Question about Samsung SMH8165W Microwave Oven
Samsung microwave SMH9151W displays code -SE-
  • Samsung Master
  • 9,047 Answers
"SE" means you have a defective membrane keypad. There are two ways to fix this:
1. Replace the membrane keypad. If you (or someone you know) might want to replace it yourself, there is a handy guide with pictures showing you what's typically involved. It is part number DE34-00304G.
2. Replace the control panel frame assembly (part number DE94-01806J) which comes with a new keypad already installed. Details are below.
There is a a YouTube video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Some connectors have a lock.
Then simply move your circuit board into the new frame.
You should first contact these parts suppliers to see which if either parts are in stock or still actually available:
Sears Parts Direct
Encompass parts (or you can call them toll-free at 866-779-5835)
The Pros here
Again the parts are:
DE34-00304G membrane keypad switch
DE94-01806J control panel assembly
Posted on Jan 17, 2013
3 Suggested Answers
rulds2008
  • 3866 Answers
SOURCE: Cooking bag of vegetables in
Sounds like some metel was interduced, now you cannot just put any bad of vegies the very paint might have some for of metals in it on the bag, Sounds like you blew the magntron in this bad boy and its going to cost a buch of money to fix it. Now that is caused by metal intruducted in the unit. A magatron might cost $100 bucks or more. Do not shoot the messenger i was not there when the vegies blew the unit nor do i know if it was save to put the whole bag in there. Let me know i am here to help, please do click accept button
Posted on Aug 24, 2010
SOURCE: Samsung microwave shows SE on display
The problem lies with the mylar ribbon cable that connects the Keypad to the circuit board. The Mylar ribbon cable folds back onto itself and are touching. Over time the mylar 'breaks down' electrically and the wire traces in the mylar will 'arc' onto the other mylar ribbon cable. The solution is to separate the two mylar ribbon cables using paper and electrical tape. I've done this on several microwaves (not just Samsung) and it has worked every time. Patience and about 20 minutes is all it should take to fix it. I've described below how I did it for the SMH9187ST Microwave Good luck to all.
1. UNPLUG THE MICROWAVE !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2. 1. Remove the top front cover by removing the (2) screws that are along the top edge (phillips).
3. 2. Slide the cover to the left about a half inch (there are tabs holding the cover in place) and remove.
4. 3. Remove (1) screw from the top of the Keypad Housing (phillips). Lift the Keypad Housing upwards about half an inch (there are tabs holding the Keypad Housing in place) and remove. Be careful of the metal grille that is just above the Keypad Housing as this may fall out since it is being held in place by the Housing.
5. 4. Be careful not to pull on the wiring harnesses that are attached to the Housing. Carefully unplug the wiring harness that has the RED connector on it from the circuit board. Carefully unplug the small white connector that has the mylar ribbon cable on it (this cable is see-through and you can see thin, flat wires in it).
6. 5. Remove (4) screws that are holding the circuit board onto the Housing.
7. The Housing should now be free of the circuit board and wiring harnesses. It's safe to let the wiring harness/circuit board hang free, but caution should be used anyway.
8. 6. Remove the thin metal frame from the Housing. There are (4) plastic tabs holding the frame in place. Using a small screw driver pry one side of the frame away from the housing (try to do this to the side that has smaller plastic tabs). When this side of the frame is free of the Housing you have to lift the frame out at an angle to remove. It might put up a fuss, but be patient and be gentle with it since the frame is thin and fragile.
9. 7. With the frame out of the way you will see the mylar ribbon cable that is coming out from underneath the Keypad assembly. You will notice that the mylar ribbon cable folds back onto itself as it re-enters the Keypad assembly. This 'touching of the two ribbon cables' is where the trouble lies. The ribbon cables may be stuck together. Carefully separate these two and then insert a small piece of paper between them (paper can be 1/2 x 1/2 ) and work the paper all the way down into the Keypad assembly as far as it will go.
10. 8. Using electrical tape, apply a small piece between the ribbon cables to hold the paper in place. Next, use more electrical tape and put it between the mylar ribbon cables enough so as to keep the ribbon cables separated.
11. 9. Re-attached the thin metal frame making sure to press it into the Keypad assembly enough so that the (4) tabs click into place.
12. 10. Use electrical tape and apply it to the raw metal edge of the thin metal frame to prevent the mylar ribbon cables from rubbing on the metal edge.
13. 11. That's it. A final word of caution. Be careful when inserting the ribbon cable connector back on to the circuit board. The connector is loose and you need to gently place the ribbon cable into the circuit board connector.
14. 12. Reverse the order of assembly from above.
15. 13. Plug in the microwave and then it should reset and ask you to set the time.
16. Hope this works for you !!
Posted on Aug 02, 2012
Why is my Samsung microwave model smh9151w showing 5e-1 and beeps
Unless there is grease, moisture, or some other foreign material deposits on your control circuit board, "SE" means you have a shorted membrane keypad.
