portable phone will ring. But when connected to console there is no ringing.
if the phone was programmed to ring originally on the system try pressing the volume up key a few times while you know there is an incoming call on that phone
Oct 14, 2014 | NEC Lands Phones
Incoming ring
Make sure the ringer is turned on on the extension. There should be a small switch either on the handset or the base that controls it. Also in the menu there could be a setting for the volume that needs to be set.
Apr 11, 2014 | NEC Lands Phones
All extensions ring on oncoming call on NEC Dterm series i
.. I don't have a solution, I need a solution.
NEC Dterm Series I, through internal calls my phone flashes notifying me that I have a call coming through but it doesnt ring. I have tried the volume key ^, that didn't work. Can anyone help me?
Aug 27, 2012 | NEC Dterm DTP-2DT-1 Phone
Incoming ring volume
It has been my experience with these office phones, that you need to change the volume while somone is calling or while the phone is ringing. Try that, have someone buzz the phone, then while it is ringing, click the volume button up or down.
Sep 10, 2009 | NEC Dterm DTP 16D-1 Corded Phone
Toshiba DKT2010-SD won't ring
ask the provider to program the ringging assignment. It wont ring couse dint assign a ringging assignment.
Feb 13, 2009 | Toshiba DKT-2010 Corded Phone
Intercome ringing
It sounds like the HFAI button on most of the sets is turned off. the HFAI (hands free answer intercom) button is located to the right of the SPKR key. With the handset down press the HFAI button. The green light next to it should light indicating that it is active. If the power goes out or if the phone is unplugged it will return to HFAI off status. hope that helps.
Feb 06, 2009 | AT&T Lucent MLS-12D Phone
Nec dterm wont ring in
Aug 21, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
When a call comes in the ringer doesn"t ring
Jun 16, 2008 | NEC DTU 8D-2 Corded Phone
Oct 17, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
NEC Ux5000 24-button Telephone Set ip3na-24txh Logo
242 people viewed this question
Top NEC Radio Communications Experts
David Payne
David Payne
Mister Danger
Are you a NEC Radio Communication Expert? Answer questions, earn points and help others
