Question about Radio Communications
I have a GiiNii gn-818 Digital Picture Frame. How do I copy pictures from it?
I am trying to copy pictures off the internal drive on my GiiNii GN-818 Digital Picture Frame without deleting them. The manual only goes into how to save pictures onto the frame. Any help would be appreciated.
SOURCE: GN 6210 with home cordless phone?
try
http://audio.manualsonline.com/search.html?q=GN+6210
Posted on Dec 07, 2007
SOURCE: Insignia digital photo frame won't recognize some .jpgs
When you save in Photoshop make sure you select "Baseline ("Standard") on the JPEG options when you save. That should fix the problem for you. It did the trick for My Kodak SV710 digital frame which wasn't displaying images I had edited in photoshop.
Posted on Apr 03, 2008
Junoon007
  • 1011 Answers
SOURCE: Sungale 7" Digital Photo Frame CA700
Hello sir,
U should install usb driver 1.0 at the location of ur drive. or connect the camera with usb drive and install the driver version of 1.1. it will solved.
Thanks
Don't forget to rate the solution
Posted on May 11, 2008
pauman
  • 248 Answers
SOURCE: Philips digital photo frame 7FFI series
Here`s a tip i found for you...
1. Connect the frame to your PC using the supplied USB connector. Navigate to the \DCIM\100Frame directory and delete all the Phillips advertising pictures there.
2. Create a directory on your PC and put copies of all the pictures you want to display there.
3. Download the free picture resizer utility from Microsoft at:
http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx
(Look for Image Resizer in the right column). After installing it, "Select All" pictures in the directory you created, then right click and select "Resize Pictures" from the context menu. Choose the 640x400 radio button. Sort by size and copy all the small ones into the "\DCIM\100Frame" directory on the frame drive (Called Removable Disk on my PC).
Posted on Jun 20, 2008
SOURCE: GN Netcom GN 6210 - headset, no worky
Not sure what you mean by won't turn on.
If you mean no dial tone when you take it out of the cradle, I have run into this. The solution is to unplug the power cord and then plug it back in which resets the unit.
Posted on Dec 28, 2008
What's your question? FIx CDI Box that give spark to the plug on a Suzuki GN 400 1981
  1. 1981 Suzuki GN 400 L specifications and pictures - Bikez.com
    www.bikez.com/motorcycles/suzuki_gn_400_l_1981.php The 1981 Suzuki GN 400 L and all other motorcycles made since 1970.Specifications. Pictures. Ratings. Discussions.
Jun 21, 2015 | Suzuki Motorcycles
Is there available online an instruction manual for GN 812 Giinii Picture Frame?
I have the same one and was looking for a manual. This link is not for the exact same model, but all the commands were the same so it worked. Good luck! http://static.tigerdirect.com/pdf/GiiNii_GN-811DS_Manual.pdf
Apr 02, 2012 | Cameras
How do I copy pictures from a USB port to the memory in the Digital Picture frame?
it depends on your digital frame becuase some frame cannot be save the picture on the internal memory. if the manual says that you can save or upload try to go setting and look for copy then choose from( memory card to internal or internal to memory card)
goodluck my friend
Jul 13, 2010 | Smart Parts Digital Picture Frame
Cant copy any pictures from computer
You can start copying pictures to SV811 digital picture frame if you get the message “Use PC interface to copy files.” Here are the steps:
Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools:
1. Connect the USB cable from the frame to your computer
2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
Copying pictures from EasyShare software:
1. Install EasyShare software (free download at www.kodak.com/go/sw )
2. Connect the USB cable.
3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
5. Select the frame source to which you are copying.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
7. Click Copy. Pictures are copied to your frame.
8. Unplug the USB cable and press “Home” icon to navigate to your copied pictures.
Feb 03, 2009 | Kodak EasyShare SV811 (8858946) Digital...
Can't transfer photos from computer to digital frame
1. Install EasyShare software (free download at www.kodak.com/go/sw)
8. Unplug the USB cable and on the frame check the pictures that were just copied.
Jan 17, 2009 | Kodak EasyShare M853 Digital Camera
I can't transfer pictures from my computer to my digital frame. When I connect my usb cable to my computer from my digital frame , the frame displays "Connected to computer. Use PC interface to copy files....
Dec 26, 2008 | Kodak EasyShare SV811 (8858946) Digital...
I'm trying to transfer pictures from my computer to the picture f
Dec 20, 2008 | Kodak EasyShare SV811 (8858946) Digital...
Transferring photos from computer to picture frame
3 Doing more with your frame
Copying between your frame and computer Copy pictures, videos, and music via the included USB cable. For wireless copying (EX models only), see Picture transfer software—copying wirelessly.
Connecting to your computer autourg00722003id1479308.jpg Copying pictures to/from your computer Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools. See info.jpg for applicable file formats.
spacer.gif spacer.gif spacer.gif spacer.gif 1. Connect the USB cable from the frame to your computer (Connecting to your computer).
autourg00722003id1967406.jpg 2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, USB devices.
See your computer documentation for more information on copying files.
Copying pictures from EasyShare software It's easy to copy pictures/videos from My Collection to your frame.
  1. Install EasyShare software from the CD included with your frame (Installing the software).
  2. Connect the USB cable (Connecting to your computer).
  4. In the menu bar, select File ® Copy to.
  6. Select Best For Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
  8. Unplug the USB cable and press autourg00722003id1974433.jpg to navigate to your copied pictures.
Dec 16, 2008 | Kodak EasyShare EX1011 Digital Picture...
Westinghouse 7" lcd picture frame internal memory not recognized
You can copy files from internal memory to sd card only. Its one way data transfer.
Sep 05, 2008 | Westinghouse 7" LCD Digital Photo Frame
Radio Communications Logo
93 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
