Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Help! chaimberlain/sears 1/2 hp door opener prob.
Sounds like you're the guy to ask. I replaced the worm and drive gears, along with the parts that came with them. When I try to run it (with or without the chain on), it goes a few inches, then reverses. The RPM sensors are not touching anything. wires all plugged back in. Force adjustment at max, both up and down. Parts lubricated. Light on back flashes 5 times. Can you figure this one out? THANKS!!! Ken
  • 2 more comments
  • kjkessler1 Jan 27, 2009
    but this happens with the chain totally off and the sensors touching nothing as it begins to travel. Still same solution?
    it flashes 5 times
    lights are on and aligned... what else could the lights be?
  • gofase2004 Jan 27, 2009
    I replaced the gears and the door will only go a few inches then comes back
  • 118 Answers
Fist, turn down the force settings to half. The force settings can damage the door when turned up that high.. Your problem is with the limit settings. This is the three white screws on the bottom with the cover off. You will have to take the bottom off the gear and sprocket assembly and place the limit in the position that the trolley is and adjust the other two screws accordingly.
Posted on Jan 26, 2009
  • 1 more comment
  • Vince Heuser Jan 27, 2009
    After the opener reverses, does the lightbulb on the opener flash?
    You have an issue with the safety eyes also. Make sure the lights are on on the eyes and if not align eyes so that they are pointed directly at each other.
    That is what the lights mean. This is one I would have to check out. I suggest you call a tech or just buy a new opener. If you are willing to install yourself you are better off buying your own.
Is there any adjustment for the gear drive sprocket that meshes with the worm drive? my gear is not engaging any more
If your drive gear is not meshing with the worm gear it is because it is worn out. You'll need to replace it post haste. The part number is 41A2817 and is available at Sears or any good door opener service company.
Dec 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Had 1/2 hp sears/craftman chain drive garage opener for a number of years but recently garage door did not open all the way. Discovered worm gear and main gear worn out so replaced them with kit from...
Make sure you put the black cup back on the end of the motor shaft and that it is pressed all the way on. Make sure the RPM sensor is plugged in. If neither of these are the issue, then you probably did not have the motor shaft pushed all the way back when you tightened the coupler after replacing the worm gear. Loosen that coupler up and from the front of the motor (opposite end in which the coupler is on) push the shaft back as far as it will go. Hold it there while you tighten the coupler back up and then try it.
Jan 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door motor dead
Keep checking for loose wires. Nothing about changing the gear should cause the motor to stop running. Check the wires on the start capacitor and follow the white wire from the motor and make sure it is connected.
Dec 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door only opens 4 inches then reverses and stops
you need to replace gear when the door is fully closed. then do your tweaking.
Jun 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need part 41A2817 drive/worm gear kit for Sears
as long as the door is less than ten years old, sears will stock the part you need. you can contact them through this link.
http://www.searspartsdirect.com/partsdirect/index.action?psid=58709328&sid=PSx20071217x00001a
Apr 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener will not work after gear replacement
From your description it sounds like you forgot to plug in the RPM sensor.
Mar 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener motor will not open garage door
It sounds like you did a really good job! My Craftsman 1/2 hp gar. dr. opener has a red reset button on it on the l/h side as you are looking at the light/motor from the garage door opening. You have to take the light cover off to be able to see it. My reset button is on the same side as the ground wire. You might check the ground wire while you're there. I really hope that this fixes it for you (and me). I'm quite sure it will as you know your way around the garage door opener already. Good Luck and Let me Know (Please) if it fixed it or not. If I think of anything else, I'll let you know. Have a Good Day!
Jan 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Power Drive 1/2 HP - motor runs but does not move chain
I have the same problem. I just removed the cover and discovered a nylon gear had been worn out. I found lots of shavings inside the cover. The nylon gear is beneath the exterior chain gear. I am looking for information on how to replace it, if I can find the part. If you decide to look at yours, unplug the power and remove the sheet metal screws securing the bottom portion of the cener cover to the front and back covers. Then just remove the upper screws from the center cover. Good luck.
Oct 08, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
192 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
