Home | Cyberhome | CH-DVD 300 DVD Player | Unit WILL NOT Turn ON
Cyberhome CH-DVD 300 DVD Player
Problem for Cyberhome CH-DVD 300 DVD Player
By JakeXL on Jul 11, 2007
The unit will not TURN ON via button front, rear or remote. The 110 V outlet is HOT. This unit has the Power Cord permanently attached so it does not have a ON/OFF Power Switch at the rear. I believe everything in the manual and Trouble Shooting has been addressed. Please Help.
Same Problem
Jun 08, 2008
-   My on/off light will come on for a brief couple of seconds and then go out. My biggest problem is there is a DVD trapped in there. The power did go out when I was out of town last weekend. Any ideas?-   needhelpindc
May 16, 2008
-   the unit will not turn on and I thought it was a problem with the power supply but still, after fixing a new one it did not work, so i am wondering wat the problem really is -   malep
May 08, 2008
-   it wont turn on...-   Guest
Jan 06, 2008
-   my jvc xv-n212 powers on with a red light at the front. but dont have a remote to turn it on. that is to say it is in standby mode. is there any other way of reseting it.coz i have searched for remotes in vain.-   kafulu
Dec 28, 2007
-   Same basic problem -- Nothing happens when I depress the 'On/Standby button.-   thickey
Solution #1
posted on Jul 12, 2007
Somewhat Helpful)
papjr
Rank: Apprentice
Rating: 83%, 7 votes
Although power cord is permanently attached, connections inside machine have broken off (from personal experience)from moving or jiggling. Unplug machine then check and see. That is, unless you are getting an "ON" red or green light when your machine ON. A question, did you have a power outage? In case you had one,and power is restore, the voltage surge can fry almost any electrical components including computer, refrigerator, freezer etc. Solution? ...a good surge protector.
Was this helpful?
Yes
No
Solution #2
posted on Apr 21, 2008
Not Rated)
Neilgw
Rank: Apprentice
Rating: 0%, 0 votes
I have no power going to the unit, I understand while I was away an electrical storm happened and this has knocked a few peoples tv's and pc's out, so if I have had my DVD recorder's bits burnt, is it worth repair or just throwing it away??
Thanks Neil
Was this helpful?
Yes
No
Solution #3
posted on Oct 05, 2007
Not Rated)
tmogc
Rank: Apprentice
Rating: 0%, 0 votes
there is a high pitcg comming from the unit
Comments:
Oct 05, 2007
- there is a high pitching sound comming from the unit
Was this helpful?
Yes
No
Solution #4
posted on Sep 03, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
you have a bloated cap on power supply board which needs replacing - replace 1000 microfarad/16V with same but 35 volt
Popular Solutions for Cyberhome CH-DVD 300 DVD
Questions and Unsolved Problems for Cyberhome CH-DVD 300 DVD
Do you recommend Cyberhome CH-DVD 300 DVD Player?
Answer
Answer
I have a CH-DVD 320 and all of a sudden it will not play a DVD. I can get a dvd in the machine but... (More)
Answer
need a code for time warners ur5u-8700l-twyq remote control for my lg lht854 dvd receiver
Answer
Have a number of the Cyberhome SH-DVD300 or 320; sad they have no address or phone, remove them from... (More)
Answer
I have followed the instructions for powering the unit up from sleep. I have a yellow light no red... (More)
9 Other Users Have The Same Problem - Continued
Comment by OFMGLOL, posted on Dec 21, 2007
just wont turn on when i press the "on" button
Comment by evan57, posted on Dec 20, 2007
the display panel was flashing. I was unable to turn on or off using remote or on the unit. I switched it off from the main hoping that it may reset but know it does not show anything on the display. the only sign that power is going to the unit is the blinking red light in the rear optical port.
Comment by Guest, posted on Dec 02, 2007
unit has power going to it, intermittent at best, a pbs light on the front and red optical light on the back. that is all it will do.
Comment by Guest, posted on Nov 19, 2007
my unit will not play dvd, when i place dvd in unit, turn on screen comes on blue and nothing happens, i push start, nothing, lcd light green, only thing happens i can touch top or bottom button and bar moves left to right. push start nothing, is battery dead, just bought unit last fall,
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Cyberhome CH-DVD 300 DVD...:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 712
Experience: 30 Years of professional repair and design.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
