Question about Alpine CDA-9833 CD Player
The lights are on but nobody is home! Turned on the car and would not tilt, buttons don't work, no sounds but the display lights are all on and shows the last station we were listening to.
Reset Button and Viola!
Posted on Jan 25, 2009
Plantronics Explorer 320 I can hear but nobody can hear me
ok..try to go your sound settings, maybe the microphone is turned off. OR try to restart your phone just to make that headset is working properly.
Jan 22, 2008 | Plantronics Explorer 320 Wireless Headset
05 nissan almera 1.5 control panel not working
Sounds like on your first attempt to jump start the car the positive and negative cables were reversed blowing your main fuse. Your interior lights are usually controlled by a switch next to your speedometer or the dashboard. If the switch does not bring the lights/gauges back then it is possible that something else shorted and the vehicle would need to be taken in for service.
Nov 16, 2013 | Cars & Trucks
I have used my Grundig S350 radio almost daily, for the past 6-7 years. I went on vacation for 10 days. When I returned home, I turned on the power, lights light up, etc., but no sound...no matter how...
Hi
Its microcomputer chip may have hanged. Just make a reset ans see whether it helps you. It must help you, i"m sure. To reset it;
S350 incorporates with micro computer chip (the component that
controls how the radio operates). If the radio has been subjected to
abnormal environmental conditions, the micro computer chip may
hang up and the following symptoms may appear
The display shows nothing and the radio cannot be turned on by
pressing POWER & SLEEP button.
The display shows random characters or does not work properly
although the radio can receive stations normally.
In these cases, you might need to reset the radio. To reset the
S350, unplug the external adaptor (if one is being used) and
remove the batteries from the battery compartment. Insert a
pointed object, such as straightened paper clip, into the RESET hole
on the right, front side of the radio and gently press and release the
button inside the hole. Then plug in the AC adaptor or reinstall the
batteries
OK.
Jul 13, 2011 | Grundig S350 AM/FM/SW Radio
Display panel works, but oven will not come on
I take it the oven will not heat. there is a safety thermo inside the grilles. it can be reset.. turn the power off at the breaker... remove the grille..inside of the door. then look inside the thermo is has two wires going to it and a red button in the middle.. push the red button down it will reset the thermo with a click... replace grille and restore power... hope it helps.. replace grille
Sep 19, 2009 | Dacor Epicure 30" Double Wall Oven,...
Hitachi projection tv was turned on and off repeatedly by child
sounds like you have lost the power supply , probably high voltage. That is what drives the tubes. Your low voltage is working because you have audio.. Proably not an in home repair. Good luck
Jul 09, 2009 | Hitachi 61SWX10B 61" Rear Projection...
No Sound
when the amp is turned on does the unit make a clicking sound a few seconds after the display lights up.
if not the amp's is not happy with it's power or could have a speaker short. Check the display for a fault warning.
Otherwise check you speaker connections.
confirm that and A and B main speaker buttons are correct.
Try some headphones, if you get sound out of the headphone things might not be too bad, if nothing is output remove all your cables and try again.
Yes I know that can be nasty, so label all the cables first.
Jan 21, 2008 | Yamaha RX-V1500 Receiver
Alpine CDA-9833 CD Player Logo
109 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
