My front loading washing mashing is making a grinding sound, it is coming from pump, what is this?
I have made sure there is not a clog in the drain pipe in the wall or in the tube from the maching to the pipe. after taking the back off of the machine, the grinding sound or a sound that is like a change counter at the bank, starts just before the spin cycle. it spins just fine but does not drain the water and the clothes are soaking wet. also the pump gets very hot to the touch.
  • Washing Mach... Master
  • 17,130 Answers
If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Posted on Jan 17, 2013
  • 1294 Answers
SOURCE: Does not Spin out the water at the end of a load
If it spins the balance is okay. Check out your filter now. And then the pump (after the spigot prob below) Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 06, 2008
SOURCE: GE Front Loading Washing Machine seems to be holding water....
manual
Posted on Mar 21, 2008
  • 20 Answers
SOURCE: washer will not spin, will not spin in any spin cycle
Your water pump is clogged
Posted on Feb 10, 2009
SOURCE: front load model LTF2940ES3 won't spin
I have the same washer and it will wash and drain but not spin. I replaced the door switch and the problem was solved.
Posted on Jun 16, 2009
blueextc3221
  • 15935 Answers
SOURCE: Clothes are soaking wet after the entire wash cycle.
The motor controller is likely bad - not getting to the HIGH spin.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
The digital screen come up with F21. How do I fix this
F21 means the washing machine has a “water draining issue”, meaning the drain pump itself, or the drain hose is clogged and the washer is having problems draining the water out. In other words, the washer is taking too long to drain the water out of the tub. If you have a front load washer then you need to locate the drain pump which is usually located on the bottom front of the machine. If you have a top load washer then you need to make sure the drain hose is not clogged or pinched. The drain hose is located in the back bottom of the washer
Mar 06, 2018 | Washing Machines
Our front load kenmore washer is not draining properly at the end of the wash cycle. At the end of the wash cycle it sounds like it is trying to drain but it does not even spin. Then it seems to run water...
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Aug 31, 2011 | Kenmore Washing Machines
The washing machine does not evacuate water and does not go in spin cycle.
Hi
Daniel
Aug 16, 2011 | Zanussi F1245W Front Load Washer
My washer is giving theOE signal indicating a clog. I drained the bottom tube and cleaned the filter. Still makes a grinding sound when it tries to drain. Drained from the bottom twice more but...
You have a broken drain pump and needs to be replaced. The part number is 4681EA2001D. This is a big job requiring a special tool to remove the spring clamp on the door seal.
Good luck.
Jul 11, 2011 | LG WM0642H Front Load
Elite kenmore washing machine wasnt spinning clothes out, a code f o2 was blinking on front panel,took off white plug and clean filter. had problems with lock control,figure that out,but when spinning out...
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^^^^
Apr 14, 2010 | Kenmore HE2 Plus Front Load Washer
My whirlpool duet front load won't run. I got an f- error code and when i went to run the drain cycle it sound like grinding coming from the pump? Now the drain cylce won't even run the machine just sits...
It sounds like the pump. You can check the drain line for kinks or obstructions, but I didn't like the way you described the sound the pump made. Remove the hoses from the pump and check for anything clogging it, like the occasional stray sock and check the pump impeller. Make sure no blades are missing/broken and that the impeller spins freely. If you find any broken/missing blades or if you can't get the impeller to spin freely, the pump is defective. Sometimes hard objects like coins, pins, etc. can make it to the pump and damage the impeller. Hopefully it's just a clogged pump or jammed impeller. Sure sorry for your trouble and hope this helped. Best wishes.
Sep 08, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
WONT DRAIN
clean the pump and also make sure that the pump motor is powered during draining
May 30, 2009 | Frigidaire GSTF1670A Front Load Washer
My washer began a grinding noise & says
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.(*&$%^
Apr 19, 2009 | Whirlpool GHW9100L Front Load Washer
Kenmore front loader - making grinding noise
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
Mar 14, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Roper washer not draining
okay you say coupler was broken, make sure coupler is on properly, and make sure your pump is clear of debri, sounds like you washed something heavy, make sure your pump is also clear
Apr 03, 2008 | Roper RAX7244KQ Top Load Washer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
