The Spin Cycle does not work
The washer goes through all the cycles but the spin cycle. You have to manually turn the dial to the spin cycle to get it to work.
  • Washing Mach... Master
  • 17,129 Answers
Suspect that the Timer module is faulty as it does not move automatically to the SPIN mode.
You need to try with another program cycle to confirm or otherwise replacement is the only option. check on cost and options..
Posted on Jan 17, 2013
  • 1294 Answers
SOURCE: Maytag Atlantis -won't spin
Find out where your filter is & clean it out thoroughly, refit.
Posted on May 10, 2008
  • 1073 Answers
SOURCE: washing machine spins but doesnt drain water until I turn it back to spin only
timer contacts are burnt replace the timer
Posted on Jun 13, 2008
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
SOURCE: Washer will not Spin during SPIN CYCLES
Check the lid switch. Through out time the lid switch housing can come apart from years of heat and cold. When I checked mine, I found the glue deterriated and the housing came apart. What I did to fix it is I zipped tied the housing together and did a functional check and it worked.
Posted on Apr 25, 2009
  • 3 Answers
SOURCE: kenmore he2 front loader washer won't do rinse spin cycle
kappharmd-
if yours is the same, the drain is hidden behind the lower access panel on the front (how convenient, huh?). I don't understand why they didn't just make a recess hole for it. I've just left one screw loose in the center and it kinda "compression" fits. We clean this out regularly, as my wife and family don't check pockets well. :)
Posted on Apr 02, 2010
My Kenmore washer drains after the rinse cycle but won't spin at the end of it's cycle. If I manually set it to the spin cycle, it spins just fine. Desperate!!! The lid switch was just replaced about
Possible there is problem with the timer controller unit. It seems that the stepper motor is not moving to the next cycle until you manually move it to the spin. You can use some contact cleaners on the switch and also carefully try to see if the timer moves within , replacement is a costly issue and must be debated
Nov 20, 2013 | Washing Machines
Wash doesn't go through full cycle
I have a Maytag model A490 clothes washer. It works fine up to the rinse cycle and then shuts down. When it reaches this point it has become necessary to manually advance the dial a short ways whereupon it will fill with water and complete the rinse and spin cycles. This happens on both the regular and the permanent press cycles. What needs to be done to fix this problem?
Jul 14, 2009 | Maytag Washing Machines
Spin cycle doesn,t work
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
May 27, 2009 | Roper RAX7244KQ Top Load Washer
24642300 doesn't spin
  • yes it does sound like the timer is bad.
  • the timer has small contacts in it (sort of like a music box) that lift and rest in certain places.
  • these contacts may not mate properly as the timer goes around slowly in the normal operation.
  •  but when you manually turn it is a faster turn and the contacts will fall faster and get a better connection.
Jun 30, 2008 | Kenmore 23822 Top Load Washer
Doesn't spin
May 10, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
96 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
