Question about Bissell 1770 Quicksteamer II Upright Vacuum
How can I clean or open the bissell quicksteamer dirty tank
The tank has dog hair and dirt stuck in the dirty tank. Is the anyway to open it for cleaning?
  • Deni W Jan 19, 2013
    the tank doesn't sit too well for soaking. Buying new seems environmentally wasteful and kind of a rip off. I'd like to just clean what i have.
  • Official Brand Answer
  • 315 Answers
Hi Deni! The collection tank can not be opened for cleaning. You may want to fill the tank with some hot tap water and let it sit for about 30 miutes.
Here's a link to our website if you decide to order a new tank.
http://www.bissell.com/parts/?id=9143&sc=part&partid=4482&cid=ccsocial
Posted on Jan 17, 2013
SOURCE: Bissell 1770 Quicksteamer ii
Looking for ther dang Instructuion booklet which/which I just saw in last day or so/ and it says what model it is.,,
altho its says quciksteamer right under the Bissel product name on the front up by handle and electrical wire holder--the SOLUTION tube runs down around the mortor housing but NO type of heating unit--So I don't get why the call it QUICKSteamer..is another GUESS
with no water is heated except for when I do use hot water or have boild water--not putting the boilng water in to tank tho=the solution flows FINE--and sems to be flowing from all sprouts
I'm not stupid-
I workled for yrs In MY dads aplpliance Co--we reapired Maytag washer & Dryers which seldom needed fixed...my lint brush I will chech & CLEAN AGAIN-- AND Pretty sure ALL FITTINGS ARE seating PROPERLY--just can get it to SUCK--the dirty water back into holder tank-unsit hasnt been used more than a dozen times..amd has worked preffect all those other times..
Seems when all esle SUCKS the vacum cleaner or Rug Shampooer WON'T
Posted on Mar 04, 2008
reddevil6
  • 1673 Answers
SOURCE: Bissell Pro Heat 8910 clogged?
Why the motor sounds muffled I am not sure. When the water is sucked up, it goes directly into the tank. The motor only creates the suction so it can do that. There should be a filter on the rim of the recovery tank lid, is it clean? Other then pulling the top cover off, and then the motor cover so you can inspect the motor, I really don't have a good answer for you. I t may be that that clump of hair when down the chute and into the fan, I have seen that happen with vacuum motors before.
Posted on Nov 18, 2008
whytfang
  • 170 Answers
SOURCE: bissell manual
Sorry this is as close as I could come...but *** covers the Quicksteamer 1970 model...and surely it is the exact same process for yours...as this manual covers several models.....I found it at www.bissell.com.....I hope this helps...good luck and thanks For rating my effort....The Fang
http://www.bissell.com/images/UserGuides/1770_0206.pdf
Posted on May 20, 2009
Vac Belts
  • 701 Answers
SOURCE: Bissell Pet Hair Erase does not vacuum.
It is because the belt is worn or stretched and needs to be replaced. Here are the belts you need and the manual which has instructions:
Bissell Pet Hair Eraser Belts and Manual
Posted on Dec 30, 2009
SOURCE: How do I fix Bissell Quicksteamer leaking from
I have the same problem... seems to be because of a bad, or worn, rubber gasket.
Posted on Jan 02, 2010
When cleaning bissell quicksteamer powerhouse model #2080. I took the dirty water tank off and cleaned it out, I removed The brush, cleaned it & put it back together and now it will not turn on...
It sounds like you didn't get the drive belt seated properly. If that's not it than try the Bissell Consumer Care number is 1-800-237-7691 they have a better troubleshooter guide than I do.
Nov 28, 2015 | Bissell Vacuums
I have a Bissell Quicksteamer plus model # 1950 and when I plug it in it begins to heat the water then trips the circuit. Can this issue be corrected?
Have you cleaned the tanks recently? If not do it.
Remove water from the solution tank and collection tank.
Keep the tanks open and allow to dry in sunlight.
If you can, remove the solution tank and see whether there are any leakage signs where the tube connects to the solution tank. If there are, use an adhesive that can withstand heat and stops the leak.
You can also contact Bissell consumer service on 1-800-237-7691.
Aug 07, 2011 | Bissell 1960-3 QuickSteamer Plus Upright...
There is dog hair stuck in the hose-how do I get
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
nb,.n
May 27, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Where can i order a quicksteamer plus 1950 clean water tank?
I had a look at the Australian variant of this model and located parts number 407-0931 Clean Water Tank.
My best suggestion is that take this part number and contact your local Bissell Service Center, go to the Bissell International website to locate information for your country.
May 26, 2010 | Bissell 1950-3 Quicksteamer Plus Vacuum
Bissell carpet steamer not working
heatman101
rtsdf
Feb 21, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Nov 18, 2008 | Bissell 8910 ProHeat Clear View Upright...
Wanting to clean dog hair and dirt from my bissell proheat
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=608457
Generic problem for all Vacuums
Wanting to clean dog hair and dirt from my Bissell...
Posted by lil1939 on May 19, 2008
I would like to know where I can take my Bissell ProHeat to have it clean and gone over as it doesn't **** up the dirty water like it used to. I don't want to have to drive a 100 miles to have it fix, as I am elderly.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You may want to call Bissell to get a vac dealer in your area to service your Bissell and some of the vac dealers offer pickup and delivery @ a reasonable cost and they will do the service on your Bissell. Not knowing where you are writing from call the phone #’s listed below and they should be able to further assist you. Or you may have to ship your vacuum to the factory or a local vac dealer to service your unit. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST
Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 19, 2008 | Vacuums
Is the front nozzle fitted correctly, Is the tank seated correctly,
On the dirty water tank there is a sponge filter make sure this is clesn,
Nov 19, 2007 | Bissell 1770 Quicksteamer II Upright...
DIRTY WATER
remove the dirty water tank and see if the front nozzle is fitted correctly, also see if the filter is clean on the dirty water tank
Bissell 1770 Quicksteamer II Upright Vacuum Logo
502 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
