Question about Toshiba MK5065GSX - Hard Drive 500GB 2.5" SATA 5.4K
I DONT KNOW THE PASSWORD FOR MY TOSHIBA DISK DRIVE MK5065GSX
MY NAME IS ZIDI
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: I can not read a cd on my lenovo B575
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem
"you only need to do the following"
if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it
Posted on Nov 20, 2012
Why it dosent won`t to boot up? It shows in BIOS but not in MY COMPUTER PLEASE HELP!!! There are important files on HDD!
Perhaps mbr of hard disc needs repair..cause of a power interruption..
Boot to your windows discs, and there should be an option to enter command prompt.
you can try a simple fix to the MBR within cmd...
bootrec.exe /fixmbr
May 24, 2014 | Toshiba MK5065GSX) 500 GB SATA II Hard...
Toshiba mk5065gsx
Your hard drive is dying. It is time to clone it to a good working hard drive. Do it as soon as possible before it completely died.
Feb 26, 2014 | Toshiba Computers & Internet
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Nov 20, 2012 | Toshiba MK5065GSX) 500 GB SATA II Hard...
My toshiba l455s5008 has been in lockdown an i forgot the password an dont know how to fix it
Forgot windows password? Don't worry about it, when I forgot the password, i remove the password by the following steps,
Step1: Download and install Windows Password Recovery Tool Professional.Step2: Burn CD/DVD/USB Flash Drive. (Namely it is to burn aWindows password reset disk.)
Step3: Set the target computer boot from CD/DVD or USB.
Step4: Remove the forgotten Windows password with the burned CD/DVD/USB. Then log on to Windows without a password.
As the above method, you can finishwindows password remover, I think it is helpfull for you.
Aug 20, 2012 | Toshiba Satellite L455S5008 PC Notebook
I forgot my password for my toshiba laptop how can I find it. I have a hint but it won't take it
During the boot up process you will see on the screen for a short amount of time press a certain key to enter set up
Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
control panel user accounts
on the users tab,click the name of the computer administrator you can change the password there
hope this helps
Dec 03, 2010 | Toshiba - Floppy disk drive - external -...
Password for windows 2000 on a toshiba satellite pro 4600
burn it to a disk put it in the disk drive turn off unit then fire it up and hold down the f10 button choose from cd and follow the instructions if you can not succeed then go to best buy spend 29.99 and have the geek squad reset it for you.
Jan 28, 2009 | Toshiba Satellite Pro 4600 Notebook
Tecra 8100
I'm not clear on your description, so here goes:
If it showed the Toshiba start screen, then asked for a password, then your hard drive is password protected.
If it showed the Toshiba screen, then asked for password, and you entered it, and then it goes "insert disk", then your hard drive is passworded and wiped.
If the first thing it does is ask for a password, then the password is in the BIOS.
Aug 16, 2008 | Toshiba Tecra 8100 Notebook
I need to replace my hard disk notebook with a bigger capacity hdd
Toshiba is rather secretive with their documentation. It is hard to find. Google TOSHIBA SATELLITE A10 SERVICE MANUAL and check the available offerings.
You now have a 5400 RPM, ATA 100 drive. You should not have any drive size restrictions. Shops are advertising many large drives as compatible.
I suggest that you purchase only a 7200 RPM drive. The faster speed will perk your machine right up.
I have not worked on Toshiba machines but suggest you have all restore disks and passwords at hand.
Feb 18, 2008 | Toshiba Satellite A10 Notebook
Toshiba MK5065GSX - Hard Drive 500GB 2.5" SATA 5.4K Logo
67 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