For the official repair information as per the Samsung bulletin, see http://www.microwavecontrol.com/samsung_se_error.htm
See my profile picture if you need more help.
We're
Oct 05, 2015 | Samsung Microwave Ovens
SMH9151W--se ERROR MESSAGE-HOW TO FIX
The 5E error indicates a problem with the key pad. The microwave computer believes there is a short between the key pad and the central board. You may be able to temporarily reset the error by unplugging the microwave for at least 30 seconds. (In some cases, tripping your circuit breaker may be an easier way to disconnect the power to an over the range microwave.)
Some people have been able to solve the code by cleaning the contacts in the wiring harness. The recommended solution is to replace the assembly control panel (switch membrane, window and control panel). See http://www.searspartsdirect.com/samsung-microwave-parts/model-SMH9151WXAA0000/1482/0123370/50041332/00004.html for a parts diagram and some prices.
Since microwaves have capacitors that store significant amounts of energy, you may want a professional to take apart the microwave and do the repair.
I hope this helps.
Aug 20, 2015 | Samsung Microwave Ovens
How do I fix a SE problem on a Samsung microwave model # smh9151w
Usually that means you have a shorted keypad, and to fix it you usually have to replace the control console/keypad assembly.
Oct 19, 2014 | Microwave Ovens
How to clear SE error code on samsung microwave Model# SMH9151W
We're
Sep 01, 2014 | Samsung Microwave Ovens
SAMSUNG MICROWAVE SHOWS SE AND WILL NOT WORK.WHY?
SE is an error code for a shorted keypad, although the keypad might not really be shorted.
Unplug the oven for a few minutes to see if it clears the error code. If not, then leave it unplugged over night. If the problem persists, then you probably do have a shorted membrane switch on the keypad.
Aug 29, 2014 | Samsung SMH9187ST Microwave Oven
Samsung Microwave Mod # SMH9187ST. Starts on its own, "bake potato" on display screen. After shutting down, code SE appears on screen. No response from keypad until unplugged. Reset and problem ret
Contact Samsung, I was having a similar problem with the SE error appearing on my microwave. Apparently its a problem with the control panel and they are going to replace it free of charge under there epidemic warranty
Mar 18, 2013 | Samsung SMH8165W Microwave Oven
My SMH9151W Samsung Microwave displays a -SE- or a -5E- and will not operate. I unplugged over night and still will not operate
I had the same issue on a 2010 smh9151w samsung microwave after installing it and using it with no problem for 5 days. The second time we unplugged the microwave and turned the circuit breaker off and on we didn't reset the clock on the microwave so the display shows :0 and it has been working for 7 days straight now. Fingers crossed that this is a long term solution. Hope this helps. Thanks!
Mar 20, 2012 | Samsung Microwave Ovens
The display panel readout has a 5E or possibly a SE on the dislplay constantly
SE error means you have a shorted membrane keypad.
You have a shorting membrane keypad. If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
We would need the model number in order to provide you with free assistance.
It will be one of these:
SMH9151B
SMH9151B/XAA
SMH9151B/XAC
SMH9151BE
SMH9151BE/XAA
SMH9151S
SMH9151S/XAA
SMH9151ST
SMH9151ST/XAA
SMH9151ST/XAC
SMH9151STE
SMH9151STE/XAA
SMH9151W
SMH9151W/XAA
SMH9151W/XAC
It is usually found on a tag located inside the cooking cavity or around the door frame or controller frame.
Since FixYa is still not notifying us when you respond to clarification requests, you will have to post a new help request with your model number and symptoms / questions, or you may contact us here for this free assistance.
In some cases, it is a simple do it yourself repair.
Sep 18, 2011 | Samsung SMH9151 Microwave Oven
Microwave keypad does not respond and screen reads SE
"SE" error means you have a shorted membrane keypad.
The exact part you need will depend on the model number, which will be one of these:
SMH9151B SMH9151B/XAA SMH9151B/XAC SMH9151BE SMH9151BE/XAA SMH9151S SMH9151S/XAA SMH9151ST SMH9151ST/XAA SMH9151ST/XAC SMH9151STE SMH9151STE/XAA SMH9151W SMH9151W/XAA SMH9151W/XAC SMH9151WE SMH9151WE/XAA.
On some models, you can just order a new membrane keypad and replace it. It's cheap, but a lot of work.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
On other models,
the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job, but it costs more.
Feel free to contact me directly (and please remind me of your full model number) for more information & help and a free estimate for us to do it for you.
Aug 20, 2010 | Samsung SMH9151 Microwave Oven
Fan not working on microwave model smh915
Samsung SMH9151W microwave display shows "-SE-", after power on. Nothing else working. Any idea? Thanks a lot
Aug 03, 2010 | Samsung Microwave Ovens
Samsung SMH8165W Microwave Oven Logo
394 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
