Question about FUJIFILM FinePix Z300 Digital Camera
Camera won't turn on when shutter is pulled down
    Genius:
  • 1,019 Answers
Does the camera turn on when you press the power button ?
Posted on Jan 27, 2013
Canyon eos auto mode= won't take a pictuRE
Push your shutter 1/2 way down. See whats the readings in view finder.
Jul 04, 2013 | Cannon EOS 50D Digital Camera
Shutter won't reset after battery replacement
it can fixed only camera fixera company,better if you fix it according to camera company because your problem also be facced to me,i take it to a ordinary camera fixer and then my camera fully get damaged because who fixed my camera they fall acid in battery placce.
Mar 26, 2013 | Vivitar V3800N Zoom 35mm SLR Camera
Canon 40d will not take pictures
1) CF card in camera? Won't shoot without one
2) Does mirror go up?
3) Canon had a run of bad motors for this model - if mirror does not go up, then it is the mirror motor. If mirror goes up, shutter will not fire, press release again then the mirror goes down, the shutter motor is bad (same model motor). If mirror goes up, shutter fires, both blades travel together/no exposure, probably the shutter is bad.
May 07, 2012 | Canon EOS Digital Rebel XS / 1000D IS...
Nikon d40x suddenly stopped working- won't turn on- was working fine and when I connected it to laptop to download, it turned on , then suddenly went blank.
Do you get the 'push shutter button again' or 'turn off and on again ' message? If so the motor in the SQ unit that charges the shutter and moves the mirror up and down has failed. A very very common problem. The part is on constant back order at Nikon, and good luck getting it anyway as Nikon is going to stop selling parts to anyone in just a few weeks.
May 06, 2012 | Nikon D40x Digital Camera
Sony dsc-w190 won't turn on
The system control board has shut the camera down to prevent damage, the lens housing will need to be replaced because you have two problems, one the lens is jammed and second the shutter is open, the cost to repair will be equal if not more than a new one.
Mar 31, 2012 | Sony Cyber-shot DSC-W190 Digital Camera
Hi, I have a F4 one week ago, I've shoot two films, and when i have developed them, i have seen a line of 4 mm wide along the up long side of each photo. Does anybody know what's...
Thanks for the additional information.
Remove the lens and set the camera to manual exposure mode. Select the "B" (or "Bulb") shutter speed. Open or even remove the camera back and hold the camera up to a light source and press and hold the shutter. Look through the camera to see whether there is any horizontal obstruction towards the bottom of the film gate ( = top of negative, they're taken upside down). If you see an obstruction then assess the damage and if it's a foreign body then remove it. Note that you must absolutely not reach through the open shutter. If it closes whilst you have your fingers or tools in the way you will ruin the shutter assembly.
If that test shows nothing, then you really have run out of options and need to send the camera to a service centre for diagnosis and repair. It's likely to be a sticking shutter causing an overexposed band across the negative, usually the width of the band would show some variation in width and position depending upon shutter speed.
A poor battery will not be the cause of a shutter issue. Unless faulty, the shutter will either work or it won't, unlike the previous F3 the F4 lacks a mechanical back-up shutter speed.
Jul 16, 2011 | Nikon F4s 35mm SLR Camera
My canon powershot SD 1000 will take outdoor pictures but wont take any with low light and the flash won't work. I see that someone else asked the same question but I can see what advice was offered
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Recommend trying the pencil tapping fix listed in the link. It worked on my SD1000 with the same problem.
Jun 04, 2011 | Canon PowerShot SD1000 Digital Camera
I have a Canon PowerShot SD1000 and it turns on, but the screen is blank. It will upload any photos taken (although you can't see what pics you take), but even then you have to click the button on the...
By the way, my wife happens to own a SD1000. Great little camera, but it's prone to stuck shutter every once and a while. Easily fixed each time though by simply opening the battery door while on, and gently flicking the lens barrel a few times. Again, see the link.
May 31, 2011 | Canon PowerShot SD1000 Digital Camera
FUJIFILM FinePix Z300 Digital Camera Logo
63 people viewed this question
Top FUJIFILM Cameras Experts
Tony
Piyal Perera
Piyal Perera
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
