Question about Sanyo DP50747 50 in. Plasma TV
How to fix the colors in my Sanyo HDTV, they are faded and yellowish
2 Suggested Answers
  • 11 Answers
SOURCE: Green Screen on an HDTV
I too had the same problem where my HT30744 TV would lose its color. My mom's HT32744 would have the same problem too. They both are refurbished models bought at Value City Dept store. If I gave the cabinet a good hit it would mostly fix the color, but it could also make the picture go fuzzy too, a clear sign of just a loose connection somewhere.
So after my wife telling me she was sick of this almost 2 year problem and she was going to buy a new TV on the weekend, I figured I had nothing to lose. So I took the rear cabinet off, unseated the card mounted on the picture tube, applied a little dielectric grease on the connector on the card and reseated the card, removed, re-greased and reattached the card. I have had no problem with either my or mom's which I did the same to since! This is an easy fix that anyone can do. The hardest part is moving the TV and reassembling the rear cabinet. Do not pull the cabinet back out more than you have to, to ease the reassembly of it.
Posted on Mar 05, 2010
Sanyo hd flat screen tv loosing color can it be repaired
It should be replaced with a new one. Normally these type of faults are irreparable.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Screen faults & possible causes to LCD screen are given with illustrations.
Jul 29, 2014 | Sanyo Televison & Video
Sanyo dp42849 picture is slow
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 22, 2017 | Sanyo DP42849 42 in. HDTV
Picture is yellowish greenish and I have new bulb in my set. I can't adjust the color to fix the problem.
Sorry, you have a defective optical block (projector)...The only way to fix this issue is replacing the optical block and is very expensive...
Aug 23, 2011 | Sony KDS-50A2000 50" HDTV
I have this blob discoloration that is in the center of my screen. what could this be its a yellowish green color
Yellowish green colour is usually caused by a burnt blue LCD Panel or the light engine requires servicing.
Jan 15, 2011 | Zenith E44W46LCD 44" Rear Projection...
Picture is starting to get greenish, yellowish colored
hitachi model 51f510 projection tv has horizontal lines & has greenish tint,do i need to chang the bulbs??i alredy tryd the magic focus button & manual focus,but unsuccesfl,any ideas????
Nov 27, 2009 | Hitachi 51F510 51" Rear Projection...
Large fish eyed picture
TRY NEW CONNECTIONS AND JACKS ,,ALSO IN THE MENU GO TO COLOR CONVERSION AND USE IT
Apr 19, 2009 | Panasonic PT-52LCX65 44" HDTV
Rear Projection TV -- Bright spot with yellow edges on TV screen
if it is a panasonic pt-50lc14 then you will need a new bulb. you can find them online, do a yahoo or nextag search for the ty-la 1000 bulb and you can find them for around $100...
Mar 11, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Sanyo 5.0 megpi( yellow tint)
yellowish color is due to the light your flash gives when taking pictures. i suggest you bring that to a service center and let them take a look at your camera...probably needs a bulb replacement.
Jan 26, 2008 | Sanyo Xacti DSC-S4 / VPC-S4 Digital Camera
Bottom of projection tube is another color
Yes, worth fixing, sounds like convergence is out on the tip ends. Check papers for Convergence controls. See if have auto fix.
Aug 12, 2007 | Philips 60PP9202 60" Rear Projection...
Sanyo DP50747 50 in. Plasma TV Logo
61 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
