Question about Panasonic PT-51HX41 51" Rear Projection Television
Projection TV wil not cut on.
PT-51HX41was working with the blue gun out of convergence arc about 3 inch top and bottom. Finally, unit went out and smelled like flyback had fried. Now, unit shuts off after unplugging ( high voltage). I do not see anything fried inside so I am wondering if I have both a convergence amp issue as well as a flyback transformer issue?
    President:
  • 3,130 Answers
You should first replace the convergence IC's, both of them. Also make sure all the resistors on the convergence IC's are good and not burnt. That's probably what you smelled burning. Good Luck
Posted on Jul 11, 2007
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic PT-47WXC43G green ONLY is bowed on bottom and top
It still convergence chip problem, check big resistors nearby these chips that would be open or devalued and causing problem, specially in green convergence area, your green tube/ gun is just fine and just not getting convergence output signal to show correct image.
I would suggest to download service manual copy of this tv for small fee from any website and fix the issue with schematics help.
Thanks.
May 02, 2010 | Panasonic PT-47WXC43 47" Rear Projection...
Curved picture top an bottom
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 04, 2009 | Samsung HCN4727W 47" Rear Projection...
Green arc across bottom of tv,and a little purple.
Replace Both of your convergence ICs STKs, big black ICs.
Jun 17, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Picture went funny on my PT-47WX53 last night... a blue ghost like arc appeared mirroring the lower portion of the images displayed on the tv a few inches above where they were positioned. Most of the...
You need to replace convergence ICs in TV for correct converge picture.
Below is an image of D board and ICs are marked need to replaced.
If you are familiar with TV repair and knows basic electronics then can do this job OR call TV tech to fix it.
Jan 29, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Blue Projection Gun
It is not the gun ,but the convergence IC that needs replaced providing that you have went into the tv menu and selected convergence and manually adjusted the blue convergence.
Sincerely the Hammerman
May 14, 2008 | Hitachi 53SWX10B 53" Rear Projection...
Red Gun screwy!!
You have a typical convergence problem here that happens on just about every tube type projection TV set ever made. There are two STK IC's that will need to be changed. Best thing to do, if you have any soldering experience on printed circuit boards, would be to get the service manual, locate the convergence amp IC's order the correct parts and not any replacement IC's that cost less the 20 bucks, and change the IC's. If you have no solid state repair experience, play it safe and call in a pro to assist you in this repair. Good Luck
Jun 30, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Severe convergence/pincushion problem on green
projo tvs dont have pincushion problems this product needs a couple of resistors and two stk packs depending on who you go to 300-400
Nov 20, 2006 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-51HX41 51" Rear Projection Television Logo
53 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
