Question about Vacuums
I have no suction on my vacuum, I have checked everything, belts are good, and hoses appear to be clear of any blocks, any suggestions
  • 2 more comments
  • tnwalkergal Jan 24, 2009
    It is a Dirt Devil, Reaction
    I will give this a try, thank you, that must be about the only thing I haven't tried.
    Thank you I will try this after supper and let you know. Many thanks
  • tnwalkergal Jan 25, 2009
    Well, I ran a wire up the hose, took it apart again, and could not find any clog, I guess it is off to the repair shop for this machine. I do appreciate all your help though.
    President:
  • 1,214 Answers
Please give the model number and manufacturer of the vacuum.
Posted on Jan 24, 2009
  • Mark Egan Jan 24, 2009
    From what I can find without a model number, you need to look deeper into the throat of the vacuum head as it goes up to the hose connection in back, near the bottom. Disconnect at that point and look down into the hose connection to the bottom, or flip over, remove the plate, and look into the hole as it goes up to reach the hose.
    Check if you have vacuum when you disconnect the hose. If you do, the problem is where I described. If you don't the problem is further up the hose.
No suction
I presume the motor is running, take the front brush roller off and check the fan is still intact. Possibly broken fan.
Mar 30, 2014 | Kirby Ultimate G Bagged Upright Vacuum
Miele Vacuum Cat and Dog Upright S7260 Loss of Suction
could be a couple things first make sure the hose is clear check real good the other is make sure your bag is good and tight and clean and make sure you have no holes or tears in the hose
Mar 07, 2014 | Miele Vacuums
No suction from canister on electrolux guardian model c154e. green light on switch is on
Have you remove the hose and checked the suction at the intake of the vacuum? If the motor is running there will be suction.
If there's suction here, attach the hose to the vacuum, turn it on, and check the end of the hose for suction. If there is none or very little, there's a clog or bad leak in the hose. The easiest way to check for a clog is to drop a coin in one end, lift that end up allowing the coin to drop through to the other end and out. If it drops through, the hose is clear. If not, the easiest way to clear it is to plug the hose in to the exhaust port of the vacuum, place the other end into a large garbage bag or point it outside, and turn on the vacuum. This will usually clear a blockage.
Leaks that are severe enough to result in no suction will be readily apparent as tears, cracks, or cuts in the hose. A crushed hose will also result in the loss of suction.
If suction is fine at the end of the hose, do a visual check of the wands. It's unusual for them to be blocked, but not impossible.
Check the power nozzle above and behind the brush and where it attaches to the wand. The elbow can catch long objects resulting in a blockage.
If there don't appear to be any problems with the above mentioned items, you need to take the vacuum, with attachments, to a repair shop to have it checked. It may need a new motor, but that would be due to worn out or broken fans, and that is unlikely with Electrolux vacuum motors years older than that.
Dec 01, 2013 | Electrolux Guardian Bagged Canister Vacuum
I have a model DC3 rainbow thar has lost suction. what can i do to fix it
Check suction at intake without any hose connected. If that is good, then connect hose and check suction again. If that is poor, then you have a clog. If still good, then check power nozzle by getting into the belt area.
RainVac
www.rainvac.com
800-523-0510
Apr 01, 2013 | Rainbow E series Canister Wet/Dry Vacuum
Making loud high pitched noise and no suction. Belt seems fine
Sounds like something is clogged/blocking the intake hose. Pull off your bin & see if you can feel/see anything blocking that hose that everything goes thru.
Jul 08, 2011 | Bissell Vacuum - Momentum Cyclonic 1 ea...
I cleaned out the hose and removed brush to clean and checked belt. Everything seems to work but will not pick up or suction on carpet. The hose is totally clear from clogs. I can see the floor from one...
Hi troupdavid,
I see that your Vacuum is having issues with it suction, you mentioned that you took it a part to clean it, see steps below.
  • Check if everything is inserted properly and is in place.
  • make sure the the Vacuum airflow does not have anywhere else to come out from, cause if there is, the vacuum suction will really not be really getting enough suction to be able to get dirt Off the floor.
  • Make sure the bag is correctly placed in the Vacuum and is tucked in properly for proper suction.
  • The hose should be twisted to be locked into Place, either clock wise or counter clockwise which ever makes it lock to the hose socket.
  • Also check the agitator shield beneath making sure that the Belt is not pinched in or squished by the Agitator and the Agitator shield, this can also cause lack of suction for the Vacuum.
I hope that this will be of help regarding your query.
Have a nice day,
mvincentc
May 01, 2011 | Hoover Tempo Widepath Upright Vacuum -...
Brush spin,good suction at hose, no suction at
Air passage from back of brush head, through the joint, and up to bag, may be blocked.
Jul 11, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
KIRBY G-6 RUNS BUT HAS NO SUCTION, BELT IS GOOD, FAN APPEARS TO BE INTACT
1. Put the hose instead of the nozzle and see if suction is good with the hose. If it is – brush roll may be worn out (bristles must be sticking out of the nozzle by about 1/8 of an inch).
2. If there is no suction with the hose either – check if bag is not overfilled to the point where dirt is blocking the fill tube hole.
3. If two above are fine – something must be blocking the air passage from the fan to the bag. Check for clogs the fill tube (tube inside the cloth bag) and mini emptor (bag bottom plastic part) and also see if there is nothing in the exhaust on the vacuum. You may not even see it so use a piece of wire. Once I found a sock there and it was so close to the fan that I could not see it in the hole and got a grip of it only a hook made out of old coat hanger.
Oct 30, 2008 | Kirby Vacuums
Willnt pick up good...
I had this problem once too. When the hose is inserted into the vacuum, the floor unit (where the spinning brushes are) becomes the head of the vacuum. In other words, the suction goes through the floor part and then up through the hose and into the vacuum. If the suction is good when the hose is out, the the problem is blockage at the bottom piece. Take the cover off of the rollers (it is one screw then it pops right off) and see if there is a bunch of lint/hair/gunk blocking the suction hole. You could also take the hose part out of the vacuum and look down the empty shaft with a flashlight and see if you see anything there. Hope this helps!
Apr 04, 2007 | Fantom Vacums FM760 Twister 500DX Bagless...
Vacuums Logo
82 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
