Question about LG Televison & Video
Just bought the TV yesterday. In the bright room, with sun shinning, i can not see the picture. Is there a setting that needs to be switced?
  • LG Master
  • 458 Answers
You didn't mention the make or model of your TV but most of the latest do have an ECO setting or similar idea in the set up or picture menu, this means the screen will automatically adjust the picture brightness if the room starts to get too bright, as in the sun shining or if the room gets too dark. Take a look in your instruction book for this type of setting, remember not all models have this & yours may be one of them.
Posted on Jan 16, 2013
2 Suggested Answers
SOURCE: Hitachi 1080i Plasma TV
In the video setting go down to reset. You will only need minor adjustment after a reset.
chrislorrie@sbcglobal.net
Posted on Feb 15, 2008
I have a Samsung 55in curved TV. It has auto dimming. In the evening with the lights out it dims to where it is difficult to see the picture. Can I get rid of the auto dimming?
If the brightness on your TV changes automatically (randomly dims and brightens), you may need to adjust the:
  • Eco Sensor function.
  • - And / Or -
    • Energy Saving function.
    The Eco Sensor and Energy Saving functions adjust the brightness of the TV to reduce power consumption.
    • When you set the Energy Saving function to Auto, the TV changes its brightness automatically depending on what you are watching on the TV.
    • When you set the Eco Sensor to On, the TV changes its brightness automatically depending on the brightness of the room.
Oct 18, 2015 | Samsung Televison & Video
Why is sony bravia dark screen
If your TV seems to be darker than you think it should be, it is possible that the problem is with the light sensor. The light sensor will automatically adjust the picture brightness based on the ambient light that is in the room, (i.e. if the room is bright the picture will also be bright, if it is dark the picture will also be dark).
To turn this feature off go to Settings > General Setup > Light Sensor.
Feb 27, 2015 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Picture settings..? What are the best calibration
You can't use someone else's numbers, even for the same set, and expect them to be perfect. The picture settings are governed by the viewing conditions in your TV room.
Settings such as Brightness can only be set correctly in the room where you are viewing. Brightness affects where you might then set gamma, and contrast, and colour. So just one setting has a lot of impact on several other areas of the picture.
Putting in someone else's numbers will make the picture look different. But that's not the same as the "best" calibration for your TV.
If you want to do a good set-up without spending any money, have a look at your DVDs and Blu-rays for those titles with the THX Optimizer.
Sep 13, 2014 | Televison & Video
Our tv is very bright like the sun is always shinning on it.We tried the setting and cant figure it out can u help
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video or Bright Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
May 01, 2011 | Philips 43P8341 43" Rear Projection...
My sony shows dim, could it be the picture tube. I can see the picture when it is dark in the room; if the sun is out you can see the picture only it is very light.
picture tubes harsly ever go out i have work on curtis mathis tvs from the 70s and their tubes were great most like the leads within the tubes need cleaed in order to do theis take it to you local repair sop an they can burn the filament so that they are bright again.
Jul 01, 2010 | GE 31GT660 TV
Screen dim, black has green in it, contrast and brightness = shin
Since you have replaced the Color Wheel, it sounds like you have not adjusted the Index Delay in the service menu. First reset all of the picture settings you have adjusted back to original factory settings. Then on your Samsung TV Remote and with the TV OFF, Press Mute,Power,123. This will turn on the set and put you in the Service menu. Look for the top setting and select or scroll to the OPTION setting and select and look for INDEX DELAY and select that. Once you have the Index Delay selected use the right and left buttons on the remote to adjust for a picture the has no abnormal coloring and while looking at a program adjust for when the blacks look black with no abnormal coloring. Once that is done, turn off the set then turn the set back on. Now the picture should look normal.
Apr 03, 2010 | Samsung Televison & Video
Dark screen can only see when shins on it you can bearly see it
laptop or desktop sounds like inverter has stopped functioning
Apr 15, 2009 | Computers & Internet
Brightness keeps shifting on Samsung 46" 7 Series 750
I just purchased Samsung series 4 LCD TV yesterday. I had the same problem since my salesman was a kind of stupid. He set the 'Power save mode' to automatic. After fiddle with my TV for a while, I found the solution.
Just change the 'Power save mode' to off, low, normal or high. My LCD TV stopped shifting its brightness.
Jun 23, 2008 | Televison & Video
Snowy Picture
You could have a bad spitter or a fitting could have come loose.First thing to do is to take another TV set right next to the bad TV set and plug in the cable to the other TV set to see if the same issue happens. If it does there is a cable issue. If it does not have a snowy picture, then you should call the store where you purchaced the set for exchange or service. Good Luck
Mar 16, 2007 | Philips 23PF5320 23 in. HD-Ready LCD...
Televison & Video Logo
244 people viewed this question
