Panel heater is getting red hot but it doesn't heat the room at all. Please help
This could be an air flow problem. If it isn't in a position where air can freely pass over the heater, the heat will not be felt within the room. Place a fan on low or medium speed near it just so see if that might help.
Posted on Jan 16, 2013
    Genius:
  • 1,669 Answers
Without a manufacturer or a model it will be difficult to help you. THe only thing I can see is that it has no fan to transfer the heat into the room. Did it have one when you bought it?
How many square feet will it heat
Hi there, it's Jack at Dyson.
The Dyson AM05 Hot + Cool heater is suitable for small, medium and large rooms of up to 30 square feet. Dyson Air Multiplier technology draws in and amplifies ambient air to projects the heat further, warming the whole room quickly and evenly. And in the summer, it cools you with uninterrupted high velocity airflow.
I hope this answers your question, but if you'd like further information please visit http://www.dyson.com or give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Feb 18, 2015 | Dyson Inc Am05 Hot Cool Fan Heater -...
Beko sensordry 6kg gets hot on sensordry programs but won,t get hot on timed programs and keeps stopping and starting, any ideas please?
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!!
Feb 13, 2015 | Dryers
Not sure if a blower is in this model because feel no air comeing from unit
The blower is/was a $69.00 optional add on feature for that heater. To be quite honest, a blower does little on an Infrared Heater. Infrared, unlike Blue Flame Convection Heaters, doesn't waste energy heating the air. It heats objects (floor, walls, furniture, etc). From that the room air heats up. Simply put, it heats a room like the sun heats the earth. It's really more efficient than a gas convection heater. Rated 99.9% efficient at 15,000 Btu's, it will heat a good sized room easily.
I've selling these heaters for several years and I always try to talk the customer out f wasting their money on a blower. It's simply not needed on an infrared heater.
I hope this helped you and thanks for choosing FixYa.
Aug 20, 2011 | Empire ECS HearthRite HR25EL Heater
The top grill on my Vulcan wall heater gets very hot is this normal please let me know thank you
this is normal as the wall unit heats and hot air is blowen into the room the grills will get hot
Jun 11, 2011 | Heating & Cooling
I have an Optimus H-5210 Infra-Red Heater and it's working great but last night while i slept, the pillow felt on top of it, burned a hole and i couldn't get the heater to turn back on. Is there a reset...
god please be carfull thousands of home fires start like this!!!!!!!
My guess is that a high temp cutout has opened. most likly it is not replacable.
Google search your model number / owners manual to see if there is resettable overtemp.
I was unable to locate but you may have more luck.
Remember infra-red heat warms items and objects in the room by absorbtion of infra-red waves this heater should not be near any flameable items! its designed to sit like 6 feet away from any thing and items in the room absorb heat energy then give it up to there surrounings.
please be carefull....
Mar 10, 2011 | Optimus H-5210 Infra-Red Heater
TOO HOT
not sure how you system is set up but it almost sounds like you have a maintain system or a stuck thermostat to stop the heat if you dont make hot water with this boiler turn off the switch on boiler till you can get service person in if you can tell me more about the way your system is set up i could help more.if you want to see if its a problem with thermostat pull red wire from subbase
May 02, 2009 | Honeywell Electronic Programmable...
I am needing an instruction manual for rinnai energysaver 556/FTR as have purchased and moved into property recently and am having trouble operating the heater and am concerned with a red filter light that...
www.rinnai.co.nz
navigate to tradesmart, space heating, energysavers.
Red filter light means the filter is blocked.
its located directly on the back of the heater and the wall spacer, from the control panel, its about 4 inches back.
Pull it up, clean reinstall
Apr 27, 2009 | Heating & Cooling
How to hard wire 240 volt wall heater
Black is 120v hot
Red is 120v hot
Black and Red go to opposite legs to get 240v between them.
White is 0v neutral
copper is Ground
Dec 27, 2008 | Fahrenheat (FFH1614) Wall Mounted Panel...
Siemens central heating control
I have a Siemens "Radio" Room Stat - the receiver has switched itself off. How do I restart it. I have pressed the restart button and the reset - nothing happens except for red light flashing and then off. I do not have the instructions. Where might I get them?
J W-K
Oct 18, 2008 | Water Heaters
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
