Can I change it to a 6600mAH battery without problems? Or does it have to be a 5200mAH battery? Thank you very much for your help!
SOURCE: i have dell inspiron 1100 with 6450 MAh battery
MAH is short for Milli Amp Hr...
4400MAH battery - short time for the battery to discharge....it may work for 4 to 5 hrs....
7800MAH will work longer for say 8 to 10 hrs.....
also depends on what applications u use...if it contains many graphics and you keep watching movies then the working hrs gets further shorter....
hope this clarifies....offcourse...the 7800 will cost you more...than the 4400....
as far as what is suitable to you laptop check the mfg website or the manual that came with the notebook...some times...the power adpator also gives the battery specifications that must be used...
reg
let me know...
Testimonial: "great advice..."
SOURCE: I have Samsung NP-R505H laptop. My laptop won't
You say it isn't charging, but will it run off of AC power? If it isn't getting *ANY* AC power, then it might be the female end of the power jack on the laptop. If it will run on AC, the culprit is likely to be a battery that needs replaced.
SOURCE: price for toshiba Li-ion battery pack
hi, we have found the battery in our store and it is in stock. About the PA3594U-1BRS 10.8v - 5200mah battery - Rating: 10.8V. please click the link and order online :http://battery-uk.co.uk/product.php?keyword=PA3594U-1BRS&x=10&y=14.Both of them are good for you with different capacity, the higher one can last longer. Hope to help u.
Type: Li-ion
Capacity: 5200 mAh, 8800 mAh,
10400 mAh,
Volt: 11.1 V
Size: 209.90 x 47.50 x 20.40
mm
Color: Silver
$ 89.33
Type: Li-ion
10400 mAh,
Volt: 11.1 V
mm
Color: Silver
$ 89.33
http://www.daily-battery.com/sony-vgn-fz38m-battery.htm
