Question about GE Profile WPRE6100G Top Load Washer
Ge gtwp1000moww
Drain leak
  • GE Master
  • 17,130 Answers
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Posted on Jan 17, 2013
My GE Profile refrigerator leaks water from the freezer. I find a puddle under it 2x/week.
Defrost drain tube clogged, drain pan cracked, water tubing near compressor gets brittle and leaks, critters chew on water tubing also.
Oct 29, 2013 | GE Profile 26.6 cu. ft. Side-by-Side...
GE SIDE BY SIDE FRIDGE HAS WATER LEAKING ON FLOOR FROM FREEZER SIDE
There is hole behind the freezer panel that the water should drain thru . Use a small hose in the hole and blow thru to cleam drain .
Aug 14, 2012 | GE Refrigerators
Older ge refrig, freezer at top leaking water into refrigator compartment below. otherwise its working fine.
Its the defrost problem. The drain hole is clogged and water is leaking in fridge section instead of draining through drain hole.Defrost the unit and check, for defrosting procedure , click the link below and follow the procedure:--- http://technoanswers.blogspot.com/2011/07/ge-refrig-freezer-at-top-leaking-water.html --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Refrigerators
My ge front load washer has a substantial leak when it is running. it is leaking from the bottom of the unit. It is not the drain hose or a clog in the drain. But it leaks like crazy PLEASE HELP
Check the door gasket for rips. Also there is a gasket between the two halves of the the outer drum, check that for leaks. Look at the pump housing and the hose that connects the pump to the drum for leaks.
Aug 27, 2010 | GE WSXH208A Front Load Washer
My GE Fridge Serial # GT566701 is leaking water inside the fridge. what can I do? or what might it be
look for a drain in bottom as it may be pluged with algi or ice . clean it with hot water in a turkey baster . when drain is cleared the water will stop leaking .. some model's require a drain heater to prevent it from doing it again .. mm
Aug 10, 2010 | GE Refrigerators
My GE fridge is leaking water on the freezer side
This would be due to the defrost drain being clogged. The automatic defrost cycle melts the frost on the evaporator every few hours and the water from that is suppose to flow down a drain tube, if the drain becomes restricted the water will leak out the freezer door. Here is a link to some instructions I put together on how to clean it out.
Defrost Drain Cleaning
Jul 18, 2010 | GE Refrigerators
GE Profile WPRE6100G Top Load Washer Logo
134 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
