Power light flashes and computer turns off
Hi....I have a Compaq Presario SR1838NX. When I push the power button to turn it on, it flashes green for about 5 seconds and then automatically shuts off. It never completes the power up cycle. It's only 3 years old. Any suggestions? Thank you for any help.
  • 3 more comments
  • Kimberly Roberts
    Kimberly Roberts Jan 24, 2009
    Power light on the front
  • Kimberly Roberts
    Power light on front
  • Kimberly Roberts
    I have already replaced the power supply with no luck
  • BrandonSH Apr 12, 2009
    We have the same problem with our HP tower.
  • 1r1sh May 11, 2010
    More info needed, power light on the front? or on the monitor?
  • 23 Answers
This is a 1,2,3 item. If it is not the power supply, the cpu or motherboard are the next likely culprits. Generally, if the power supply is OK, the pc would have the fans running and you should be able to open the case and check the North Bridge, the large chip on the motherboard near the cpu and the cooler on the cpu itself. If they are both still cold, it is most likely the mother board.
It it were the cpu, it won't post, but you should still be able to feel the heat with the back of your fingers, just to be safe and touch it quickly so you don't get burned.
You can also try to remove the ram and try to reboot, if you get a steady series of beeps, you can add 1 stick at a time and reboot just to try to elimanate ram as a potential problem.
My next step would be to remove all of the other cards and add 1 at a time and reboot after each card, I probably removw the 4 pin connectord from the dvd/cd hard drives also ans add 1 at a time.
I know this sounds like a lot of work, but this is how I troubleshoot pc and telephone systems for the last 25 years.
Posted on Jan 25, 2009
Compaq Presario SR1123WM desktop won't turn on
Hello Kim.
When you press the power button, is there no life?
The PC may be set up for manual start instead of auto restart after power is restored.
Otherwise a surge may have blown the PSU.
Mine's not a Compaq but I'll research what the green light is.
Could be a modem....
Dec 04, 2017 | Computers & Internet
My Compaq Presario SR1250nx will not turn on. The power chord is attached and power strip is turned on. I've also tested on a stand alone outlet to ensure it wasn't the power chord. A little green light...
Looks like your power supply's failed. The green light on the back of your power supply is just a neon light that just confirms that the power lead is OK, it does not relate to the status of the power supply! Try powering it up with another power supply, or replacing the power supply.
Oct 14, 2010 | HP Compaq Presario SR1250NX (PJ534AA) PC...
Compaq Presario sr1550nx wont power up. Green light on power supply is blinking. What is that telling me?
Basically, I think that your power supply has gone bad if nothing at all happens when you turn it on.
To test this, disconnect the hard drive, the CD, and any other peripheral and try to start it.
All this assumes that when you push the on/off button, all you hear is yourself breathing--nothing at all from the computer.
Oct 11, 2010 | HP Compaq Presario SR1550NX (PY059AA) PC...
Green light is flashing in back of computer but it will not turn on
if the green light you're mentioning came from the power supply, you need to replace it. green light flashes from the LED at the back of the power supple serves as an indicator if you have a good or a faulty power supply.
Aug 07, 2010 | Compaq Presario 5000 PC Desktop
Compaq Presario SR2150NX doesn't turn on. Front panel green light turns on but nothing else happens (no fans, no boot, no noise, nothing) Please advice
On the back of the Power Supply there should be a Green LED, When you power it on if it is flashing, this means that the Power Supply is dead and you need to replace it.
Apr 14, 2010 | HP Compaq Presario SR2150NX PC Desktop
HP Compaq Presario SR1820NX will not turn on
i worked for hp and compaq it is well known issue to reslove this issue
1#turn off the computer and uplug the power cable from the computer and then hold the power button for 20 second then turn on the computer and the momment you back to desktop screen
go to download driver from hp site and here is the web site and restart the computer .
Apr 15, 2009 | HP Compaq Presario SR1820NX (ER919AA) PC...
On my desk-top presario
HP/Compaq has had alot of power supply issues with this series of computers. Do you have another power supply you can try in this system? If the light is flashing rapidly, it is usually a power supply. Fairly cheap and easy to replace.
Jan 26, 2009 | Compaq Presario SR1050NX (DW257A) PC...
Flashing Green Light on Power Supply
get yourself a themaltake ps
make sure you remove the old one and take it with you to the shop or get the shop to do it for you if you dont have the expertise yourself.
hope this helps
Dec 31, 2008 | Compaq 300Wt Presario ATX Power Supply...
Red light flashing on power button
Sounds like the hard drive has had a failure, you need to get a replacement one, and reinstall it, along with the opperating system, and any other programs that were on the old one.
Feb 14, 2008 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
1,191 people viewed this question
David Payne
David Payne
