Ideal IMAX 80 continuous fan fault keep replacing
Replaced fan 9 times in 3 years
3 Suggested Answers
  • 143 Answers
SOURCE: GE Central A/C Unit about 30 yrs old; condenser fan stops after a short time.
I gather that it is the outdoor fan motor that runs a bit then stops.
Fan motors that stop by themselves are overheating and going into self-protect. The fact that you replaced the motor and capacitor opens up a whole world of "which wire is in the wrong place". I could do this if I could see it, but I can't see it. You're probably going to wind up calling a service man to sort out the wiring.
Posted on Jul 25, 2008
  • 10 Answers
SOURCE: My Fan above the condensor keeps cutting off. The
the fan capactor is bad and the motor overheats and goes off on thermal overload
Posted on Aug 08, 2011
F8E0 0n whirlpool gas range M: weg730hod50, What is going on, this is only 1 year old?.. reset and continues to error...
F8E0
Cooling Fan Speed Too Low
Fan speed below 500 rpm, either because the fan is spinning too slowly or because there is a problem with the Hall Effect sensor.
When will occur:
Within 20 seconds of a fault condition when cavity temperature is above 170°F (77°C).
RECOMMENDED CORRECTIVE ACTION PROCEDURE
1.Unplug range or disconnect power.
2.Pull the range forward and remove the top access cover.
3.Verify there are no obstructions in the blower. If there is an obstruction, remove it and go to Step 6. If no obstructions, go to Step 4.
4.Disconnect control board connect or P5 and check the fan motor for 105? resistance between P5-1 and
P6-3. If the motor test is not good, replace motor and go to Step 6. If motor tests good, go to Step 5.
5.Check the Hall Sensor by removing the control board P7 connector and testing for 5 VDC between P7-7 and P7-1. If test
is good, go to Step 6. If test results are not correct, replace the Hall Sensor.
6.Replace all parts and panels before operating.
7.Plug in range or reconnect power.
8.Start a cook cycle and check for proper operation.
9.
Enter the diagnostic mode to view the "Faults" screen. Press START TIME or DELAY START to clear each Fault code(s).
Nov 19, 2016 | Whirlpool Kitchen Ranges
The self-diagnostic light is flashing 5 times for a brake fault.
CTM info on flashing 5 times is CHECK FREEWHEEL LEVER IS IN DRIVE,,check wiring .connections good luck
Apr 21, 2016 | Ctm HS 125 3 Wheel Power Scooter
I have a Hyundai IMAX (2008 model). Recently, it has started idling rough, dropping to 500 rams and losing power. It has stalled a few times and can not be started afterwards. Mainly happens when it i
Have the fault codes read to check for sensor faults . Go somewhere else to get the job done as I feel you are being touched in the wallet.
Nov 29, 2013 | 2006 Audi A4
Carrier Performance Boost 80 has a status light flashing on the furnace, 3 times fast followed by 3 times slow. What does that mean?
this indicates fault 33, on inside of access panel will tell you faulty switch. i believe off top of my head is pressure switch open, this a safety switch to verify that inducer fan is working, several things besides a failed part can cuase this, there is a rubber hose going from the inducer fan houseing to the safety pressure switch, remove hose from fan housing and run a small stick ,wire or torch tip cleaner, down the acces port, calcium builds up inside the port and blocks the sampling of pressure, reassemble and try it, if this works add it to yearly maintenance could need new switch or inducer fan motor, these need to be replaced by a tech, also birds can block flue pipe
Feb 02, 2011 | Heating & Cooling
E Machine T6534 fails every 6 to 9 months
This could be caused by the processor or fan,But very unlikely to be the mother board.
May 28, 2009 | eMachines T6534 PC Desktop
Radiator fan spins after shut off
the fan running on could be a problem fan relay or coolant system sensor
manufacturers recommend a timing belt change at 100,000 klms so you will be safe there for a bit
At the 100,000klms mark replace the belt, crank and cam shafts oil seals , idler pulleys and hydraulic adjuster as the seals will be starting to leak as will the adjuster and oil is not friendly to timing belts
it is a vw so maintaining the car properly may get you another 100,000 klms but the reliability of the car decreases each year
best course of action is regular servicing with periodic fault code reading
oil and filter changes every 10,000klms
Mar 24, 2017 | 2007 Volkswagen Jetta 2.5 Sedan
Need DVR Surveillance Computer Fan
Any 8cm or fan listed as an 80 should work in your system. Just make sure you use one that has the same # of pins as the one you are replacing. Here is a link that should help: http://www.comparestoreprices.co.uk/computer-parts/akasa-internal-system-fan-8cm-3pin-dfs802512m.asp
Hope this helps & please remember to rate my answer. Thanks.
Jan 22, 2009 | Computers & Internet
American fridge freezer keeps freezing up and fouling fan We have switch fridge off and defrost manualy. This fridge is under two years old and we have had to do this at least six times .I have already...
Sounds like either the defrost heater or the defrost timer needs replacement. IF you can get to the heater and check its continuity then you can suspect the timer
Jul 25, 2008 | Samsung Refrigerators
Panasonic PT-50DL54 problems
there actually was a class action law suit on these tv's due to the bulbs.
1 | Load Shortage
2 | Over Volage
3 | Fan Sos
4 | Main 3.3v
5 | Lamp Disable
6 | Gc3fm-Iic
7 | Gc3fs-Iic
8 | Gc3i-Iic
9 | Color Wheel Stop
there is the list of codes so yours is 7. Hope this helps.
Keep me posted.
Thanks,
Lee
Jul 21, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
