Question about Panasonic KX-TA824PK Phone
KX-TA824 Select idle CO line
I am using KX-TA824 / KX-T7731and when I press 9 to seize an idle co line it will go to the last CO (CO# 6 in my case). But have only 4 CO connected lines! Can I program the system to start searching from botom (CO#1) to top?
Thanks a lot in advance!
Sergio
  • vectorusa Jan 30, 2009
    Thank you Carl, you solve my problem! I really Appreciate.
    Just for curiosity, do you know why Panasonic search lines from high to low?
    Sergio
  • Panasonic Master
  • 2,460 Answers
No. C.O. Line group access is always from high to low. However, you can turn off CO 5&6. In programming command 400.
Carl
Posted on Jan 30, 2009
  • Carl Navarro
    Carl Navarro Jan 30, 2009
    It's an obscure term called glare. Back in the day, when the ring generator only came around 2 seconds out of 8, you had 6 seconds of a line being connected but the PBX trunk not knowing someone was there. If you dialed "9", you answered the incoming call. To fix it, you always arranged your incoming lines from low to high and selected your outgoing calls from high to low...or directionalized your lines.
    The impact of Glare is less today, with immediate ring, but you still can get it in a busy office.
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    Have a slt connected to my ta824. at factory defaults, if i go off hook on the slt and dial 9, line 1 will be seized. that is what i want but after i loaded my settings into it, 9 no longer accesses line 1...
    By default, a TA-824 seizes outside lines from high to low. You can't change that order, but you can dial the 8x code to get each line. As an alternative, in program 400, you disable the lines that don't work, but you'll still select the highest line assigned to the single line port when you dial 9.
    I don't know why your PT is different, but when I dial 9 on the intercom of my PT, I also select the top line.
    Carl
    Jul 28, 2011 | Panasonic KX-TA824PK Phone
    I have attached this cordless to KX-TA824 supporting 2 incoming lines. How can I select which line (CO 1 or CO 2) to call from?
    If you start with intercom dial tone, press 81 or 82. If you dial 9 you'll get line 2 before line 1 in normal programming, and if you dial a line that's busy with 8x access codes, you'll get a busy, even if the other line is free.
    Of course, you could also RTFM and program the system to function with your TA-824 http://public.carl.airpost.net/Pana/TA-824/UG_TA_0823%5B1%5D.pdf
    Starting on page 15 or so of the pdf, after you set up the keys, you'd press the > and 1 or 2 to get to lines 1 or 2 :-)
    Carl
    Oct 08, 2010 | Panasonic KX-TD7896 Cordless Phone
    Hi, Expert Guy , I have some problem with Panasonic TDA100 about calling Out by co line i have 20 extension and 4 CO line , so when i need to call out , i press number 9 , it will switch to the line free ....
    To call out: Go off hook press an idle CO button-- Dial outside phone number. There is no need to dial "9".
    If you need a copy of the manual you can get one for free at the following link: HTTP://phone.manualsonline.com/manuals/mfg/panasonic/kx-t7630.html....Let me know if this answers your question. Master FixYa...
    saailer@att.net
    Dec 05, 2009 | Panasonic KX-T7630 Corded Phone
    How do I forward calls to an outside number on a panasonic kx-ta824 system. what is the line access code
    Line access codes are the codes you dial from the intercom to get an outside line. 9 works.
    Call forwarding to an outside line has to be enabled in system programming either 2.1 in the maintenance console or option 607 in system programming. There's also a timer that allows the CO connection to be maintaned. By default it's 10 minutes.
    Once you get the program set up, you can dial 7139xxx-xxx-xxxx#
    Carl
    Oct 06, 2009 | Panasonic KX-TA824PK Phone
    Programing outside (CO) line button
    press program button then press the flexible where you want program the CO line then press 0, here u can select which CO line need to be program.
    Ali
    Sep 08, 2009 | Panasonic KX-T7730 Corded Phone
    We want to transfer a call to a phone number (external party). System programming is required. Can you help me? Thanks, Gina
    Panasonic KX t7730 call forwarding function to external party:
    If you are using the Kx-TA624 pbx (TES 824 models) system, program your phone unit (t7730) as follows: lifet handset, press FWD/DND button, press 3, then the outside line access code, then phone number, then #, then return handset.
    If you are using the kx-ta1232 (higher models) of pbx system (usually with 9 or more CO lines cabable, use the following command:
    lift handset, press FWD/DND button, press 6, then the outside line access code, then telehone number, then # then return handset to cradle.
    Jun 11, 2009 | Panasonic KX-T7730 Corded Phone
    I bught a kx-ta824, I just have one CO line and i want to put 4 extensions , but i couldn't. I can just recive 1 call and then the line sounds busy.
    With one CO line you can only make or receive one external call at a time. You can have extensions connected on intercom calls, but once your CO line is in use, anyone calling in will get a busy signal, as will anyone in the office trying to make an outside call. You'll need additional CO lines if you want to have several outside calls going on at once.
    Apr 10, 2009 | Panasonic KX-TA824PK Phone
    KX-T7600 series outgoing calls
    1. Press "PROG" (Program)
    2. Press "1" and "9" (19)
    3. Press "ENTER"
    4. Select "Idle Line"
    5. Press "ENTER"
    6. Press "EXIT"
    Jan 30, 2009 | Panasonic KX-T7630 Corded Phone
    Need to program pf buttons on kx-t7730
    Press Program Button
    Press Button to be Programmed
    Dial 1 - Plus extention number to be stored on button
    Press button directly under 'ENTER'
    Feb 12, 2008 | Panasonic KX-T7730 Corded Phone
    Panasonic KX-TA824PK Phone Logo
    547 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    john milligan
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
