Question about Drills
Bosch GSB20 2RE will run perfectly through variable range if tilted over to the right. Tilt it to the left and it is as dead as a door nail.
New field coils and brushes fitted, all the rest of the drill looks ok. Not sure what the, so called, contact spring (48 on schematic) does. It's present and in place. Drill failed originally, burning out field coil at contact, after drilling heavy concrete at 19mm, supposedly well within it's range. field coil retaining screws had losened and the flexing had led to the coil wire breakage.
  • Ed Pattinson Jan 16, 2013
    As daft as it seems - as soon as I posted this I realised what it was, A broken wire in the flex. Flex it one way and it contacts, flex it the othe way and the contact is broken. Sorted now cheers.
  • 885 Answers
I was going to tell you to check the power cord by the strain relief. Sounds like you got it.
Posted on Jan 19, 2013
  • 16 Answers
SOURCE: Need a new battery for a Bosch 9.6v cordless drill.
call 1 800 346 4103 and give them the 10 digit number, $ 46.25 I believe.
Posted on Jul 16, 2009
  • 61 Answers
SOURCE: trying to drill a solid concrete 10 inch wall
the ideal sollution is to fully service the machine but there may be a quick fix.
remove the 4 screws that hold the black plastic handle assembly, and take the handle off. on the top of the drill you will see an oil filler cap. unscrew using a 10mm allan key.
empty out any old oil. rinse out with some parafin if you like. empty out again . put some new oil in and replace the cap. 50cc of transmission fluid / power steering oil will do the trick. if this dousnt fix it then you will need to replace the o-rings on the pistons, if this is the case, drop me a email and I will send you a parts diagram. paul@wysehire,gi
good luck.
Posted on Sep 19, 2009
  • 50 Answers
SOURCE: I have a Black & Decker DR250 Type 1, 3/8 inch
the coil spring should be attach to the 2 carbon inside it
Posted on Jan 16, 2010
jmgldsmth
  • 1869 Answers
SOURCE: Faulty bosch hammer drill
a bad trigger switch; bosch sells a replacement part
Posted on Jul 24, 2010
muntejaya
  • 10421 Answers
SOURCE: I bought a Bosch PSB
Please check your carbon brushes and replace them if necessary
Posted on Jan 11, 2011
My brand new fridge, one door style will not self close.
front raise 1 or 1 1/2 inches the side that is the door hinge side is 1/2 inch higher then the handle side. Tilt it on a slit angle towards the way that will force the door with the added weight of food on door shelf's. A perfectly level fridge is a useless fridge. If its only mission is for the doors to close from the maximum range its able to open.
Mar 16, 2017 | Refrigerators
Bosch Dishwasher fault E 15 explain
Bosch Dishwasher Error Code E15
Fault Condition:No water in dishwasher or not sensing water.
Repair or Check: Tilt dishwasher back and the error code should disappear. While you tilt it press off button to clear. Stand it back to normal turn back on and dishwasher should run normally.
Parts Required:Tilting machine
Hi i found this answer on this link, scroll down the page and it's the 3rd error code (in red) Hope it helps...
https://removeandreplace.com/2015/10/09/bosch-dishwasher-error-codes-how-to-clear-what-to-check/
Mar 16, 2016 | Bosch Dishwashers
How to make the freezer door on a kenmore elite 74033 tilt
Refrig of the year: Kenmore Elite 74033 Refrigerator
Consumer Reports Rated: Excellent
Hello Charles,
Just when I'm thinking Sears SERVICE is NOT some sort
of sad/bad joke... you put in a Kenmore Elite Model number...
continued search found your Owners Manual... Pages 10 & 16 are what you want
The front should be slightly higher than the rear to aid in door closing... (page 10)
Your refrigerator has two front leveling legs-one on the right and one on the left. Adjust the legs to alter the tilt from front-to-back or side-to-side. If your refrigerator seems unsteady, or you want the doors to close more easily, adjust the refrigerator's tilt using the instructions below: NOTE: Tools Required: 11/16" wrench or flat blade screwdriver.
