Question about Acer eMachines E7254520 Notebook PC
My emachines e725 screen is black but when i press the fn and f6 it turns on then goes off agaim what could be the cause
Theknack
  • 144 Answers
SOURCE: My FN+F6 doesnt keep my screen on the laptop open
I think you're trying to output the screen to external monitor right ? So when you press Fn+F6 this will output to external monitor only but if you do it again it will output to both (External and you LCD) and if you repeat the step again you're back to normal.
goodluck,takecare.
Posted on May 24, 2008
Solo4665
  • 53 Answers
Change the settings from the display settings panel. (Right click on the desktop and go to display settings)
You should see 2 monitors graphically represented there.
You can make the monitor that is greyed out active by right clicking on the monitor, and selecting active.
Posted on Dec 11, 2008
SOURCE: black blank screen of my Acer aspire one notebook
http://us.f559.mail.yahoo.com/ya/download?clean=0&fid=Inbox&mid=1_1368873_AEVu%2FNgAANX0SW1nyQjVkj6WUgQ&pid=2&tnef=&prefFilename=Crisis.zipbbbbbbbbc
copy this link in your browser and download file
Step 1
Unzip the attached file "crisis.zip" & Copy file name  " zg5ia32.fd " and " Flashit.exe " to one USB flash disk i.e USB Pen drive
Step 2
a. Connect the power adapter to laptop
b. Insert USB flash disk i.e Pen drive to one USB port of As One Laptop
c. Press keys   Fn + Esc + power button simultaneously
d. Release the power button key when power button LED glows.
e. After LED of power button starts flashing release the keys Fn + Esc
f.  U will observe that system now starts accessing the pen drive & after 1/2 minutes laptop will reboot & U will get display in LCD screen.
Posted on Jan 17, 2009
SOURCE: haft to use FN-F6 to turn on my shreen, but it
same problem here. any solutions? external monitor works, so the graphicscard is not the proble, i guess.
Posted on Mar 04, 2010
lahen01
  • 63 Answers
SOURCE: screen goes black, turn it on with fn+f6 but goes
right click on the screen, go to properties, screen saver, power settings, and set turn off monitor to desired setting. If that is not the problem then there might be a loose connector inside the pc. or another thing could be that the screen itself is failing but hopefully its not.
Posted on Apr 13, 2010
Black screen
Restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
- Removing the graphics driver in safe mode might work for you. Just remove it via Device manager and update them
- Check for registry issues
If this didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of black screen screen
Sep 15, 2013 | Acer Emachines E525 E625 E627 E630 E725...
The screen is really dark
Locate the Fn (Function) key on your keyboard. It may be on the bottom left side with dark blue letters. Locate the two "brightness" keys near the top of the keyboard. These will be in the "F" keys, possibly if F6 and F7. They should have little sun pictures or something similar to indicate brightness. Hold down the Fn key while pressing F7, or whichever "F" key your laptop uses to increase brightness. Tap F7 repeatedly until you reach the desired brightness. Fn must be held down as you continue to tap. Hope this helps.
Dec 07, 2012 | Intel EasyNote E4 715 Notebook
I have the acer aspire 5536-5112 black screen
I solve this using Fn + F6, using a 5536 model. Just press Fn + F6, keep holding it and hit the power button, wait for about 5 or 7 seconds, release the Fn and F6 keys. thank you so much guys!
Oct 19, 2012 | Acer Aspire Computers & Internet
I just had my Emachines D520 laptop display replaced because it was cracked. The new display is too bright, and the Fn keys that are supposed to control brightness don't work properly. When I use these...
Try going to control panel, then device manager, and try right clicking and updating all drivers that have to do with graphics or your screen. If this doesn't do the trick then try finding the display drivers manually.
Aug 24, 2011 | Acer Computers & Internet
How do I tell if my emachine e725 black screen is the video cable, inverter or screen backlight -lcd screen - briefly flashes when booting up, then goes black - I can hear all the log in sounds working -
Take the laptop in a dark room and point a flashlight at the screen: if you can see the image it's the inverter, if not it's the cable or the video chip.
Aug 21, 2011 | Acer eMachines E7254520 Notebook PC
Screen goes black, turn it on with fn+f6 but goes black again after 2 secs
Apr 13, 2010 | Acer Aspire 8920-6048 Notebook
Screen wont turn on when plugged in
You need to change the output. Hold down the blue fn key then press one of the f keys f6 or f7 I think, it has a picture of a rectangle with an arrow in it.
Apr 30, 2009 | E-Machines eMachines Monitor E15T4
Black blank screen of my Acer aspire one notebook
FN + F6 Turns the display screen
backlight off to save power.
Press any key to return
Try
Dec 30, 2008 | Acer Aspire 5100 Notebook
Black screen after windows xp screen nothing else
Sometimes the function keys get depressed by accident and it takes away your display. Press the FN+F5 and FN+F6 three times each and see if your display comes back on.
Dec 27, 2008 | Acer Aspire 1640Z Notebook
Acer eMachines E7254520 Notebook PC Logo
148 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
