Question about Eclipse 180 G2 Sl 180G2 4Gb Mp3 Music & Video Player ,Silver
How do you "set" a radio station?
I "set" the radio station that I want but then when I turn off the player and turn it back on I have to find my radio station again. Is there any way to "set" it?
Radio wont set stations
hi, does the radio go back the standard settings when you turn off the key, if it does than try checking the fuse for the constant power supply as this controls the time memery and the settings for the stations, if not try holding the station button down for 3 to 4 sec
hope this helped
Jun 13, 2013 | 2001 Chrysler Sebring
Why do my settings reset in aftermarket stereo of my 92 mercury cougar
As well as the normal 12 volt line form the ignition switch, there is a 'permanently on' 12 volt lead, which keeps the clock and memories going even when the ignition is turned off. It sounds like the installer has missed connecting this one.
Aug 28, 2012 | Pioneer Audio Players & Recorders
Does not stay set.
your deck has two power sources a main for when your car is turned on so the radio kicks on and a remote which is always on keeping stations and clock powered passively so whoever installed it did it improperly or do to road wear and tear it was jossled lose and can simply tightened after pulling the deck out
Mar 29, 2010 | Sony MEX-BT2500 CD Player
Need to use my car radio frequency for my dvd (make is unknown) player but can't figure out which station!
You want to pick a frequency where there isn't an existing station, so the radio will have a clear signal from the dvd player.
If the DVD player only has a few frequencies to choose from, then tune the radio to each one (with the DVD player turned OFF) and see which one has the most static and the least signal from radio stations in your area.
If the DVD player can be set to any frequency, then just pick a frequency (usually down on the "88" side of the FM band) with the least local signal, then set your DVD player to use that frequency.
Does this make sense? Feel free to ask questions with the "add comment" link.
If this solves it for you, please be sure to hit the "thumbs up" for me!
Feb 09, 2010 | Farenheit DVD-36 Car DVD Player
How to lock in radio station on kenwood face off cd player
once you have the station you want to listen to on the radio press and hold one of the buttons along the bottom of the stereos face for a few seconds the screen should flash for a second or two or it should beep as well to indicate its saved it.
if when you turn the ignition off and then turn it back on the stereo has forgotten the station you programmed you need to remove the stereo from the car and check the wiring at the back of the unit. most of them have a red and yellow wire that are joined by metal push fit connectors, swap these two over and it will then remember the station for you.
the red wire is the switched power lead from the ignition and the yellow lead is a constant live feed for it to remember your settings, if these are round the wrong way it will keep forgetting radio stations you program until you switch them over.
hth
Dec 30, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
Cannot get a radio to set - need directions as I don't have mine
Go to the manufacturer's site and download the instruction set. Hope this helps .
Aug 05, 2009 | Audiovox Jensen Universal iPod Docking...
I have a sansa clip mp3 but i can't turn on the fm radio. help
1) Go into the settings menu, go to FM settings, and make sure the FM Region is set for United States. If you are outside the US, change it to "World"
2) The radio might initially be set for Pause - to test this, turn to a specific radio station that you know you get, and press up on the clickwheel. The "block" icon underneath the radio station should now change to a play arrow, if indeed it was on pause.
Jan 19, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip - not able to playlist listen on car radio w/ adapter
Jan 02, 2009 | SanDisk Sansa Clip MP3 Player
Pre setting the radio station on the keh-p2800 cassette player
HAS TO BE A CONSTANT POWER WIRE THAT CONTROLS CLOCK AND SETTINGS SHOULD BE A 16-14 GUAGE WIRE THE SAY 12+ AND HAS TO BE HOOKED INTO A CURCUIT HAS IS POWERED ALL THE TIME (NOT ONLY WHEN IGNITION IS TURNED ON)
Jul 12, 2008 | Pioneer KEH-P2800 Cassette Player
Eclipse 180 G2 Sl 180G2 4Gb Mp3 Music & Video Player ,Silver Logo
Top Eclipse Audio Players & Recorders Experts
henrysmooth
Level 1 Expert
Joseph Hoffmann
juanmireles1
Are you an Eclipse Audio Player and Recorder Expert? Answer questions, earn points and help others
