Question about Vivitar DF-293-NIK TTL LCD Bounce Zoom Swivel DSLR AF Flash for Nikon
Vivitar DF 293 CAN series 1 flash not firing
I have rarely used this flash but now it won't fire. The ready and ok light are not coming on. My camera is reading that there is an external flash. I have charged the batteries. I tried pressing the test button and it fired the flash but will not again. I have read only one other review that said they have had this problem. Anyone know how to correct this? I am shooting with a Canon 60D.
5 Suggested Answers
lightingman
  • 22 Answers
SOURCE: Vivitar 285HV Stop Working
There is nothing wrong with your flash unit. The regular AA batters are 1.5 v volts each- if 4 batteries are used that is a total of 6 volts for proper operation. The rechargeable batteries are 1.2 volts each and 4 will get you 4.8 volts- thats 1.2 volts short and that is probably the root of our problem .
Try recharging you rechargeable batteries and put the im one more time- if the same problem happens you will have to stick with standard AA batteries. There external 6 volt packs that will work with your flash unit0 the are a bit of an expense at first but you will save on replacement batteries in the long run,.
Ed
Posted on Nov 29, 2008
SOURCE: vivitar 283 won't flash, exept through pc terminal
Hi if it is a Japanese 283, CAREFUL, you are working with ~300V
remove the sensor from the front. Short out the terminals at 7 o'clock and 11 o'clock with eg a paper clip, and then charge up the flash . Short the centre terminal with the one at 7 o'clock. If the flash fires, then it probably needs a replacement hot shoe from ebay. If it doesn't, it is a simple job to fix for an electronics worker. Manuals are available on ebay.
I repeat, careful with the Japanese flashes, you will have ~300 volts near you fingers, so if you are less than 100% confident that you won't blow the top of a finger (or worse), get an electronics worker to look at it.
Don't use the ebay hot shoes on a 300 volt flash, you will have the 300 volts out in the open and ready to bite you - have a look how well hidden the second contact is on the Vivitar plastic hot shoe.
Good luck the Feral Photographer
Posted on Jan 05, 2009
  • 65 Answers
SOURCE: Vivitar 285 HV won't fire
If you know basic soldering, Open the old hot shoe from base
(4 screws).Note down the position of the wires.
Try to fire the flash with shorting two trigger wires,most ly it will fire.
If the springy contact is adjustable do it.If it is not repairable, you can get metal hot shoe from ebay easily.
Caution: metal hot shoe will short circuit 4 TTL contacts (on digital camera) ,so you need to put cello tape at bottom of hot shoe with only center hole.
Hope this solves.
Posted on Mar 16, 2010
  • 50 Answers
SOURCE: Vivitar DF-283-CAN flash suddenly won't go off. I
This is more than likely a Manufacturing problem. A lot of Vivitar cameras have this problem as well as many others that are usually not the consumers fault. Just a glitch in the technology. I alone have gone through four Vivitar cameras in the last six months. The best thing to do is contact Vivitar directly. This is there website: www.vivitar.com It is best to see if you can find the number for technical support. To see if they can give you a refund or replace it for you. I hope this helps. -Richard
Posted on Apr 12, 2010
Canon 580exii speedlight, I want to only use the slaves, but they won't fire when I turn off the master
You didn't say what camera model you are using.
If you have 7D/60D/T4i you can have a total of 3 wireless ir flashes.
580EX II must be set at Master, say Group A & Channel 1
Two 270EX II must be set at Slave, say Group A & Channel 1
or
One 270EX II set at Group A & Channel 1
Second 270EX II set Group A & Channel 2
Then go into camera menu & turn off Master flash & turn settings for those two flashes.
