Question about Air Ride Management 1996-2003 Renault Megane Scenic Plug and Play Air Suspension Kit
My 2003 Scenic 1.9dci battery keeps going flat overnight. I've changed the battery and still the problem persists. It's difficult to start on a morning that's if it starts at all and every time I need to start it with a jump after the battery dies pretty soon after cranking it on a morning. I've checked the glow plugs and they were fine so I had the electrics to the glow plugs checked and when the ignition is switched on there is a +12volt supply to the plugs as to be expected. Then when the ignition was turned off I still had a +6volt supply going to the glow plugs. I presume that this +6volt constant supply to the glow plugs is where I am losing my battery's power overnight. Does anybody have an idea what can be causing this +6volts constant feed to the glow plug wiring? Any help anybody can give me in this matter will be greatly appreciated as it would be a pain to have to disconnect the battery every night in order to stop the battery going flat. Thanks in advance, John
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 136 Answers
Take it to an Auto Electrician and they should find the problem and there is a leakage in the glow plug system
Posted on Jul 28, 2015
Fixya car
Check altanator
Jul 24, 2013 | 2003 Kia Rio
2004 murano
Temporary fix until you find someone who knows.
When you pull into your place to park the car for the night, or whatever, go ahead and unhook the battery. Re-hook up the battery when you are ready to drive it again. That will at least keep you from not driving it at all.
Jan 12, 2013 | 2004 Nissan Murano
My mitsubishi challenger keeps dying when i go up the hill or downhill. i've changed the fuel pump but the problem is the same. sometimes its difficult to start the engine..
Check the condition and/or operation of the following:
1) Spark plugs, coils and leads.
2) Air filter
3) Fuel filter.
Please report back if no findings.
Nov 13, 2012 | Mitsubishi Cars & Trucks
I have a 2003 silverado with the 6.6 diesel engine and I've had a problem this summer with it not wanting to start after it sits through lunch. I've replaced the filter and batteries but it still...
FUEL PRESSURE IS GETTING LOW PUMP MY BE GOING OUT YOU PUT NEW FUEL FILTER ON IT BLEED FILTER REAL GOOD, CHECK ANY WHERE IT MY BE SUCKING AIR; PUMP UP THE FILTER BE FORE YOU RUN THE BATTERY DOWN TRY IT !?
Aug 30, 2011 | 2003 Chevrolet Silverado 2500HD
2003 - RX300 I'm tring to change the battery,when I connect the negative terminal, the horn blows and won't stop... I've turn the key to start and nothing happens, the horn keeps blowing.......
I would check to see if this is a relay problem for the horn. Remove the relay for the horn and see if you can swap it with another to confirm it is bad. If with another relay it doesn't stay on you no it was just a relay so go get a new one. The only other thing could be a security issue and when you discharged the power by unhooking battery the vehicle is acting like it has been broken into. But i would say it's a relay problem. Good Luck.
Jul 26, 2011 | Lexus RX 300 Cars & Trucks
My 2000 renault scenic battery keeps going flat. I've put in a brand new battery and the car battery died again yesterday at my son's school after starting first time at work. What should I be looking at...
Something is draining the battery, or either the alternator isn't putting out to keep the battery charged. A local shop can usually check it for free and let you know if it's the alternator. The other is a shortage somewhere which will be a pain to trace down.
Apr 19, 2011 | Renault 181 Cars & Trucks
Renault megane scenic chugging when going right 98
if this is an auto gearbox change the transmission fluid
May 02, 2009 | 2003 Renault 181
Air Ride Management 1996-2003 Renault Megane Scenic Plug and Play Air Suspension Kit Logo
104 people viewed this question
Top Air Ride Management Air Tools & Compressors Experts
Mr R D Cochrane
Mr R D Cochrane
Andrew Taylor
Andrew Taylor
Are you an Air Ride Management Air Tool and Compressor Expert? Answer questions, earn points and help others
