Question about Toshiba Camileo X100 High Definition Camcorder
Why does my camcorder shut off when i power it up with new battery
My camcorder does not come on. When I put the battery in the screen comes up, then shuts down. This is with a new battery and charged. Also, when you open the tape holder, it appears that you can see...
Your camcorder might have an internal problem. As long as you know that your battery is charged and working properly. To make sure you can connect your camcorder directly with the power supply and try to turn your camera on. If that still doesn't work i would contact manufacture and hopefully the camera is still under warranty. They will help you further.
Mar 20, 2011 | Cameras
Error code
I believe this means that there is condensation in the tape mechanism.
Apr 06, 2008 | Sony Handycam DCR-HC14E Mini DV Digital...
After recording with a full new battery (and the old one) the power just shuts off after about 15 min. Why?
The camcorder will shut off (i.e. go into "sleep" mode) after a few minutes of inactivity - to save your battery, particularly when your battery is at half or lower.
I find that my (fully charged) battery lasts only about 30 minutes (or less, if I use the zoom a lot, or, I use the filming (night) light, or I do not put the lens cover on when not in use, or I do not close the LCD display screen). I'll usually power off after completing my shots.
I keep a close watch on the battery meter and switch batteries as soon as it shows a red bar. (Just give it a minute to wrap-up before shutting down). I usually carry a couple of extra charged batteries. A larger (after market) battery that I bought lasted a hour or so, but it didn't hold a charge well after a couple of weeks of use.
Jun 10, 2010 | Samsung SC-DC173 DVD Camcorder
Camcorder shuts down when trying to record
Your battery is not holding the charge. Buy new battery for the camer and charge it up.
Dec 12, 2009 | Panasonic Palmcorder PV-DV102 Mini DV...
Camcorder works only when charging!!
Maybe you need a new camcorder battery to test.
We have many camcorder batteries on sale. Welcome to visit:
Canada
www.buy-battery.ca/camcorder-battery.php
USA
www.all-batteries-shop.com/camcorder-battery
May 08, 2009 | Jazz DV-179 Digital Camera
There is a flashing red and then shut down NV-DS65
battery is not charged or is defectived. or the power supply is not working.
i suggest replacing the battery or getting a new power cord
Apr 23, 2009 | Panasonic NV-DS65 Mini DV Digital...
Camcorder problem
you need a new battery
Nov 06, 2007 | JVC COMPACT VHS-C CAMCORDER
Shuts off
It sounds like the battery is flat - I realise that you've probably already thought of this, and charged up the battery, however batteries have a finite life and number of charge cycles they can go through, and may appear to be fully charge (According to the charger, at any rate), but they are unable to hold any decent charge. My suggestion would be to head down to the local camera shop, and ask if you can try a new battery in-store.
Sep 14, 2007 | Quasar VM-L450 Camcorder
Sony dcr-trv22
Just FYI, www.silentwitness.com has Sony modify the camcorders for use in mobile applications so they don't shutdown. I have no cure for this, but I do know the stock models are programmed to do this to prevent overheating. It has to do a lot with the warranty. i.e. you have a one year warranty. The unit can't (without modifications) run 24x7. Said modification almost triples the price of the camera.
Sep 13, 2005 | Sony Handycam DCR-TRV22 Mini DV Digital...
Toshiba Camileo X100 High Definition Camcorder Logo
27 people viewed this question
Top Toshiba Video Cameras Experts
Voros101
JonSnell Electronic
JonSnell Electronic
Are you a Toshiba Video Camera Expert? Answer questions, earn points and help others