Send me a email, then I can help you much better.
atdlee@netzero.com
Nov 17, 2012 | Canon Speedlite 580EX II TTL Flash
Error 5 with canon eos rebel 6.3 mp
there is a pin in the hot shoe that detects if an external flash is connected. check and make sure it isn't stuck down.
check to make sure the flash comes all the way up. sometimes spillage can cause the flash to not go up all the way or not to come up at all. you would have to disassemble the flash unit and clean the pivots and lubricate them with grease
If the flash comes all the way up but the camera is still 'clicking' - the lock is still moving back and forth to free the flash, then the problem is either in the flash-up switch, located on the flex on the bottom side of the top cover, is not operating properly. you would need to remove the top cover (first removing all the other covers) and repair the switch. if that switch is OK, then there may be a circuit problem. don't forget to discharge the flash capacitor - 300 volts - ouch!!!
if the flash comes up but the flash symbol keeps blinking and the flash never charges, or the symbol comes on for full flash, but when you fire it the flash doesn't fire and the symbol starts blinking again, you are probably looking at a dead flash board
Jun 02, 2012 | Cameras
Canon 580EX II Flash is not firing??
It could be the bad bulb. You need to replace the entire bulb assembly. Canon Speedlite 580EX II MYK Camera Camcorder Repair
Apr 22, 2017 | Canon Cameras
My flash stopped working on my nikon coolpix L110..
The Nikon Coolpix is a compact digital camera that is well-suited for amateur to semi-professional photographers. Occasionally, some issues with the built-in flash can occur. If the hardware is damaged, the camera must be taken in for repairs. More often, problems occur because of obstructions or issues with the camera's settings and are easily repairable. Follow the troubleshooting guide to fix the built-in flash.
Instructions:
1.Ensure the Nikon Coolpix digital camera battery is fully charged.
2.Wait several seconds before pressing the shutter-release button if the "Flash Ready" indicator light is flashing red. Press the "Flash Mode" button once or twice to change the flash settings from "Off" to "On" or "Auto" if the "Flash Ready" indicator light is off.
3.Ensure there are no obstructions, like your finger or the camera strap, that are preventing the flash from firing if an error message appears on the display screen and the flash is not firing when the flash mode is set to automatic.
4.Press the flash back into the camera after every photo to ensure the flash always fires in "Auto" mode instead of just in low illumination settings. Press the flash back into the camera to turn off the flash in "Manual" mode; otherwise the flash will continually fire.
5.Change the auto focus setting from "Infinity" to "Auto," "Macro Closeup" or "Self-Timer" by pressing the "Focus Mode" button once, twice or three times to automatically turn the flash back on.
6.Use only Nikon external flash accessories to avoid damage to the built-in flash and camera circuits.
I hope you find it very helpful. Thanks.
Aug 25, 2011 | Nikon COOLPIX L4 Digital Camera
All of a sudden my sb-400 won't fire. i have changed the batteries numerous times and the red ready light is on but when i take a pic the auto flash pops up and the speedlight won't fire.
HI, I have a SB-400 with cracked housing, and hope to find a broken one to replace my part. Any offer is very much appreciated if you are interested of selling yours! Sincerely, Samantha (utwicky at gmail dot com)
May 14, 2011 | Nikon SB-400 Flash
Flash doesn't fire
Should fire from test button. If not flash tube is blown.
Jul 08, 2017 | Digital Concepts 952AF for Pentax Flash
The flash on my camera will not go off, it shows the light in the back ready, but nothing happens to help light up the picture
If your using the hot shoe with an external flash, three things could've happened: battery power in your camera is too low to fire the flash; or check the menu/settings/flash - ext flash settings may not have been chosen by the camera, but you may need to set it first manually; or your hot shoe is not a hot one, but your flash needs to be plugged into a PC outlet on the side of your camera. One last thing - test fire your flash and make sure it works to rule out the camera. There have been occasions where the ready light works on the flash, but it won't fire even after being plugged in. This problem was found to be a loose soldered wire in the flash foot. Another time it wound up to be the flashtube. Hope this helps.
Aug 01, 2008 | Cameras
Sigma Elec Flash EF-530 (so) DG Super used with Dimage A2 camera
The light only flashes in wireless mode or in slave mode. It basically lets you know that the flash is ready to fire. At least that is my experience w/ the 530 DG Super.
Apr 16, 2008 | Cameras
Vivitar DF-293-NIK TTL LCD Bounce Zoom Swivel DSLR AF Flash for Nikon Logo
261 people viewed this question
Top Vivitar Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
