Question about Maytag Washing Machines
Maytag LAT9635aae walks
I have made sure the machine is level, (front to back and side to side); but the machine still walks. I bought the washer in 1995 and haven't had any problems with it until recently; 3 to 4 months since the machine started to walk.
  • Maytag Master
  • 17,129 Answers
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Posted on Jan 17, 2013
SOURCE: UNBALANCED WASHER
I also had roper washer model RAX 4232KQO for about three or four years. It washed great but would walk around on spin. It was in a house I rented out to someone else. Three years later I moved back. The roper still walked around on spin. I went to APD, a parts store and purchased a repair book. I took the washers case off. All the (3)suspension springs were intact as were the counter weight spring. When reassembling the washer a saw a yellow plastic band that had embossed on it pull out. I had pulled out the band attached by a yellow plug when I first purchased and set up the machine. What I did'nt do was completely remove the band which had two cotter pins attached four years earlier. I pulled out the band with the two cotter pins. I put the case back on, plugged the machine back in and put the machine on spin. The Roper Model RAX 4232KQO never worked so good! I guess I should have read the setting up instructions!
Posted on Oct 29, 2007
  • 489 Answers
SOURCE: Walking Washer
The best way to fix this problem is to adjust the front legs while the machine is spinning a full wash load.  Put in a load of clothes and run the machine to get the clothes nice and wet.  It will take about 5 minutes to get them completely wet.  Next, turn the washer off.  Now, turn the washer back on and push the spin button to select the extra fast speed.  You washer will go into a drain mode and then begin to toss the load into a balance spin mode.  Once the washer is spinning the clothes, check the balance of the unit by pushing the front left corner of the washer towards the right rear corner and right front corner towards the left rear corner.  If the sound of the washer quiets down on one side vs the other side, adjust the front leg to quiet that side.  Do not attempt to adjust the rear legs as they do not require adjustments at all.  Everything adjusts on the front legs.
This procedure works if the floor is sturdy enough.  If the floor is old and the wood is weak, it will not work.
Posted on Apr 27, 2008
THENTHEREWER
  • 131 Answers
SOURCE: Maytag front loader MAH-3 vibrates. Level & on concrete floor.
THERE ARE SHOCK ABSORBERS IN THIS UNIT,SOUNDS LIKE ONE OF THEM IS BROKEN.HOPE THIS HELPS
Posted on Nov 16, 2008
huuum
  • 750 Answers
SOURCE: Front load washer shakes violently during spin cycle
On something like this you will need to remove the washer wrap to inspect the suspension springs & base assembly. Please see the link provided for accessing the inside of the washer. Be sure the shipping pins have been removed. The tub should float freely.
Posted on Apr 03, 2009
SOURCE: MAYTAG NEPTUNE FRONT LOAD WASHER MAH5500BWW
Central bearing and seal are damaged. Very expensive repair and very expensive parts. Maytag does not sell bearings separately, they're only available with the outer tub, which is $400-$500; Repair itself is another 2-3 hours of hard work. Do the math...
Posted on Nov 02, 2010
Maytag washing machine walks across floor during spin cycle
Did you set the back feet before leveling? On most units to set and lock the back feet you need to pull the top towards you so that the back is raised off the floor, then set it down again, this will release the feet and lock then down. The you level the two front feet. After this is done you must make sure your load is balanced. Distribute the items as evenly as you can in the tub. Once it gets to the spin cycle if its walking or shaking a lot, stop it and redistribute the items more evenly in the tub. Also try not to overload the unit or combining many heavy items with few light ones. If this is a new machine, did you remove the shipping locks from the back before using it? They have plastic strips attached to them, make sure they have all been removed, as well as any shipping bolts.
Feb 17, 2015 | Maytag Neptune MAH6700A Front Load Washer
When you put a normal load in the machine seems to get off sided and it walks out of position. If there is a little amount of clothes it is fine. What can I do?
you need to get out a level and put it on top of the machine, put it across from left to right and then adjust the feet by turing one side or the other in our out till the bubble on the level reads in the center., now take the level and put it front to back and do the same thing. if your machine is level it should not vibrate to the point that it walks across the room.
Mar 16, 2011 | Maytag Neptune MAH5500B Front Load Washer
Washer vibrates and walks during spin cycle. Washer is on a vinyl floor
check to make sure the washer is level, and double check to make sure the shipping bolts have been removed from the back of the washer.
Feb 12, 2011 | Maytag MAH8700A Front Load Washer
Maytag walking
Hello. I have a few ideas for you.
1. Tilt the machine forward so the back feet are 3 to 4 inches (7.5 to 10 cm) off the ground, then set it back down. The back feet usually are self-leveling--just raising and lowering the machine like this will cause the feet to re-level themselves.
2. Place your level perpendicular to the front of the machine and check to see if the washer is level in this direction. If it is off, readjust each front foot by the same number of turns until you reach level.
3. Go to the carpet store and buy a remnamt which is the size of the washing machine lengthxwidth. Place this under the machine with the four legs all resting on the carpet.
Regards, Joe
PS please rate my answer. thank you.
Dec 20, 2009 | Maytag MAT13MN Top Load Washer
Shakes when on spin
Hi, your washing machine need to be leveled, use a spirit level, to level your washer, used washer legs for adjustments, after leveling of washer, place both hands on machine, and try to rock side to side, front to back,there should be no play (movements) on washer, make sure machine is firmly position, good luck.
Aug 13, 2009 | Washing Machines
Why does my EPIC z walks during spin cycle even after I used the rubber pads? It moves from the right back corner out to the left.
Make sure that the leveling feet are secure with the jamb nut tight against the BODY of the washer. If not, the washer could walk during spin. Make sure that washer is flat level front to back and side to side with a 24" level. Just set the level on the top near the front and then on both sides as well. Adjust the feet and jamb nuts so that they are as low as possible. If washer is on a stand, remove drawer to adjust feet. Also, if on stands, washer will vibrate more due to increased height and natural flexion of stand. What kind of flooring? If ceramic tile, rubber feet may not couple to surface and provide enough friction to stay in place. I have had success with......I know it might sound stupid.....but buy a couple rubber jar opener pads and cut them into small pads. Put them under the rubber feet of stand or washer. These seem to make a better connection to the floor.
Aug 01, 2009 | Washing Machines
Apr 03, 2009 | Washing Machines
The machine does not spin properly. The tub
it sounds like the unit is not sitting on level ground sometimes there are feet that can be adjusted to raise and lower the unit on the front left and right side go to a department store and by a level for a couple of dollars and put it on the top exterior of the unit and check it left to right and front to back
Feb 21, 2009 | Maytag Performa PAV2200
Washer walks across floor no matter what problem.
FIRST OF ALL SCREW THE FRONT LEGS ALL THE WAY DOWN THEN TILT THE MACHINE UP FROM THE BACK MEANING THE BACK SIDE UP SET DOWN FIRMLY THIS WILL AUTOMATICLY SELF LEVEL THE BACK LEGS THEN UNSCREW THE FRONT LEGS TO MAKE LEVEL WITH YOUR FLOOR THIS SCHOULD FIX YOUR PROBLEM THANKS GLAD TO BE OF SERVICE
Feb 03, 2009 | Maytag Performa PAV2200
Nov 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
