Question about Iomega 4TB ix2-200 StorCenter Network Storage
Port forwarding I know the ports that need forwarding and the IP address (it's all given) but when I go to my Time Capsule (router) and enter the ports it still doesn't work. I need to know if I use all ports (50500, 443, and 80) or just 50500? Do I put the port in UDP or TCP? Private or Public?
2 Suggested Answers
SOURCE: I installed the Iomega 1tb
Check tcp ip settings of your harddrive. Make sure it is in the range of your local network. check the ping command from computer if you get reply then it is in network. Then you can use it. Make sure network cable is fine. Let me know if you need further assistance. Thanks for using FixYa.
Posted on May 17, 2011
I got a Motorola wired modem and it dosn't let me play xbox live why?
you may have to open a port that you xbox can use to connect to xbox live
    • 1 Connect only your Xbox and computer to the Internet. Disconnect all other devices. This is done to easily determine the Xbox's IP address, which is used in the Port Forwarding process.
    • 2 Open the Windows Command Prompt from the Start Menu. Click "Start > Run...," then type in "cmd" and hit "OK."
    • 3 Enter "ipconfig" n the command prompt. A list of IP addresses pop ups. Write down the IP address of your computer.
    • 4 Open your router setup utility through a web browser. Use the given directions from your router manufacturer to do so. Generally, the configuration page is opened by inputting the router IP address into the URL in the following format: http://123.456.7.8/ (where the IP Address number is unique to the router manufacturer).
    • 5 Open the "DCHP Client List" section of the router setup utility. This lists the devices currently connected to the Internet through the router, which is your computer and Xbox. Write down your Xbox's IP address (in this case, the one that is not your computer's IP address).
    • 6 Navigate to the "Virtual Servers" or "Port Forwarding" menu in your router setup utility. Most manufacturers have a side menu on their router setup utility, which is generally a section under your "Firewall" settings.
    • 7 Input the following port numbers and your Xbox's IP address into your router's port forwarding configuration:
      TCP 80
      UDP 88
      UDP 3074
      TCP 3074
      UDP 53
      TCP 53
      Placing these numbers in the port forwarding menu opens up the required ports that your Xbox needs to connect to the Xbox LIVE network. Save this configuration.
    • 8 Start up Xbox LIVE to check your connection. If you have no problem connecting, then you have successfully forwarded the required ports.
Jun 04, 2011 | Video Game Consoles & Games
Port forwarding for model number F7D5301
To setup port forwarding on this router your computer needs to have a static ip address. Or you can take alook at our Static IP Address guide to setup a static ip address. When you are finished setting up a static ip address, please come back to this page and enter the ip address you setup in the Static IP Address box below. Open a web browser like Internet Explorer or Firefox. Enter the internal IP address of your router in the address bar of your browser. If you do not know your routers internal IP address please read our How To Find Your Routers IP Address guide.
The address bar has http://www.fixya.com/AnswerQuestions.aspx#top in it. Just replace all of that with the internal IP address of your router. By default the IP address should be set to 10.1.1.1.
We do not currently know the default username and password for your router.
Click the NAT button near the left of the page.
You should now see a new menu. In this new menu, click Port Forwarding.
Enter the name of the program into the Description box. It doesn't really matter what you put into this box, but something that will remind you why these ports are being forwarded would be a good idea.
Enter the port to forward into the Public Port and the LAN Port boxes.
Use the Protocol Type drop down box to select the protocol type of the ports you are forwarding.
Enter the ip address to forward these ports to into the LAN IP Address box. If you are forwarding ports so you can run a program on your computer, you should enter your computer's ip address into that box.
Put a checkmark in the Enable checkbox.
When you're finished, click Save Setting near the top of the screen to save your changes.
And that's it! You're done!
Feb 05, 2011 | Belkin Basic Wireless Router
How to set port forwarding?
Open a web browser like internet explorer or Netscape. Enter the ip address of your router in the address bar of your browser. By default the IP address should be set to 192.168.1.1.
You should see a box prompting you for your username and password. Enter your username and password now. By default both the username and password are blank. Click the Ok button to log in to your router.
Click the Firewall button near the top of the page. Use the Protocol drop down box to select the protocol type of the ports you are forwarding. If you are forwarding a single port, enter that port number into the LAN port range, Left WAN port range and the Right WAN port range boxes. If you are forwarding a range of ports, enter the lowest number of that range into the LAN port range, Left WAN port range box. Then enter the highest number of that range into the Right WAN port range box. Enter the IP address to forward these ports to into the LAN IP Address box. If you are forwarding ports so you can run a program on your computer, you should enter your computer's ip address into that box. When you are finished, click the Add button.
When you're finished, click Save near the bottom of the screen to save your changes.
And that's it! You're done! Hope this helps.
Dec 22, 2009 | U.S. Robotics USRobotics USR5461 Wireless...
Problem connecting with mates on fifa 09 on ps3.
here is the link for your port forwarding configuration:
http://kb.netgear.com/app/answers/detail/a_id/1166
here is the link for HOW IS PORT FORWARDING CONFIGURE:
http://kbserver.netgear.com/kb_web_files/n101145.asp
Instructions for RP614, MR814, WGR101, WGR614, WGT624, WGT634U, WGU624, WGM124, or WPN824 These routers do port forwarding by assigning port numbers to a "service" that is associated with the application you want to run.
