Question about Ovens
My ge oven is not heating jtp20w0f7ww
  • DONNIE JONES Aug 26, 2013
    MY GE TRUE TEMP IS FLASHING F7 AND E7 AND WILL NOT TURN ON
What is causing my ge single wall oven with built-in microwave oven not heating, only the fan runs?
Is it the microwave or the oven that is not heating? If the microwave is not heating it is more tan likely the magnetron. If the oven is not heating it could be the element or the control board.
Sep 01, 2014 | GE JKP86 Electric Double Oven
Ge oven jtp18 elements won't heat
The limit switch in a Ge oven usually works or is blown. I would look at the oven sensor located at the back of the oven. It should read approximately 1k ohm at room temperature.
http://www.on-timeappliance.com/ovenrepair.html
Mar 26, 2012 | GE Profile JTP18 Electric Single Oven
Ge gas oven jgbp28dej3ct.. oven pre heats good to right temp but wont maintain temp during cooking.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jul 29, 2011 | GE 30 In Freestanding Gas Range ...
Ge oven will heat up then the pre heat will beep then oven shuts off and the time light will flash 0
heatman101
Apr 01, 2011 | GE Profile JTP18 Electric Single Oven
Oven does not heat to desired temp. It is a GE spectra
heatman101
Jan 04, 2011 | GE Profile JT912 Electric Single Oven
GE Profile JTP85 (installed 1998). The lower heat element in the lower oven will not heat. I can make the upper element heat up by using the BROIL function, but neither element gets warm on BAKE.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
heatman101
Dec 11, 2010 | GE JTP85 Electric Double Oven
Everything works except the the electric oven , it just does not heat please help. its a ge 316417609 free standing range oven
heatman101
Nov 23, 2010 | GE Ovens
Bottem Oven Over Heats
GE announced a recall for some of its wall ovens this week for an overheating problem. Have you contacted a GE dealer yet?
Nov 20, 2008 | GE JRP24 Electric Double Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
