Question about Acer Iconia Tab A200 Series Tablet with 16GB Memory - Metallic Red A200-10R16U
Solution for authentication problem on my acer iconia 200
Try to go on line through virgin media get excellent signal when i try authenticate it says authentication problem
2 Suggested Answers
aldanenewlan
  • 30 Answers
SOURCE: Tablet recognizes signal f rom Verizon Jetpack but will not connect - shows message: "authentication problem""
Authentication problem MEANS THAT THEIR MY BE A WRONG PASSWORD
Posted on Dec 21, 2013
MY POLOROID TABLET WILL NOT STAY CONNECTED TO INTERNET. SAYS AUTHENTICATION PROBLEMS
Android tablet wifi authentication problem [Solved ...
www.tomshardware.com/.../43704-43-android-ta...
Tom's Hardware Guide
Nov 23, 2012 - 20 posts - ‎9 authors
Hello, every wireless device works except my new tablet from Acer running Android 4.1.1. ... Yes, I try to connect to the network router. ... You can hide the SSID - once your Android has it as a saved network it will ... gefraenk said: ... Hello all, I have the same authentication problem, worse, I m not sure what ...
Authentication Problem to Connect Android Tablet - YouTube
? 3:05
https://www.youtube.com/watch?v=2wul81jM7Ts
Apr 2, 2013 - Uploaded by Meroy Diniz
If you have Authentication Problem connecting you androidtablet. ... i got a different problem i cant even turn the wifi on, on my hudl 2 it blocked ...
Dec 25, 2015 | Tablets & eReaders
Why won't my tablet connect to the internet?
Authentication errors happen when the tablet does not have the correct credentials to log onto the network. Be sure you have the correct SSID and password to join your local network. You can check this in Settings.
Apr 14, 2015 | Tablets & eReaders
I have a Dragon Touch tablet. won't connect to wifi after WEP is entered and accepted/saved.
Are you still using WEP security? Most devices today no longer use WEP as it is inadequate for serious security. Most devices today are using WPA2 security. If you are no using the proper security you will get an authentication error even if the password is correct.
Dec 25, 2014 | Dragon Touch Tablets & eReaders
Trouble with authentication
Authentication means the password is wrong.
May 07, 2014 | Acer Iconia A3-A10 10.1" Android Tablet -...
Tablet will not connect to inernet
did you add the tablet in the router admin panel?
Apr 29, 2014 | Acer Iconia A1-810
trying dumbing down the authentication on your wifi router. Try these:
turn off 40mhz wide channels
try wpa instead of wpa2
try tkip instead of aes
if all else fails, try wep.
Feb 11, 2014 | Craig CMP741d Tablet
Authentication Problems
wrong settings entered on tablet, try again.If possible connect tablet first via usb cable to computer or router to try connecting it , to determine the actual fault on connections.
Dec 28, 2013 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
NEED SCREEN UNLOCK CODE FOR ACER ICONIA 200 TABLET
Well, the only way to unlock your tablet is to factory reset tablet.
To reset tablet start the tablet, then hold volume up then select factory reset.
Sep 15, 2013 | Acer Iconia Tab A200-10g16u XE.H8QPN.001...
Can not get to wifi
Wi-Fi technology enables wireless Internet and network access through public and private hot spots.
These hot spots are widely located in homes, restaurants, bookstores, coffee shops and other businesses, so you can keep connected wherever you may travel.
To connect to Wi-Fi, you must have an enabled wireless adapter on your computer.
Most modern laptops and many desktops have this adapter built into the system, but many lack such capabilities.
However, a wireless adapter is easily installed via USB, which allows you to connect to available networks through Windows 7.
Enable your wireless adapter. Most laptops have a hot key labeled with a radio antenna.
Hold the "Fn" key and press this key to toggle wireless on or off.
Desktops likely have a physical antenna on the back of your computer that is typically always on. If you don't see such a hot key or antenna, you need to acquire a USB wireless adapter.
Attach the USB wireless adapter to an available USB port on your computer.
Windows 7 will automatically install the necessary drivers for most adapters.
If it does not, insert the CD that came with the USB wireless adapter into your drive and choose to install their drivers.
Restart your computer if you do not see a wireless icon in your Windows 7 notification area.
Click the wireless icon in the Windows 7 notification area and click the network name to which you want to connect.
If this is your home network, the correct network will likely be the one with the strongest signal.
Click "Connect" and enter the wireless security passphrase, if required.
Only secured networks will ask for a passphrase, but some public networks will require browser authentication instead.
Open your browser and navigate to any website.
If the hot spot requires browser authentication, your website request is redirected to an information page.
Follow the instructions on this page to get Wi-Fi.
This may entail clicking "Accept," entering a given password or entering a cell phone number.
After authentication, attempt your website again to verify accessibility.
Hope this helps
Oct 29, 2012 | Acer Iconia Tab A200
Acer Iconia Tab A200 Series Tablet with 16GB Memory - Metallic Red A200-10R16U Logo
50 people viewed this question
Top Acer Tablets & eReaders Experts
Lawrence Oravetz
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
