Question about Philips 60PP9352 60" Rear Projection Television
SDM message and Philips TV goes off and on
TV randomly shuts off and then on again with a SDM message on the top R corner. When TV comes on again message 'channel not available' and it has disconnect from satilite. I reset connection and it works fine for a while. Then repeats. What is wrong and how do I fix it?
  • Judy Jan 17, 2013
    I've replaced lamp and set TV to factory settings. What is a SSB board and how much about? Maybe better buying new TV?
  • Judy Jan 19, 2013
    I replaced the bulb, put TV back to factory setting, reset bulb life to A (it was on F), and problem still persists. How difficult is it to replace SSB Board? Do I need a professional? Or should I buy new 60" TV @ Costco for 1K?
    Genius:
  • 1,140 Answers
It may be that the dish alignment needs resetting or the lnb is going bad
Posted on Feb 15, 2018
SOURCE:
tvman
  • 4 Answers
SOURCE: Sound Goes Off and TV Comes On By Itself
You need to replace the SSB board
Posted on Jun 08, 2006
SOURCE: no picture no sound
I have the same problem so it would be helpful to know if you've resolved this issue....
Posted on Jan 05, 2008
  • 3 Answers
SOURCE: Philips FTR 9964 Receiver Problem
The problem is in your cable connection on the back of your monitor or Box. I had the same problem and solved it by reattaching the VGA cable that was loose.
Posted on Jul 19, 2008
SOURCE: My Philips Magnavox 50 inch projection tv picture
my philips projection tv model number 50pl9126d/37 has a dark screen
Posted on Sep 03, 2009
  • 11 Answers
SOURCE: 60" philips projection - no picture
check to see if your collor wheel is rotating and the buld didnt blow.
Power
Either a loose/bad power cable or the backlight is failing.
Jan 30, 2018 | Sony SDM-HS95 19" LCD Monitor
Power
Check for a loose power cord on the back of the monitor (quite common).
Jan 29, 2018 | Sony SDM-HS95 19" LCD Monitor
No picture no sound. Message on screen 'weak or no signal' The signal is strong. Also in top corner it says - A-----2 Auto panoramic
Reset the tV to its factory settings. Refer its user manual for details. If it do not help you, visit the site named 'Electro-help' for more details. You might ahve to enter its service mode option to reset it to its factory settings. Check this link and select the site. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy.
Aug 06, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I pushed the tv button on my remote and the tv went to a blue screen with channel not available in the top right corner. Now I cannot watch my satellite tv and I can't figure out how to get the...
Dear Sir:
Please change new batteries, and clean the contact of batteries.
2)next reset the remote control: go to the next web pages: www.fitness.manualsonline.com give your model and download for free.
3) You must reset your box tv satellite, and adjust according as the company as instructed. If you have any doubht call them for reset the box tv.
4) You must shure that you do not have any problem with your TV,because the amps for color can be faulty, and this another reason, and the TV remote control + box control TV.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Feb 20, 2012 | Philips Televison & Video
I have Aiwa TV MODEL No. TV-A219 The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control. Its
Hello
Check your remote control hanset for proper functioning. Get into this link to know more about the faults and repair to remote contorls.
http://www.fixya.com/support/r10192276-cleaning_remote_control_handsets
If remote control functions proeerly, the front panesl switches to be suspected. If any one mong the microswitches inside got strucked, all functions will be distrubed. it will be best to follow any more after replacing these microswitches. These switches can be located just behind the control panel of the tv, soldered diretly to a printed circuit board. You have to replace all of the at the same time. Just undolder one amoung them as as sample, when you go to buy for a new one.
If this also does not help you, repalce its memory IC. This IC can be located very near to the main system control IC, will have 8 solder terminals. A very small IC and wont cost more. Eventhough it is very small, function of it when the set works is great. Replace it. When you buy this IC, make a keen look on it number. It is very important when replacing this IC. All these components stated above, can be bought from most of the electronic spare part selling shops st your town. OK.
Feb 07, 2012 | Aiwa TV-S2011 20"
MY SONY 42'' JUST SHUTS OFF BY ITSELF.THE LAMP REPLACEMENT MESSAGE HAS BEEN SHOWING FOR SOME TIME.WE REPLACED IT WITH A BULB WHICH WASNT NEW & ITS STILL DOING THE SAME THING.
When it shuts off how many blinks of the red led on the front. This is an error code. What is the model number? It is common for sony sxrd projection tv set to shut off randomly when the lamp is bad. would try a new lamp.
Jun 07, 2011 | Televison & Video
Have Aiwa TV MODEL No. TV-A209 The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control. Its stuck...
have Aiwa TV MODEL No. TV-A209
Its stuck randomly on a particular channel that I was watching at that point of time.
Along with that channel it now shows a message in flashing red color that reads :-
AGING
O6895H
Now when I press ''Display'' button on remote control volume goes off and this code is shown :-
S123 K234 Y
000 001 1
The numbers in the second line can be navigated by ''CH+'' button and changed between 0 and 1 by ''Vol+'' button.
I really don't know anything about this. So, please help me out of this problem.
Nov 08, 2010 | Televison & Video
We have a magnavok big screen tv
Manual Library you should find all you need here:
http://www.techlore.com/group/2/list_downloads
Hope that helps, good luck
ALSO:
I searched a Magnavox manual for the lock feature here is what I found...
The following functions are disabled during SDM (and enabled after leaving SDM):
· Parental lock
· Blue mute
· Hospitality Mode
· No-ident Timer (normally the set is automatically switched off when no video signal (IDENT) is received for
15 minutes).
All other controls operate normally.
Entering Service Default Mode
To enter the Service Default Mode, press the following key sequence on the remote control transmitter:
0-6-2-5-9-6-MENU
Do not allow the display to time out between entries while keying the sequence.
Upon entry into the Service Default Mode, the letters “SDM” will be displayed at the upper right corner of the screen.
ALSO:
- Line 7 : “CHANNEL BLOCKED”
Indicates that all channels are locked except the selected channel.
The following complaints may be generated due to locked channels:
- TV cannot be switched on from standby with the local keyboard buttons.
- “CH+” and “CH-“ buttons on local keyboard do not function.
To disable the LOCK feature:
Select ”FEATURE” menu (with the Remote Control).
Select “LOCK” (with the Remote Control).
Set to “OFF”
Sep 07, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips 60PP9352 60" Rear Projection Television Logo
204 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
