Xerox memorywriter 6020's space bar sticks
Space bar sticks. Have to press really hard for it to move one space.
  • 3,594 Answers
Under each key there is a contact pad, they get old and the foam falls apart. They can be fairly easily replkaced the pads are 1.50 apiece.
Befor you do anything realize that the ribbons are no longer made.
DickyO
Posted on Jan 17, 2013
  • sengo939 Jan 18, 2013
    Hi ****,
    As you probably guessed, I'm trying to get one of the old typewriters at work to work for me (I asked the question for the IBM wheelwriter). I would replace the pad for the space bar, but I cannot lift the space bar out. Any suggestions? As to the ribbons, we have plenty of them from the days when everyone used a typewriter instead of computer keyboards. Thanks for your help.
  • 3594 Answers
SOURCE: space bar
If the bar works when you hit right in the middle try reinstalling the bar the metal rod must go under the tabs on the keyboard, if it won't at all you probably need a keyboard.
DickyO
Posted on Jun 02, 2008
  • 3594 Answers
SOURCE: space bar does not work??
If the space bar won't go down there may be some debris under it,
DickyO
Posted on Jan 02, 2009
  • 3594 Answers
SOURCE: Space bar acts as a return key
You probably need a keyboard, contact george beyers co. 1-800-392-8085.
DickyO
Posted on Jun 08, 2009
  • 3594 Answers
SOURCE: KEYS ARE STICKING ON MY XEROX MEMORYWRITER 6010
The Xerox keyboards can be rebuilt for about 100.00. Under each key is a foam pad that deterates over the years the must be removed and replaced. If you can get the keyboard to us we will do it for you.
DickyO
Cleveland Business Machines
216-241-0027
Posted on Aug 12, 2009
  • 3594 Answers
SOURCE: space bar key doesn't work
If the keys do nothing at all you probably need a keyboard, if they do something but not what you want try a little WD40 on the silver shaft that guides the carrier. If it's the KB contact Geo. Beyers Co.
1-800-392-8085
Posted on Aug 21, 2009
Carriage does not advance when pressing the space bar or pressing a key. Does advance when depressing tab.
If you press a key does it type or try to correct? The escapement mechanism that allows it to move from space to space may be sticking and causing your problem. That mechanism just may need a flushing and lubrication. You will see a shaft that runs through the carriage. Try to turn it top to rear until it stops. if you hear a click then it has been turned the right amount. If it doesn't turn, then it is as far as it goes. Try hitting the spacebar and see if the carriage moves. If it moves, hit any key and see if it moves. if it moves, hit another key. If it doesn't move then your escapement mechanism needs to either be flushed and lubed or adjusted.
Nov 20, 2015 | IBM Correcting Selectric II
Space bar on sylectric 2 ibm typewriter is not moving the type
There are a few things that can cause your spacebar to not move the carrier. Do you hear any sound when you press on the bar? There are adjustment that may need to be made to the machine or perhaps there is something sticking in the mechanism. Unfortunately you mey not be able to fix this yourself as these machines need a technician to properly repair and service the machine.
Feb 15, 2015 | IBM Correcting Selectric II
I cannot release de left margin on my Xerox Memorywriter 6010. I press de Mar Rel Key and don't have success. Please, Help
Have you tried oiling it w/3-n-1 oil? Often the sticking problem is nothing more than it needs lubrication.
Feb 11, 2015 | Xerox 6010 Memorywriter Electric...
Space bar will not work.
It's probably just dirty and gunked up. Clean it with Q-tips and a bit of rubbing alcohol.
Nov 19, 2014 | Xerox Memorywriter 60 Series - Correctable...
Space bar keeps going but not pressed
might be dirty, get a can of air, from like home depot, office max, etc. turn off laptop, take out battery, turn upside down and blow the air underneath the spacebar, this should fix your problem. If not you need a new space bar.
Chad
Apr 12, 2013 | Toshiba Satellite Computers & Internet
How can I release margins on my XEROX memorywriter 6010
Get to the margin you wish to change Hold the code key, the key with the green oval and press thr top L. key that says mar rel in green, space or backspace to desired position press R. or L margin key depending on which one you are resetting.
DickyO
Apr 07, 2010 | Office Equipment & Supplies
My key board fell off and the space bar came off Itried puttingit back but it doesnt work
You can easily fix your space bar. I fixed mine last month when my daughter pulled it out of the keyboard. I used this video tutorial guide to help install the space bar key back into place. Its really very simple. have a look:
http://www.laptopkey.com/installation_guides.php
Oct 10, 2009 | Dell 0Y3740 Keyboard
DickyO
216-241-0027
Aug 12, 2009 | Office Equipment & Supplies
Space bar sticking on Saitek lighted keyboard
For me, I popped of the space bar, cleaned the junk underneath and fidgeted with the plastic push-button and all was better. Thanks for the suggestion!
Feb 21, 2008 | Saitek Eclipse II
131 people viewed this question
jasbo
jasbo