To Let an Application Use Port Forwarding
  1. Type the router's address in an Internet browser's address bar. (By default the router's address is 192.168.0.1). The Setup Wizard appears.
  2. Enter the router's username and password.
  3. Under Advanced, click Port Forwarding on the left menu bar.
  4. A Port Forwarding Screen (Varies Slightly by Router)
  5. From the Service & Game (or Service Name) pull down, select the service that you will host. The services the router knows about are listed here. If the service does not appear in the drop down, add a service as described in the next section, then return to this step.
  6. Enter the IP address of your local server in the Server IP Address box.
  7. Click Add.
  8. Click Logout to exit from router settings.
To Add a Service for These Routers
To define a service not in the Service Name list, determine what port numbers are used by the service.
  1. Click Add Custom Service.
  2. Enter the first port number in an unused Start Port box.
  3. If only one port number is to be forwarded, enter the same number in End Port. To specify a range of ports, enter the last port to be forwarded in the End Port box.
  4. Enter any name you choose for the service.
  5. Click Apply.
Apr 03, 2009 | NetGear WGR614 54Mbps Wireless Router...
Port Forwarding
at the time of portforwarding in that you have to give the port number of the device which ip address you put in means if ip cam is there you give the port number for that example 90 you give then you have to give the device.
Jul 24, 2008 | Linksys Wireless-G WRT54G Router
Utorrent downloads with WRT54GL?
Before we can forward ports for Utorrent, we need to figure out what ports Utorrent is using. Here is a brief walkthrough on how to do that. Go ahead and open up Utorrent.
Click Options in the menu at the top of your screen. In the list that drops down click Preferences.
Click Connections on the left hand side of the Utorrent program. You should now see the menu shown in the screenshot above. Make sure the Enable UPnP box is unchecked. The number in the Port Used for Incoming Connections box contains the port you need to forward. You can change the port number, if you want to. Please enter the port you chose into the box below.
Utorrent's Port for incoming connections To setup port forwarding on this router your computer needs to have a static ip address. Take a look at our Static IP Address guide to setup a static ip address. When you are finished setting up a static ip address, please come back to this page and enter the ip address you setup in the Static IP Address box below.
Do not skip this step! Please enter the static ip you want to forward to: 192.168.1.
Open a web browser like internet explorer or Netscape. Enter the ip address of your router in the address bar of your browser. In the picture above the address bar has http://www.google.com in it. Just replace all of that with the ip address of your router. By default the ip address should be set to 192.168.1.1.
You should see a box prompting you for your username and password. Enter your username and password now. By default the username is blank, and the password is admin. Click the Ok button to log in to your router.
Click the Security link near the top of the page.
Remove the checkmark from the Block Anonymous Internet Requests checkbox.
Click the Save Settings button near the bottom of the page.
Click the Applications & Gaming link near the top of the page.
You should now see a new menu. In this new menu, click Port Range Forward.
Port Range Application Start End Protocol IP Address Enable To Both 192.168.1. We will list a series of lines here that will show you exactly how to forward the ports you need to forward. Utorrent requires you to forward the ports you entered above. Go ahead and enter the settings shown above into the Port Range Forward menu.
When you're finished, click Save Settings near the bottom of the screen to save your changes.
Feb 21, 2008 | Linksys Wireless-G WRT54GL Router
Port forwarding
What is the manufacturer of your router so I can get a user guide and taylor the instructions if needed?
Generally I would statically address the device to be forwarded to. If your router address is 192.168.1.1 and Subnet mask of 255.255.255.0 and it's DHCP server controls address 192.168.1.100 for 50 leases to 192.168.1.149 then consider using the range 192.168.1.2 - 192.168.1.99 uniquely as static IP addresses. There are more starting at 192.169.1.150 but let's ignore them for now. In the network adapter to recieve port forwarded content assign a static IP address based on the above as say 192.168.1.15 with a subnet mask of 255.255.255.0 and a default gateway of 192.168.1.1. The DNS addresses should also be static however depending on your router there may be an option. Some routers allow their address to be entered as the DNS address and pass requests as appropriate to the DNS servers loaded in their lan configurations, otherwise you will enter your ISP supplied DNS addresses into the network configuration.
Now that we have established a stable IP address to forward the port to we need to tell the router everything it sees for port 5060 gets forwarded to IP Address 192.168.1.15 port 8000. If detailed instructions are needed I will need to know the manufacturer and model of your router.
Please provide the additional information and any questions in a response to this problem and I will respond when available.
Dec 25, 2007 | Computers & Internet
How is Port Forwarding Configured?
To Enable Port Forwarding for MR314 or RP114 1. Type the router's address in an Internet browser's address bar. (By default the router's address is 192.168.0.1). 2. Enter the router's username and password. 3. Click Advanced > Ports on the left menu bar. 4. Enter the first port number in an unused Start Port box. 5. If only one port number is to be forwarded, enter the same number in End Port. To specify a range of ports, enter the last port to be forwarded in the End Port box. 6. Enter the IP address of your local server in the Server IP Address box. 7. Click Apply.
Feb 19, 2006 | NetGear (RP114NA) Router
Port Forwarding
Feb 19, 2006 | NetGear MR314 802.11b
Port Forwarding
Feb 19, 2006 | NetGear RP114 Router
Iomega 4TB ix2-200 StorCenter Network Storage Logo
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
