Question about Vtech Kidizoom Digital Camera
Music download doesn't work
When I connect the camera to the PC I can read the SD card and transfer music to it, however, the camera says "no music found". How can I transfer music (mp3-files) to the camera?
  • 423 Answers
Make sure you are transfering the actual file and not the icon. Better to copy and paste it than use media player or some other program
Posted on Feb 16, 2009
I have a Straight Talk LG440 and there is no place for my SD Card, how can I use my MP3 without the SD Card?
  1. Purchase an SD card adapter (Attached link)
  2. Place SD card into the adapter and connect to computer
  3. Transfer content (your music) from the SD card to your computer
  4. Connect your phone to your computer via USB
  5. Transfer the music you downloaded from your SD card to your phones internal storage.
Oct 27, 2015 | Cell Phones
How do I use sd card storage
Hi if you want transfer your apps on sd card go to setting- application manager- choose the app and there you will see a move to SD card button, just press it and after a while your app gona be transferred to memory card. You need do it for every app sepretlly. If you want store a photo's on it go to camera- setting and there press storage and choose memory card. With music create a folder music on it using my files and player should detect it automaticlly if not navigate there.
If you need more help let me know.
regards
Dec 14, 2014 | Samsung Galaxy Tab Tablet PC
I cannot download pictures from my LG Neon gt365 to my computer. What do I need to do? Do I need a USB? Do I need a micro SD? If so, what kind do I need? any help would be great!
You should be able to connect it using a usb cable that will need to be bought separately and a micro SD card installed in the phone. You should be able to buy any micro SD card up to 4GB. Also, if you buy a card with an SD adapter that will allow you to connect the SD card (with a memory card reader) to your computer without the additional usb cable. The manual link is attached: http://www.tmoatt.com/uploads/53/LG_Neon_GT365_UG_English.pdf
Per the manual:
Transferring Music from the Digital Music Service 1. Using your computer, open your preferred PC music management client. 2. Download the selected song to your library. 3. Make sure the microSD™ card is inserted properly into the handset. 4. Use the USB adapter cable to connect the handset to the PC. When you try to connect handset on your PC, the handset displays "Call and Message functions will not be available while connected to USB". 5. Once the USB connection has been established, the handset displays "To avoid data corruption always carry out safe removal hardware on PC after use." and the computer screen then shows the LG NEON device. If the detection does not occur, skip to Changing USB Connection Settings section on page 63. 6. Follow the instruction in the program to transfer music to your handset. n Note If you have a USB hub, connect the handset directly to your computer rather than through the hub. Transferring Music using Windows Media Player 1. Open Windows Media® Player on your computer (version 10.0 or higher). 2. Use the USB adapter cable to connect the handset to the PC. When you try to connect handset on your PC, the handset displays "Call and Message functions will not be available while connected to USB". 3. Once the USB connection has been established, the handset displays "To avoid data corruption always carry out safe removal hardware on PC after use." and the computer screen then shows the LG NEON device.
Jul 23, 2011 | Cell Phones
How do i load music into my new i856 by boost
according to motorola, this phone has bluetooth and micro SD card slot.
if you have computer with bluetooth, then you can pair the computer and phone and simply send music files wirelessly via bluetooth.
if you dont have bluetooth, then you can buy a cheap usb bluetooth adapter from ebay and have a bluetooth enabled computer, then follow above step.
if you have SD card slot on your computer then you can get a SD card to micro SD card slot adapter from ebay or elsewhere, where you can simply put music on then card from pc and then transfer the card to the phone.
here is the phone manual.for safety read the whole manual.
p.55 for music and p.79 for bluetooth instructions.
http://www.motorola.com/staticfiles/Support/US-EN/Mobile%20Phones/i856/US-EN/_Documents/Static_Files/i856_UG__%20Boost_NNTN7815A_.pdf
Nov 06, 2009 | Motorola Mobility i850 Cellular Phone
I am adding music on SD card, by a Mac, but when put card into ph, it does not transfer to "My Music", it transfer to audio/ringtones
make sure you read the manual about your phone to see which music file format does it support(MP3, WMA etc).
May 31, 2009 | LG Vu CU920 Cellular Phone
LG KC550
kk to add music make sure you syn the phone and the cp do the data and all then put .mp3 on all the media files and see if it works. Then if that doesnt go to computor format the card and then put it in the phone. Otherwise you need new stuff.
Mar 13, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
I have LGKS360 and i insert micro sd card to my phone and try to transfer music from my pc but i can not do it.
simply check the u correctly insert the your micro SD card and check the manual of your phone which type card its support. After it select the data storage type then try to transfer the music. Its work
Feb 26, 2009 | LG KG800 Cellular Phone
Cant transfer music file to my lg ku990 via usb from pc to phone
Instead of loading the music manager, click on file in the LG Suite box, and then click 'content'. This will connect without a problem (at least it did for me, despite music manager not working), and then drag and drop music from your pc files, onto your phone. Hope this helps.
Jul 27, 2008 | LG KU990 Viewty
Putting music on cell phone
MUSIC
This menu needs to be supported by mini SD Card.
It plays the music stored in the mini SD Card.
Copy the downloaded music from PC to mini SD Card,
and play the music stored in the mini SD Card through
your mobile phone.
Store music in the mp3 folder on the SD card.
1. Press [MENU] .
2. Scroll through the downloaded music to display the
music you want.
3. Select the music you want to play then press
[PLAY] or press [MENU]. Then select “Setting”,
press [OK], then 1.All Repeat, 2.Repeat,
3.Random.
Press [OK].
  • “mini SD Card” is connected to your phone, press
[MENU] to select 1. Setting, 2. Erase (Erase This/
Erase All), 3. Information.
Mar 30, 2008 | Audiovox CDM-8940 Cellular Phone
Transferring MP3 files from PC "C" drive "My Music" folder to SD card
you may want to try downloading only those that didn't download the first time. Sometimes when you try to download a large file (all the songs) it causes the "error message" you talk about. You may want to delete files already downloaded, or save the files downloaded to a different file folder, and try the download again.
Dec 27, 2007 | iLO (2 GB) MP3 Player
Vtech Kidizoom Digital Camera Logo
165 people viewed this question
Top Vtech Cameras Experts
Tony
Are you a Vtech Camera Expert? Answer questions, earn points and help others
