Question about M-Audio OXYGEN 8 USB Controller
Service manual for M-Audio Oxygen - M-Audio OXYGEN 8 USB Controller
Have a 2009 silverado codes p0053,p0059 show chaned sinsors light still comes on
This is a heated oxygen sensor and the computer is detecting that there is a problem with the heater portion not working. And the other code is caused because the heater is not working.
This could be a fuse, wiring, a connector with a poor connection, or the heater in the oxygen sensor (replace oxygen sensor in that case).
Generally oxygen sensors should be changed every 60,000 miles as a regular maintenance item. And when I replace mine, I get better gas mileage (also my engine is more lively). So I see this as a money saving thing myself.
But just about everyone I know will REFUSE to replace their oxygen sensors for some reason???
Anyway information for troubleshooting and/or replacing this would probably be in an aftermarket repair manual for your vehicle (auto parts store). But this information would for sure be in a Factory Service Manual set for your vehicle which you can order from your dealer.
Aug 17, 2014 | 2002 Chevrolet Silverado 1500
My m-audio oxygen 8 got wet. is it destroyed?
no not completely if you take it to an electronic store they usually can fix it
Dec 29, 2011 | M-Audio Oxygen 8 V2 Midi Keyboard
Hi i can't get my m-audio oxygen 8 minni key bord to make sound when i plug it in to my proo tools 8 m-powered essential can you please explain to me how it works
Oxygen 8 is a MIDI keyboard only.It does not produce any sound of it's own.
It opperates with instrument software that either plays as a standalone(a self contained program)or as a virtual instrument(VST,DXi)in a Digital Audio Workstaion(DAW).Sonar,Cubase,and Ableton are examples of DAWs.
Jul 10, 2011 | M-Audio OXYGEN 8 USB Controller
Where is the oxygen sensor on a 2005 Hynudai
Go to www.hmaservice.com and register( Vehicle by VIN). Afterward, you have access to shop manuals, service bulletins, wiring diagrams, etc. about your vehicle.
Sep 26, 2009 | 2005 Hyundai Sonata
Oxygen sensor
you need to borrow the oxygen sensor wrench from autozone or whereever you bought the sensor. Section 03-14: Engine Controls, Electronic 1996 Taurus, Sable Workshop Manual REMOVAL AND INSTALLATION -------------------------------------------------------------------------------- Heated Oxygen Sensor (HO2S) SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Oxygen Sensor Wrench T94P-9472-A Removal and Installation Disconnect battery ground cable (14301). Refer to Section 14-01 . On 3.0L (4V) engine remove cowl extension and right side of leaf screen. Disconnect engine control sensor wiring (12A581) from heated oxygen sensors (HO2S) (9F472). Do not remove harness connectors from the brackets. Raise vehicle on hoist. Refer to Section 00-02 . NOTE: If excessive force is needed to remove a heated oxygen sensor, lubricate the heated oxygen sensor with penetrating oil prior to removal. Remove heated oxygen sensors from exhaust manifolds (9430) using Oxygen Sensor Wrench T94P-9472-A. To install, reverse Removal procedure. Apply a coating of anti-sieze compound to threads of heated oxygen sensor. Tighten heated oxygen sensors to 34-46 Nm (26-34 lb-ft).
Jun 13, 2009 | 1996 Ford Taurus
Where & how many oxygen sensors do I need for my 1997 Ford Ranger XLT Super Cab
Look before and after the catalytic converters. They will have wiring connected to them.
Apr 20, 2009 | 1997 Ford Ranger SuperCab
M-Audio OXYGEN 8 USB Controller Logo
27 people viewed this question
Top M-Audio Computers & Internet Experts
Gareth Cockram
Gareth Cockram
mukhtar21 shaikh
mukhtar21 shaikh
Jim Goldsmith
Jim Goldsmith
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
