Question about Acer Aspire 6920 Notebook PC
CONNECTING ACER 6920 TO TV WITH HDMI
I have just got the blu ray player to work properly on the lap top but i now want toconnect it to my HD ready tv via the HDMI socket on the laptop. I can get an image on the screen when doing normal computer functions but when it switch on the blu ray player it freezes and i get the message that the video card may not be compatible and not to run on two monitors because of clone mode.
Any ideas
Cheers
Gary
  • rg42394 May 11, 2010
    What kind of video card did your acer come with? What kind of blu-ray player is it?(External of Internal)?
I have checked other sites and found out a way around it. Right click on the desk top and select properties, this will then give you the option to connect to external applicances which include the tv. All i need to do now is work out the sound and i am there.
Cheers
Gazza
Posted on Jan 25, 2009
Why is there no power to DVD box?
Check your power cord and plug for damage, do a wiggle test with DVD plugged in and see if it comes on while moving and bending wire plug. press the helpful button
DVD power supply repair tips
Press Release Consumer Electronics Video Audio Camera TV
DVD Player Repair Guide Covers Every Detail
Jan 26, 2016 | Televison & Video
Tip
What is 1080i and 1080p what cable and HDMI version do I need
So you've got your new Flat Panel Plasma TV and Blu Ray DVD player what cable should you use, am I really 1080p HD Ready ?
So here it is in laymans terms
HDMI
stands for High-Definition Multimedia Interface. It's a digital interface to get the best, uncompressed digital picture possible.There are currently five versions that are setup as improvement on the last since its introduction in 2003
The first high defintion TV's were classed as HD Ready only the resolutions were set at 1280x720= 921,600 just under a MegaPixel per frame and were called 720p and are capable of viewing only 1080i signals with the correct cable the latest version is called HD Ready 1080p the HDMI standard for this is HDMI 1.3 which means that unless you have a TV that is rated for HDMI 1.3 your 1080p Blu Ray player wont work in full 1080p there will be no picture and the players HDMI output will have to be reduced to 1080i this can be done in the Blu Ray Players settings so you can still watch the video on your older HD Ready television
1080i vs 1080p - Basically both formats have the same number of Pixels 1920 across the top and 1080 across the side this gives a total number of pixels (1920x1080=2,073,600) aka 2 MegaPixels per frame assuming that the aspect ratio is 16:9 this is the same as a basic digital camera or phone jpeg.
You might also see written like this 1080p24 means that it originated from a progressive scanned 24 frames source and has become an established production standard Cimena and for your Blu Ray player will also have this setting if you require it.
When Compared to standard DVD with and aspect ratio of 4:3 which has 720x576=414,720 this is an increase of 500% in the resolution alone over the now humbled DVD Video format with interlaced video
The difference between the two is that one is interlaced (like normal DVD-Video) and the other is progressive OR non-interlaced scan which means that 1080p requires way more transfer speed than that of the 1080i format.
So the main disadvantage of progressive scan is that it requires higher bandwidth than interlaced video that has the same frame size and vertical refresh rate this is why DVD-Videos incorporate the interaced video due to the lack of a digital inteface like HDMI 1.3 rated cable is required to transfer this higher speed of transmission in contrast the 1080i signal requires a much slower speed and HDMI 1.2 rated cable might work.
As far as interconnects go you can still connect your full 1080p Blu Ray Player to your 1080i Plasma TV using the three cable interconnect that comes with the players but for the best possible connection you need to use a HDMI cable with gold plated connecitons. Prices range from £15 right upto £60 and beyond if you go with Monster Cables however the £15 version if it says rated for Blu Ray it will work just fine so save yourself £40.
HD Ready
HDMI 1.0 - combines a digital video signal (standard or HD) with a two-channel audio signal over a single cable used with the HD Ready
HDMI 1.1 - This version adds the ability to transfer not only video and two-channel audio over a single cable, but also added the ability to transfer Dolby Digital, DTS, and DVD-Audio surround signals, as well up to 7.1 channels of PCM audio.
HDMI 1.2 - This version adds the ability to transfer Super Audio CD signals in digital form from a player to a receiver most Home Theatre Systems require at least this type of cable for full capabilty however you can use a v1.3a cable works just as well
HD Ready 1080p
HDMI 1.3 and HDMI 1.3a These versions include improvements in both audio and video capability. With the advent of Blu-ray Disc it adds the ability to transfer the digital bitstreams for the new high resolution audio formats in addition to the standard 24-bit color depth we are used to, HDMI 1.3a has the ability to transfer color depths up to 48-bits, and can accommodate resolutions much higher than the 1080p resolution standard that is in use today on all TVs that are HD Ready 1080p
HDMI 1.4 and HDMI 1.4a HDMI version 1.4 adds practical enhancements for HDMI connectivity. If home theater components, such as HDTVs, Blu-ray Disc players, and Home Theater Receiver, the next step in HDMI of the future is covered by the v1.4a cables wrt to speed.
on Apr 15, 2010 | LG 47 in. Flat-Panel LCD HDTV
I have a beko 37 inch hd ready tv i recently go the sky hd box . my tv only has one hdmi port and i also have a samsung blu ray dvd player which only has a hdmi connection i got a switcher box for the hdmi...
