Question about Cell Phones
Htc water damaged
My girl put my jeans in full cycle in the washing machine with my htc phone inside. It is now completely dead. Does anyone know where to fix it? Thanks
  • 983 Answers
Remove the battery and take an hair drier and dry it completely and then switch it on . if possible you remove the panel and dry it so that all the water particles inside will get dry .
if you have tried it switching on before drying it then some short circuit will occur and it will no switch on if so you must contact the mobile technician or if you have warranty you can make use of it.
Regards
-Dileep
Posted on Jan 24, 2009
What is the best settings to wash jeans on.
While hand washing and line drying is safest, it's also costly in terms of time and effort. Unless your jeans are particularly dirty, it's best to wash them in cold water, select one of the gentler cycles, and dry them at a low temperature. Special detergents formulated to preserve dark colors really do work.
What temperature do you wash jeans? When to Use Warm Water - For man-made fibers, knits and jeans, use warm water (90°F). Most of your clothes can be washed in warm water. It offers good cleaning without significant fading or shrinking. When to Use Cold Water - For dark, bright colors that bleed or delicate fabrics, use cold water (80°F).
Wash your jeans in the sink or a tub.
  1. Fill a tub with a few inches of cold or lukewarm water. Mix in a gentle, color preserving detergent.
  2. Turn the jeans inside out, then lay flat in the tub. Don't bunch them or wrinkle them. Let them soak for about 45 minutes.
  3. Run them under the water to rinse. Hang up to dry.
  4. Can you put jeans in a tumble dryer?
    According to Good Housekeeping "All fabrics and especially jeans benefit when youtake them out of the dryer slightly damp. ... If, even after tumbling on low heat and a delicate cycle, you see lots of lint on the dryer's filter, you may want to switch to linedrying your jeans to help preserve the fabric.
    hope this helps you out.
Oct 28, 2017 | Washing Machines
Washing machine won't spin
It sometime appens that the program was not finished let it do a full program with nothing in it
Jan 26, 2018 | Washing Machines
My washing machine (HAUS WM1050 is full of water, it won't empty whatever cycle i put it on. How can i fix this??
Hi, i have a Haus WM1050s which is also full of water and will not drain. There is a cover at the front with NO filter behind it, just a large plastic screw (unsure what). I suspect the filter is blocked, does anyone know where it is before i pull the machine out please.
Thanks in advance
Alison :-)
Feb 10, 2011 | Washing Machines
I replaced the base assembly and completely level the machine and it still is unbalanced at the 11 mi. mark.
Is your washer a front loader because if it is then one possible solution is by putting less close. I have a front loader and when I put 8 blue jeans along with some other close. The spin cycle is violent and by removing 4 jeans, the cycle spins better and it end up balancing its self. Usually jeans soak up a lot of water, so try to put in lee close and less heavy close.
If this does not help then you might have a problem with the damper shocks (leaking) or springs (broken) if it a front loader washer.
Jan 11, 2011 | Washing Machines
Dishwasher not completing full cycle
Hi i too have the same problem matrix mx194 approx 4 yrs old.On near completion of cycle the 3 center lights out of the 4 on the inside of door flash and a ringing tone indicating a fault. When the door is open there is approx 1'' of water in base of machine and the inside is extremely hot and full of steam.
Can anyone please help
Nov 21, 2009 | Dishwashers
Rid of Mildew Smell?
Make sure there are no leaks from the machine. look behind it and check the water inlet hose and connectors for any damage. Also look under the machine for any water as this may indicate a leak from the internal hose and pipe work and / or water pump. Also check that the outlet hose is completely clear of debris and soap scum build up and check that the filter is clean.
To keep the machine clean of waste build up and to keep any bad odours away
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
7. Repeat the cleaning procedure monthly
Aug 22, 2009 | Bosch Nexxt 500 Plus WFMC5301UC
I just had my washer-dryer repaired by CandyHoover. They replaced the tub and drum. I put it through the half hour cycle yesterday, then today I put a couple pairs of jeans in it on the 40C cotton
hi i had the same problem clean the door seal then use some disilled malt vinegar on a 90 wash then clean your filter out then use some bleach with your washing powder on 90 wash clean your filter then you should be all good then as that worked for me
May 23, 2009 | Candy CNW136 Front Load Washer/Dryer
Bleach and Fabric Dispenser not working
Got a Brand new LG ~ WT5001CW toploader today. I did 2 loads of wash. Theres a Bleach Dispenser on the top left side but I didn't use it. In the middle of my 2nd wash I noticed the bleach dispenser was full of water. I thought well maybe after the rinse and the spin it would take the water out. Well when the cycle was complete the Bleach Dispenser was still full of water.
I took the Bleach dispenser out and checked the holes to see if anything was plugged, didn't look like it. Was wondering if anyone knew how to solve this problem or do you think that since I took the bleach dispenser out and put it back it that it might work for my next load ??
Any opinions will be greatly appreciated !! Thanks Much !!
Apr 26, 2009 | LG Washing Machines
Door jammed
take the top off the machine,put your hand down to the reigon of the door lock and by using a small screw driver the catch on the door can be forced open without doing any damage.
Jul 24, 2006 | Indesit W 123 Front Load Washer
Cell Phones Logo
467 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
