SOURCE: water not coming through nozzle of nespresso essenza
I have had this issue.
I have removed round silver plastic piece from around coffee spout,(gently -do not crack it) I then removed and washed the black spout, I even used a toothpick once, to remove the stubborn coffee ground, Once it was cleaned - it worked perfect. If you run water from the faucet into spout it should flow smoothly. I warn you though, not sure what this does to any warranty, but don't mess with my morning coffee! I hope this helps.
SOURCE: My nespresso machine is not making coffee once
i'm having the same problem. it makes a sort of grinding noise but no coffee comes out.
SOURCE: My machine is a cube
stop being such a fuckig bum and throw that piece of **** out the window....it was trash before you bought it...if you saw a rotten piece of steak, would you put it on your kitchen counter...no, so why would you put this hunk of **** in your window. If you are considering trying to fix this metal pile of ****, do yourself a favor and beat it with a hammer. This retarded machine will probably work better.<3