It is possible the hdmi cable that you are using is faulty. The reason I say this is because you have multiple signals that pass through a hdmi cable (19 pins in it means 19 wires to carry signals). The more the cable gets moved and bent, you increase the chances of creating a short or re-connecting a short if moved from one tv to another. This is the best case scenario as it is easier to replace the cable and less costly. Since you already connected the the dvd directly to the tv, and I am presuming that you have working devices running through the switch and you can eliminate that as the problem. If you do not have working devices on your switch or directly into your tv, and you have tried multiple hdmi cable and still nothing, the hdmi connector on your tv is probably bad and that would be the worse case scenario.
Nov 03, 2013 | Philips Televison & Video
I have hooked up my br to an onkyo home theater through hdmi. i now get an unusable signal on my flat screen. This also happens when I hook it up directly to the tv. What can I do to get this to work
hi,
The Blu-ray player outputs full HD VIDEO (1080p) through HDMI, if your tv is not a full HD one then you can't see the video. Do one thing connect the Blu-ray player to any full HD tv and go to it video setting. Down scale the video to 1080i. All HD ready tvs supports only resolution up to 1080i. only full HD tvs supports 1080p. Down scale the video to 1080i surely you will get video. Also check the version of HDMI cable you have used. It should be 1.2 or above.
ok
Feb 15, 2011 | Sony BDPS570 Bluray 3D Player
Just connected our directv hd receiver to the tv via component cables, because we just bought a blue ray player and the only output for that is HDMI and since there is only 1 DVI input we had to change the...
You may be able the settings of your directTV box to stop frustrating you. If you help me identify the model you are using, I can research the proper menu choices you will need to choose to select the correct features. There are many different directTV set-top boxes available.
My own home theater setup did the same thing, and my solution was to use component cables from the PVR instead of HDMI cables. It is too bad your blu-ray doesn't allow for this configuration.
My work-around until I realized that using different interconnects fixed the problem, was to turn the TV off and then on again whenever switching from HD to non-HD sources. This fixed my problem, maybe it will fix yours.
I hope that helps.
Mar 28, 2010 | Samsung HLN617W 61" Rear Projection HDTV
HDMI and or Receiver problem
While Bluray pluged into the TV change the resolution from AUTO to 720P then plug Bluray back to the receiver and see if it solve your problem.
Nov 27, 2009 | Hitachi 51F59 51" HDTV Projection...
Trying to get my Acer Aspire 7720 blu ray player to play on my lg LCD tv. player plays fine on the laptop but not the tv. Connecting thru a VGA able for video feed. Help please
Hi there
You will need a HDMI cable, that is of course if the laptop has HDMI out and that the TV supports HDMI.
This is the only way you will be able to experience the full Blue-ray HD experience through the LCD TV.
Good luck and thanks for using Fixya!!!!
Feb 19, 2009 | Acer Aspire 5100 Notebook
Acer 6920 blue ray problems
I have had the same poblems after buying my lap top from Currys. I emailed acer and all they would say is that all of the warranties have been taken over buy PC WORLD who are the same company. They then said that i should contact the tech guys. The tech guys tell you to restore to factory settings which tales off anything that you have already put on the computer. I then contacted the software tech guys £1.50 a minute line and the bloke i spoke to said that it was the fourth call that he had recieved that morning and the advice that he gave me was to return the computer as it was less than a month old and state that it was not fit for purpose. I took the lap top back to Currys and explained what i had been told to do. In the end they installed Power DVD 8 on my computer which allows me to play all blu rays on the computer. However i still can't connect the acer up to my HD eady tv without it freezing. It appears that the software supplied is absolutely **** but acer are happy to let you get on with it. The only real solution is to obtain third party software and update your graphics drivers. In time hopefully acer will release better edition of the pre installed software.
It is a real shame as the laptop is great apart from this blu ray issue which seems to be a well known problem as it is mentioned on many forums.
I hope this assists
Dec 27, 2008 | Acer Aspire 6920 Notebook PC
Cant play blu-rays on lcd hdtv connected with hdmi
The software playing the bluray disc (PowerDVD) will only play it on the primary display. You will have to set your tv to be your primary display in order to watch the movie.
This only happens with bluray and HD-DVD discs.
Dec 06, 2008 | Sony VAIO Notebook
Acer Aspire 6920 Notebook PC Logo
422 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
