Question about Kodak EKTAGRAPHIC III A Slide Projector
I have slides back from the 1960s will they work in a Kodak Carousel slide projector
    President:
  • Kodak Master
  • 412 Answers
As long as they are in mounts that are 2 inches square, they will work. Given the age of the slides, chances are that they are not perfectly flat any more - - so I would choose a Kodak 80 Slide Tray (as opposed to their 140 Slide Tray. The individual slide compartments in a 80 Slide Tray are wider and will be more forgiving if your slides are slightly warped.
If you need to buy a slide tray, contact Vine Valley Imaging (www.vinevalleyimaging.com). Good Luck! Jim
Posted on Jan 17, 2013
SOURCE: My Kodak Carousel 750H slide projector will not
A common cause for that problem is a broken plastic "link" on the solenoid (Kodak part #217769). There are repair shops who can replace this part. It is very difficult to replace by yourself. http://www.kodak.com/global/en/service/repair/slideProj/index.jhtml
Posted on Nov 11, 2009
  • 412 Answers
SOURCE: I'm having a problem loading a tray onto my kodak
First, with the tray off the projector, cycle the projector several times in forward and then in reverse. Next, check to make sure the locking ring on the top on the slide tray is LOCKED ON TIGHT. Then turn the tray upside down. On a 140 Slide tray there is an index notch. On the metal plate there is a index hole. Gently release the metal spring of the tray latch and rotate the metal plate until the notch and hole line up. Now the tray should drop on the projector and index properly.
Posted on Dec 03, 2010
  • 412 Answers
SOURCE: I just purchased an older Kodak slide projector
By the sounds of your description, your projector needs an adjustment to the slide change mechanism. This is best done by a factory-trained dealer, who has the service manual. Sorry I can't be of more help. Happy New Year!
Posted on Dec 30, 2010
  • 412 Answers
SOURCE: I am trying to locate
Kodak has an e-copy of the manual on their website:
http://support.en.kodak.com/app/answers/detail/a_id/19709
I hope this helps !!
Posted on May 18, 2011
  • 412 Answers
SOURCE: my kodak carousel 5600 slide
You are experiencing a fairly common problem called continuous cycling. It is caused by use or mis-adjustment.
If you feel comfortable with a electro-mechanical adjustment, take a look at the attached picture for the correct alignment of the cycle contacts. The positioning is critical for correct operation.
Turn the projector upside down (unplugged), and remove the bottom screws. Then carefully remove the bottom cover. The cycle contact assembly will be in the center of the projector.
If you need help, contact a authorized repair dealer. Good Luck!!
Posted on Aug 08, 2011
Kodak carousel 760h projector
Yes, there is a fix. It's a pretty straight-forward adjustment. You can go to this web page: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-locale=en_US&pq-path=6499
The Service Manual there will detail the the adjustment.
Good Luck !! Jim
Mar 11, 2014 | Office Equipment & Supplies
Kodak carousel 750H slide projector power cord missing
Detatchable power cords for KODAK Carousel Slide Projectors can be purchased from: www.micro-tools.com
or: www.vinevalleyimaging.com
Good Luck!! jim
Sep 13, 2013 | Kodak Carousel 4600 Slide Projector
Kodak Carousel 600 Slide Projector manual
The KODAK Carousel 600 Projector has NO forward or reverse controls. To cycle the tray forward, LIGHTLY depress the SELECT bar. Reverse is accomplished by holding the SELECT bar down completely and rotating the tray by hand. Jim
Apr 03, 2013 | Kodak Carousel 600 Slide Projector
Will slides back from 1960 work in a Kodak Carousel Slide Projector?
As long as the slide film is in 2"x2" mounts, yes! I would advise you to use an 80-slide tray as opposed to a 140-slide tray. The individual slide compartments in an 80-slide tray are wider, making it more forgiving to older, possibly warped slides. 80-slide trays can still be purchased from: www.vinevalleyimaging.com. Good Luck! Jim
Jan 16, 2013 | Kodak Carousel 4600 Slide Projector
I am trying to locate an instruction manual for a Kodak 5600 carousel slide projector. Will pay a reasonable price!
May 13, 2011 | Kodak Carousel 5600 Slide Projector
The lever that drops the slides gets stuck in the 'up' position when the carousel is on the projector but it works fine when there is no carousel attached. When it gets stuck you have to take the carousel...
If you are using a 140 tray with older slides, that's very logical! Over time, slides develop a "side-to-side curve". Because the Carousel 140 tray stretches the design limits of the projector to be able to accurately return the slide to the tray, the slightest bend or "dog-ear"(the fraying of the corner of the slide) will cause exactly the problem you're having. If you have a Kodak 80-Slide tray, try it. Chances are that it will work fine. If it does work fine, then you have 2 options: 1. Move all your slides into Carousel 80 Trays.
2. Have your slides re-mounted (that is, have the paper mounts replaced).
Feb 14, 2011 | Kodak Carousel 4600 Slide Projector
What is the correct carousel for a kodak 760 H projector?
A KODAK Carousel 760H is designed to be used with either KODAK 140 or KODAK 80 Slide Trays. The KODAK 80 Slide Tray has wider slide compartments, which tend to be more forgiving for older, slightly warped slides.
Oct 02, 2010 | Kodak Office Equipment & Supplies
I just purchased an older Kodak slide projector with a carousel on top. Everything works fine but the carousel won't advance. When you click the next button, the plastic arm that should advance the...
Nov 14, 2009 | Kodak Carousel 5600 Slide Projector
Trying to find a carousel that will fit Navitar model CP-300AF
I am pretty sure that the projectors modified, marketed & sold by Navitar were Kodak projector bodies & slide transports. Assuming this is the case, a Kodak 80 Tray should work just fine!
Aug 03, 2009 | Navitar 750-AF 35mm 80 Slides Rotary...
Kodak EKTAGRAPHIC III A Slide Projector Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