1. Turn the leveling leg to the left to raise that side of the refrigerator or to the right to lower it. It may take several turns of the leveling leg to adjust the tilt of the refrigerator.
NOTE: Having someone push backward against the top of the refrigerator takes some weight off of the leveling legs. This makes it easier to adjust the legs.
2. Open both doors again and check to make sure that they close easily. If the doors do not close easily, tilt the refrigerator slightly more to the rear by turning both leveling legs to the left. It may take several more turns, and you should turn both leveling legs the same amount... (page 16)
`` After that...
All you have to do to maximize that efficiency is keep the closure area free of pizza boxes, ice cubes or errant frozen food bags.
Hope this was helpful...
Kenmore Elite 74033 Refrigerator Review Kenmore com
Feb 12, 2016 | Kenmore Refrigerators
JD 757 engine stalls and dies when going downhill tilted to the left.
You may have trash in your tank. Check your fuel cap vent too
Jul 16, 2015 | Garden
I have a delta 34-444 table saw, is it a right or left tilt, or how do i find out?
Left-tilt, right-tilt refers to the direction the top of the blade can be tilted when it is not straight up and down. There will be an indicator on the front of the saw, normally pointing to zero. When you adjust the blade away from zero, if it tilts to the left, it is a left-tilt saw.
Feb 05, 2013 | Delta Machinery Delta 34-555 Sliding Table...
Hi i have a bosch SGS45E68GB52 Dishwasher.My problem is the pump runs continually i have taken the left side panel off and water can be seen lifting a small float up and engaging the anti-flood devise....
The float lifts up if there is water leaking into the motor compartment. Get the unit out from under the kitchen bench and tilt it to remove the water. Let it dry and try again.
You will have to find the source of the leakage. Most likely it is the door seal or dripping hose.
Jul 20, 2011 | Bosch Dishwashers
Not sure how to load nails
use left hand, slide spring retainer all the way to the back of nail tray, load a rack of nails into back of nail tray , tilt forward allow
nails to slide forwardthen slide spring retainer back slightly, release and let spring engage nails.
Feb 02, 2011 | Porter Cable 16 - Gauge Finish Brad Nailer...
I have a bosch dishwash e15 check water
I found this solution on elsewhere on fixya. it relates to a little float switch designed to detect water leaks I think. 1. turn off power and water 2. tilt back machine about 45% (have towels ready to soak up any spill off 3. when all the water has emptied, right machine and retry. if the problem keeps reoccurring, you may have a genuine water leak. I had to try a few times but this worked for me and saved me at least 4 days of hand washing over a long weekend. good luck
Mar 18, 2010 | Bosch Dishwashers
Black text only printing dark on right side of page. I jsut put in a new black toner cartridge
My solution
(CAUTION: Never loss balance while tilting printer! You may drop and damage your printer! Hold the printer firmly all the time! Ask someone to help you if needed!)
Here, front of the printer is where you can access the cartridge, back of the printer is where you connect the power cord and USB cable, left is your left, right is your right.
1.Lift the front to keep the printer tilt to its back at about 45 degree
2.Power on printer while it's tilted back, wait untill green light is on
3.Open the front door, red light will be on, then close the door, printer will start up again,wait untill green light is on
4.Repeat step 3 once again, then put the printer back to level position
5.Lift the right to keep the printer tilt to its left at about 45 degree
6.Open the front door, red light will be on, then close the door, printer will start up again, wait untill green light is on
7.Repeat step 6 once again, then put the printer back to level position
8.Print some test page to see if there is any improvement of black print quality.
You may try several times and print several pages each time before you finally cure the problem.
Good luck! And do it safely!
Feb 04, 2010 | Samsung CLP 300 Laser Printer
Drills Logo
60 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
